Old 02-24-2011, 12:40 AM   #1
Bigo Serge
How to install e.fan??
Hello everyone,
I have been trying to research the procedure on installing an electric fan on my 2002 silverado, but have not been lucky. My question is.....
1- Can I use the factory efan from a 05 silverado on my truck?
2- Will the efan have to be connected to the computer or will it pick up the signal from the temp. sensor and the AC relay?
3- What is your opinion about the flex-a-lite fans, and how much more does an efan increase in mpg?
Your input is greatly appreciated, Thanks
Pick'em up, lay'em down, Oh Yeahhh
Bigo Serge is offline   Reply With Quote
Old 02-24-2011, 10:41 AM   #2
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
Re: How to install e.fan??
1- Yes you can use the ones from an '05, but you would also need the 34" radiator. you can pick up a set of ls1 or lt1 fans for your current setup and will work fine.
2-wire it in with a pair of relays, 1 relay per fan. you can use your own temp sensor if you buy one, doesn't need to tie into the computer
3-flex-a-lite makes very good fans, expensive though. ls1/ lt1 fans can be had for $100.00 or less
'85 swb
droppedgmc is offline   Reply With Quote
Old 02-24-2011, 07:30 PM   #3
Bigo Serge
Thanks DroppedGMC,
I'm going to look for a lt1 fan.
Old 02-24-2011, 10:20 PM   #4
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
i'll post some pics up for you
'85 swb
Old 02-24-2011, 10:38 PM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
LS1 fans and zip ties.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-25-2011, 01:21 AM   #6
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
^^ what mine looks like
'85 swb
Old 03-04-2011, 03:16 PM   #7
Chlorin8ed
Did you notice an increase in gas mileage? Any problems with electric fans with towing?
1987 Chevy R10
2004 GMC Sierra
1980 Chevy Malibu
Chlorin8ed is offline   Reply With Quote
Old 03-04-2011, 11:52 PM   #8
usmcchevy
usmcchevy's Avatar
About 1 mpg highway, no difference city. Never had any problems towing. I didn't tow much, but had no problems when I did.
Build thread
LSx Swap FAQ index
Old 03-06-2011, 07:27 PM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
What do you get the lt1 or ls1 fans off of. Camaro? What year? I want to do this to my tahoe.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 03-06-2011, 10:59 PM   #10
usmcchevy
usmcchevy's Avatar
98-02 Camaro/Firebird with a LS1 engine. The older Camaro/Firebird with a LT1 efans will also work. I'm going to try to throw a "how to" together on this when I get time.
Build thread
LSx Swap FAQ index
Old 03-07-2011, 03:05 AM   #11
Jacfourteen
Thanks for the info, next time I go to the local junk yard I'll have to keep an eye out.
Old 07-29-2012, 09:34 PM   #12
Boog
laying low
Boog's Avatar
I just revisited this thread and wonder if you ever got around to the fan writeup? Thanks.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
