Old 02-25-2011, 11:30 AM   #1
fun in dirt
fun in dirt's Avatar
Can I go from 17" to 16" wheels
Just found a killer deal on some factory 16" aluminum wheels.
I want to replace these steel work truck 17" with them... will they fit?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-25-2011, 11:02 PM   #2
clinebarger
Re: Can I go from 17" to 16" wheels
They will fit.
clinebarger is offline   Reply With Quote
Old 02-25-2011, 11:07 PM   #3
71swb4x4
71swb4x4's Avatar
I don't know for sure either way, but I would check the brakes first. Those are from the last body style too, not sure if the backspacing is the same???
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-26-2011, 12:05 AM   #4
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
what year is your truck? they started putting bigger brakes in '05 when they went back to drum rears.
'85 swb
droppedgmc is offline   Reply With Quote
Old 02-26-2011, 12:11 AM   #5
bwood
bwood's Avatar
Originally Posted by clinebarger View Post
They will fit.
16"s were also an option when new.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 02-26-2011, 12:35 AM   #6
clinebarger
Yep, My 04 1500 Crew has 16"
Old 02-26-2011, 01:11 AM   #7
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Depends on what year your truck is. 99-04 can use 16s. In 05 they went to rear drum brakes with bigger front discs that require 17" rims.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-26-2011, 02:36 AM   #8
crashedout
crashedout's Avatar
x2 my 06 crew came stock with 17's and when i tried to put a reversed drop 17" it wouldn't clear the calipers
crashedout is offline   Reply With Quote
Old 02-28-2011, 11:18 AM   #9
fun in dirt
It's an '07 Classic. Your right...after researching I learned about bigger brakes in '05 too. Went outside & looked - It's only about 1/4" now between caliper & inside of wheel, so no way 16" would work.
I love the look of the 20" factory wheels (found this pic somewhere surfing around), but refuse to pay $1000+ for used wheels...something good will come come up I'll just keep looking.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 02-28-2011, 06:50 PM   #10
bwood
bwood's Avatar
Well I'll be dipped in............................
I knew about the change in brakes in 05, but didn't know about the size change.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 03-24-2011, 10:09 AM   #11
1985ChevyK20
1985ChevyK20's Avatar
i did on my 2000 chevy silverado and they work and look good
1985ChevyK20 is offline   Reply With Quote
