02-12-2009, 01:19 PM | #1 |
67-72 parts collector,…
Conversion tie rod sleeve for DISC brakes on a 67-70
I'm installing 71-72 Spindles on my '69 swb.
I'd like to run the original cross link and inner tie rods,... but know I need to swap to the 71-72 outer tie rods. Here's my question. Are the 71-72 outer tie rods the same diameter as the 73-87 outers? This conversion sleeve is offered by Performance On Line. (part# HPAS6370) http://www.performanceonline.com/sto...cat=787&page=1 Can I use these with my 71-72 outers? Or will 73-87 outers work in a 71-72 spindle?
02-13-2009, 10:49 AM | #2 |
Re: Conversion tie rod sleeve for DISC brakes on a 67-70,...
The adjusting sleeves for a 1971-72 is the same as the sleeve for a 73-87 (the tie rods are different but have the same threads).
The 73 up outers will not fit the 71-72 spindle arm. I think the taper or maybe the thread length is different, can't remember off the top of my head. I used 73 up drop spindles on my truck because they were cheaper for some reason... I double checked this on Autozones website. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-13-2009, 12:24 PM | #3 |
Have you bought the adapters yet? If not I can probably save you some money... I know these can be bought at most places for about $49 but this place builds race car stuff and makes those adapters for $14 each.
Just call and talk to Randy. Make sure to tell him the 11/16-18 is RH (right hand) and the 5/8-18 is left hand. The length for these trucks is 5-1/4" One thing no one tells you is you have to use the 65-70 OUTER as the INNER or you will end up with 2 ends that have RH threads (they won't adjust that way!) http://www.dcaracing.com/cat_steering.html Rg
02-13-2009, 12:49 PM | #4 |
Wow,... I'm 22 minutes too late. (my luck)
I already have them coming. Good info for everyone else though.
03-14-2009, 10:00 PM | #5 |
Update:
I went to install the adapter sleeves today from POL. I'm using 71-72 drop spindles on my 69 disc brake swap. I purchased 71-72 outer tie rods and 69 inner tie rods. Heres the problem. 71-72 outers are RH thread. 69 inners are ALSO RH thread. So I guess I have to purchase 69 outers and use them as inner tie rods so the will be LH thread and adjust properly. I wish POL would have had this info on their website. NOT a big deal,... just a waste of money and a set back on todays progress.
03-14-2009, 10:44 PM | #6 |
73-87 outers are the same thread size as 71-72 outers.
I checked my old tie rod ends to confirm that I needed to do this.
03-15-2009, 04:08 PM | #7 |
Didn't think the 69 rod end diameters were different than the 71-72 ?? I know the taper is different, are the threads also ?? I used McGoheys 71-72 drop spindles.Just wondering ! THANKS IN ADVANCE
03-15-2009, 05:53 PM | #8 |
I believe the 69 is 5/8" diameter and the 71-72 is 11/16" diameter. I'm also using 71-72 McGaughy's drop spindles on my 69.
Mine is also a non-power steering, 6-cylinder truck.
03-15-2009, 06:17 PM | #9 |
so is each end tapped accordingly ( 5/8 1 end and 11/16 on the other ??)
03-15-2009, 06:26 PM | #10 |
YES.
The 11/16" end is RH thread,... and the 5/8" end is LH thread. They also sell "stock replacement" sleeves, if you just want the "looks" of these sleeves.
03-17-2009, 12:29 AM | #11 |
Glad I caught this post as I'm swapping '93 LD 3/4T spindles onto my '68 C10. Started checking all ends for both years & discovered the '68 has one LH & one RH thread outer in the 5/8". The '93 donor has 11/16" RH on both.
Looks like I'll be swapping Inner & Outer on one side before I can complete this deal. Raggedjim, Thanks for the info on the cheaper sleeves. Hope I can get them sent out tomorrow to wrap this up & start driving her soon.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
03-17-2009, 12:48 PM | #12 |
I just put 73 spindles on mine Another difference is that the 73 outer tie rod is longer . I had to shorten the outer 3/4 of an inch to be able to get the tie rods to shorten up enough to get the toe back into alignment Tim
