04-14-2011, 09:32 PM | #151 |
Re: How to: Ruin a perfectly good C10
Nice work on the exhaust...I bet you can't wait to fire it up!
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
04-14-2011, 09:55 PM | #152 |
A guy with a truck
Thanks! I hope it has a little rumble- the mufflers are pretty small Dunno how I'll drive the truck without the exhaust smell; it had become such a part of its character...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-14-2011, 10:22 PM | #153 |
I can appreciate the effort as I've been mocking mine up this week too.
I went by Northern Tool today @ lunch & got some stainless wire for the welder. After work I started making my alignment 'tool' for tacking all the bends together 'in place' in the chassis. I'll weld it up on a pipe stand. What mufflers are they? How much was the pipe kit?
04-15-2011, 12:51 AM | #154 | |
A guy with a truck
The muffs are Magnaflow, um, I couldn't tell ya. Been a while since I bought them. They, like many things that ended up on this truck, were intended for the Blazer. I do know they were some of the smallest I could get in a 2.5" in/out. You can see straight through them- I wanted to do something other than flows- I must be getting old I think I paid $199 for my Flowmaster U-fit kit a while back- they are now $239 through Summit, and the stainless is $279. Looking back, I should have gone stainless, but this is what I had on hand. Show us some pics when you start working it
04-15-2011, 01:12 AM | #155 |
A guy with a truck
Does anyone see anything wrong with these shocks? Notice how there is nothing holding them compressed, yet they are fully collapsed- I'd say they're smoked Luckily, I picked up a set of Monroes on Amazon for, get this, $6 each with super saver shipping! I love that site for smokin' deals...
I wanted to get them installed to make sure my clearances were still gonna be good with the larger shock body. The pics (taken at slightly higher than ride-height) show just how tight it is around that area- I'm trying to keep at least 1/2" clearance between the exhaust and anything else, so I may have to do some tweaking around the shocks- we'll see. the pics make it look closer than it really is...
04-15-2011, 08:53 AM | #156 | |
Check out Lakeroadsters build thread for his upper rear shock mod. He built a simple new bracket that raised the shock mount & relocates it further back helping to stand the shock more upright. That might help increase your clearance & give you a little better shock performance.
04-15-2011, 09:30 AM | #157 |
67cheby
nice work
04-15-2011, 10:41 AM | #158 | |
A guy with a truck
Thanks!
04-18-2011, 09:24 PM | #159 |
A guy with a truck
Completed the front section of the exhaust this afternoon. What fun, taking a 2" hole saw to a freshly installed set of pipes
I tacked the H-pipe assembly together on the truck, then removed it to finish weld on the bench. Turned out pretty nicely- it tucks up higher than the trans pan, just behind the crossmember and under the tailshaft. It will remain completely removable with band clamps on the pipes at the t-arm crossmember. I am not particularly happy with how my welds are looking on this exhaust- the beads seem to want to 'build-up' on me- I'll hafta play with the settings some when I finish weld the over-axle pipes... Included a few pics of the hangers I'll be using. They're called 'Snappers'. I used them once before, on my Blazer (the red ones) and liked them, so I picked up four more to use on rear sections. They're blue 'cause the red ones were $5 each- the blue $2 on eBay
04-18-2011, 10:51 PM | #160 | |
Do you have a link for the hanger bushings? I know of one source but other choices aren't a bad thing .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-18-2011 at 10:51 PM. |
04-19-2011, 04:13 AM | #161 |
Big Red - Now its a SWB!
Looking good! You have been making good progress, looks like the only major project left is to finish up the bed.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
04-19-2011, 09:26 AM | #162 | ||
A guy with a truck
Thanks Looks like it! Hope to start on the bed next week- then it will be all loose ends from there...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-19-2011 at 09:28 AM. |
04-19-2011, 02:37 PM | #163 | |
Has more rust than truck...
04-19-2011, 06:41 PM | #164 |
A guy with a truck
Thanks The shocks are Monroe 32301s. Looks like they are back to 'normal' price now, $20.62. I've gotten lucky like that a few times with Amazon; just have to be in the right place at the right time, I guess...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-19-2011 at 06:42 PM. |
04-19-2011, 10:48 PM | #165 |
A guy with a truck
Received my vinyl dye recently, so I thought I'd give the armrests a shot. They were in poor condition from years of abuse and one of them was a different color from a failed experiment- the color was NOT the same as the cap...
Through a little research, I found that the 68-70 Corvette bright blue is the same (or VERY similar) as the '70 truck color. I couldn't find a truck vendor that advertised their dye as anything other than 'blue', so I bought Corvette dye. It was cheaper, too The color is spot-on and laid down very nicely. It matches my dash pad very well, excepting the fact that it is faded in a few spots. I am contemplating giving it a shot too- which likely means that it will happen...
04-19-2011, 10:54 PM | #166 |
looks pretty good.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
04-20-2011, 10:51 AM | #167 |
67cheby
looks great
04-20-2011, 11:23 AM | #168 |
Still Learning
Awesome build thread! I love it. I got a lot of inspiration from your project. I am subscribed now.
Hey, sorry to hear you had to sell the Blazer. Man, I would have jumped on that thing. I never knew it was for sale. I noticed your avatar had changed but never guessed you had to part ways with it. If you decide to dump this project let me know |
04-20-2011, 09:35 PM | #169 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 04-20-2011 at 10:02 PM. |
04-20-2011, 09:56 PM | #170 |
A guy with a truck
Finished up the exhaust today. Had to use two more bends to get the pipes from over the axle back to the bumper. I ended up using factory holes in the shock crossmember and rear framerails to bolt the 'snapper' isolated mounts to- still need to get some longer bolts for them, as they are temp-installed with what I had on hand. All in all, it turned out decent once I got my welder settings down- I wish I could go back and re-do the forward H-pipe section and get rid of the booger welds, but, oh well, it will work
The rear pieces that run parallel with the 'rails will get either turned down or kicked out towards the ends of the bumper, since I have a couple of 90* bends left, but I will decide on that when the bed goes back on and after the next big projects- bed/body work and paint
04-21-2011, 12:11 AM | #171 |
Still Learning
Nice work on the exhaust. You probably already said, but, where did you get the kit? What dia. tube? Can't wait to get to that point.
04-21-2011, 04:55 AM | #172 | |
A guy with a truck
04-21-2011, 11:19 AM | #173 | |
Still Learning
04-21-2011, 07:48 PM | #174 |
A320 Pilot/USAF Retired
Very nice work on the exhaust!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
04-21-2011, 11:10 PM | #175 | |
A guy with a truck
Thanks! It turned out pretty well, I think. Should suit my needs just fine- hope to fire her up in the next couple of days and see how it sounds
