04-07-2011, 12:32 AM | #1 |
Reverse lights not working.
My 1970 c10 reverse lights do not work. How can I get them to work?
04-07-2011, 01:36 AM | #2 |
Re: Reverse lights not working.
#1) I'd check the Fuse Box. I believe they take a 10 amp fuse.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
04-07-2011, 08:59 AM | #3 |
Restoration Virgin!
Couple other things to check is the brake light switch on the brake pedal, also verify that you have good ground s
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
04-07-2011, 09:39 AM | #4 |
Hey there-- I feel your pain-- I went through this with all of my rear lighting (bad cut up at bumper by PO) -- BUT-- As above, after the fuse check the grounds- I think these ground-out in the case-- so you need to make sure the back-up light case is properly tightened. (clean metal bolt and case).
my 2 cents |
04-07-2011, 09:46 AM | #5 |
04-07-2011, 10:02 AM | #6 |
i'd first check that there is voltage boming in to the backup switch,if yes then i'd see if there is voltage coming out of the switch when in reverse, if not try adjusting switch
if you get voltage out of the reverse switch then you need to follow that wire to the rear and find out where you stop having voltage , if voltage at the socket for the backup lamp then bad grounds
04-08-2011, 01:43 AM | #7 |
Can anybody post any pictures of the grounds and how the back up switch is suppose to be mounted?
04-08-2011, 07:47 AM | #8 |
Auto or manual transmission? If manual, which one?
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-08-2011, 10:47 AM | #9 |
Forgive my hijack here. Where is the backup switch on a 4 spd manual truck? My truck is converted from a 292 cylinder 4 spd to the a 350 th350 disc brakes out of a 71 and I need to find the backup switch plug in the wiring harness. When I find the plug then I can run it to the bottom of the column, making the reverse lamps work.....I hope.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
04-08-2011, 11:22 AM | #10 | |
Automatic trucks where different than 3 on the tree columns. |
04-08-2011, 02:45 PM | #11 |
Mine is a TH350 Automatic.
04-08-2011, 04:29 PM | #12 |
bottom of steering column near the floor the neutral safty switch and reverse are ont switch with 4terminals on it// to heavy 12 gauge purple wires are for the neutral safty part the backup light wires are thinner gauge16 if i remember right green
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-08-2011 at 04:35 PM. |
04-08-2011, 04:38 PM | #13 |
The column from the 71 was installed in my truck, so yes I have the neutral saftey/reverse lamp switch on the bottom of the column. Besides it needed a column for the shifter. Which side of the truck would the switch in the 4 spd have been? Thanks and I return you to your pervious thread.
12-09-2014, 11:17 PM | #14 |
picking up where Btc10 left off...I have the same issue. My neutral safety/backup light switch is on the bottom of my steering column. There are no wires. If I were to make wires..where would they go?
Thanks!
Joe 1968 K20 1970 K20 Semper Fi |
12-09-2014, 11:21 PM | #15 |
Thanks!
12-11-2014, 04:49 PM | #16 |
I'm in the same boat. Have a switch but no wires
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
12-23-2014, 03:35 PM | #17 |
My 1968 Panel didn’t have a reverse light switch when I bought it. It came with a Saginaw 4-speed with a Universal Shifter from Summit Racing. I wasn’t very happy with the universal shifter from Summit so I replaced it with a Hurst Competition shifter. I also bought the reverse light switch that mounts to the back of the shifter. I found the reverse light plug on the dash wiring harness and ran wires from the switch to the plug.
12-23-2014, 08:06 PM | #18 |
I had/have a similar issue. I adjusted the reverse switch on the column, but my 3ott is super floppy which requires holding the shift lever up for the lights to stay on
12-24-2014, 05:43 AM | #19 |
I'm the opposite! I have wires but no switch, my truck was totally gutted by the PO so I've been going from scratch! New everything! I have a new harness and new column. But I have 2 light green back up lights wires with no idea where they go? Switch? Does it go to the tranny? Does it go to the column? Do I needto buy a switch and install it? I'm totally confused? I'm sure it's something simple. If I figure it out, I will post a detailed description!
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
12-24-2014, 11:57 AM | #20 |
If you have the two wires (light green and dark green) you have half of the battle won. Those two wires have to be connected together via the backup light switch. Do the two wires have a socket connected to them? If not, you should be able to test the backup light function by connecting the two wires together and then turn your ignition key to the “on” position. Check to see if your backup light are on. If they are, all you have to do is install a switch by your shifter. If they are not on, check your backup light fuse on your fuse panel. If the fuse looks good, check the continuity of the fuse. I found out the hard way that even new fuses can be bad. What kind of shifter are you using? As I stated in a previous post, I’m using a Hurst Shifter and bought the backup light switch from them and it fits right up to the shifter. In my case, I had to clean all of the paint overspray from the backup light sockets that the previous owner neglected to mask off during a re-paint.
12-24-2014, 12:40 PM | #21 |
No backup light switch exist that I know of. my shifter is on the column. I haven't bought the linkage of yet.
12-24-2014, 01:20 PM | #22 | |
12-24-2014, 02:48 PM | #23 |
There is a backup light switch on the steering column that I believe you can purchase through one of the 67-72 truck suppliers such as Brother’s or LMC. It mounts to the steering column with two fasteners. Napa may even carry them. The socket for the switch has two blades at 90° from each other, ( looking similar to this: _ | ) so you can plug into the switch. As far as having a push button starter, you’ll have to have an on/off switch to energize the ignition/accessory system before starting. Do you have a color wiring diagram for these trucks? They are available from other subscribers on this website for download. You can even find them through a Google search. A valuable tool to have when wiring these trucks.
12-24-2014, 02:51 PM | #24 | |
12-24-2014, 03:30 PM | #25 |
Mine were disconnected at the lamp housing as there is/was a quick disconnect....well...disconnected there.
