#101 |
VA72C10
![]() Join Date: Mar 2008
Re: 71 Cheyenne Super- A Combined Effort
Nice progress!!! Looking good!!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#102 |
Very nice progress and build, Subscribed!
99 Camaro Z28 420hp/400tq 1998 Tahoe Z71 2dr 6" Rancho 35's DAILY |
#103 | |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#104 |
Looking good,keep on truckin''
#105 |
Moderator
![]() Join Date: May 2007
lookin' tough!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#106 |
I was looking at your inner rocker and wondering why it doesn't run up to the seam? looks to be short, I'm doing mine now and that area just doesn't seem to fit right. what your trick?
#107 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Truck is really comming along guys keep up the good work..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#108 |
Burnouts are therapeutic
great work geoff and jesse , that cab and rust repair look very fimiliar to me!
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
#109 | |
Since we are on the subject of cab repair, here are a few pictures of progress from this weekend. The bracket that the lower door hinge bolts thread in to was missing from inside the a-pillar on the passenger side. sharpie1972 sent us a used one. I didn't get a before picture, but the bracket is L-shaped and has a thin sheet metal "cage" that is spot welded to the a-pillar in two place. The cage is designed so the bracket will not fall into the a-pillar, but it has enough play that the hinge can be adjusted. So, I drilled out the spot welds on the piece sharpie1972 sent us: ![]() I guess I was making good progress, because I didn't think to take any pictures of the next steps! I then used the old a-pillar as a template and marked the two holes on our cab, and drilled them out. I cut a square access panel to get to the inside of the a-pillar, slid the bracket and cage inside the a-pillar and spot welded it in place. In order to pull the bracket/cage close to the a-pillar, I inserted a 1/4-20 bolt with a large fender washer on the backside through the bracket and used a washer and nut on the outside to hold the bracket/cage in place. In this picture you can see the top spot weld (I have already ground some of it down) and the access hole in the front: ![]() ...then it was just a matter of welding everything shut and putting primer on the exposed metal: ![]() ![]() ![]() ![]() I also worked on fitting the driver's side cab corner today. I have a little more work to do on it before I weld it in place, but it is close. While I was doing this, Geoff was working on the frame, suspension, steering, etc... More to come on that later!
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
#110 |
Still Learning
Very nice work guys! Awesome repair. Brings back fond memories
#111 |
Restoration Virgin!
So glad to be working with Jesse on this one, cuz I know I would of never been able to weld things up as well as he does.....Wanted to also post up some pictures of painting the chassis and suspension parts, and our progress on the assembly.....
Jesse built this "swing" for the parts to hang on for painting ![]() ![]() and here's the rear end ![]() and this is what we used....suggest getting 3 quarts, but maybe cheaper to just buy a gallon ![]() ![]() and the chassis.....we lacked a lower control arm seal (stupid me forgot to check to make sure they were in there), and the 2-u-bolts for the rear end...it's amazing what 3 measly parts can railroad your weekend work ![]() ![]() By the way....we ended up using MOOG Control arms, tie rods, and adjusting sleeves, and TRW ball joints ![]() ![]() ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-02-2011 at 12:26 PM. |
#112 |
67cheby
![]() Join Date: Sep 2008
Nice progress
#113 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Looking really really good fellas. Nice work on the patch Jesse!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#114 |
I am proud of my redneck swingset. It is a shame that I have to disassemble it tonight.
#115 |
Still Learning
Hey you guys are doing some nice work! Coming together fast. I like the swing set. very good idea.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 05-02-2011 at 11:47 AM. |
#116 | |
Restoration Virgin!
Thanks!!
![]() Quote:
![]() Thanks Mike.....we actually released one side of the tie straps to paint the bottom side....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-02-2011 at 12:25 PM. |
#117 | |
Restoration Virgin!
#118 |
VA72C10
Nice work guys!!!
#119 |
I will need to reinforce it before we hang a Suburban!
#120 |
I've just got to say,that you have done some very nice work & love the welding you have done on the cab,keep up the hard work,love the pictures of the progress,hope to see more soon
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() Last edited by RCbowtie69; 05-02-2011 at 08:33 PM. |
#121 |
I agree, very nice repair work. Great job fellas!
#122 |
PROJECT 7DEUCE
Nice work guys.
#123 |
Restoration Virgin!
We're getting a burb?!?!?...
#124 |
Yep, it is a 71 rust free survivor with original paint. It was owned by an older gentelman in Arizona and he only drove it on Sundays when it was not raining. It has 27,890 miles on it and some decent options: big block, bucket seats, factory tach. It is blue and white. It should be shipped to your house today. I hope your wife doesn't mind.
#125 |
Cool,hope to see pictures of it soon,nice score
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
