06-16-2007, 08:51 PM | #1 |
Help with rear axle code
Rear axle code on right passenger side says RHA W330 1; what is the rear axle ratio for this code???
1969 C10 Long Wheel Base 1985 Monte Carlo SS(Snake Charmer) |
06-17-2007, 11:00 AM | #2 |
Member #1049
Re: Help with rear axle code
that is a 1972 3:07 ratio..
Here is a link.. srcoll down to axle codes and click on year http://www.americanclassic.com/paint.htm?p1=axles Last edited by Livrat; 06-17-2007 at 11:01 AM. |
07-14-2011, 08:16 AM | #3 |
I need this info but the link is dead now....arrrgh!!!!!
07-14-2011, 08:21 AM | #4 |
a code that was stamped 40years ago is not always what is inside now alot of times// a simple rear fluid change will give you a foolproof answer
07-14-2011, 08:31 AM | #5 |
True enough, I am pretty sure this is an unmolested truck though, as far as the rear axle. I plan to pull the cover soon and change gear oil but I have a lot to get done before I get around to it. I really would like to find a ratio code chart.
07-14-2011, 11:31 AM | #6 |
Member #1049
Yes that site is dead, I now have an interchange manual that lists the codes, post up your axle code and I can tell you what it originally was
07-14-2011, 12:03 PM | #7 |
Its a 70 pickup TDA. I found another post after I did a search that said it is a 3.73. Im guessing its an open (peg leg)
07-14-2011, 12:26 PM | #8 |
You are both correct, the GM parts manual says that is a 1072 3.07 (open) for CS/CE, and the same stamp was used in 1970 for a 3.73 (open). Therefore, if it is a 6-lug, it's probably the 3.73 and if it is a 5-lug it's probably a 3.07.
Good Luck!! |
07-14-2011, 12:29 PM | #9 |
It is a 6 lug, 3.73 should be nice with my overdrive. Thank you!
Posted via Mobile Device |
07-14-2011, 10:12 PM | #10 |
Member #1049
My Hollander interchange manual lists it as a 70 3:73 open.
11-03-2011, 03:16 PM | #11 |
any help with a 72 rearend stamped RHC W126 1 Thanks in advance...
11-03-2011, 03:29 PM | #12 |
[QUOTE= a simple rear fluid change will give you a foolproof answer[/QUOTE]
Please explain, what would one look for? |
11-03-2011, 03:33 PM | #13 |
Book says 1972 3.73 open (non-posi).
11-03-2011, 03:36 PM | #14 |
Florida Edition
Here is what was stamped on mine...
It's a 3:07 Posi now
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-03-2011, 03:53 PM | #15 |
04-08-2012, 01:10 PM | #16 |
Need a bit of help, have a 1970 C-10 that I have reason to believe was swapped to a 71 Frame, dash sheet says automatic & had to cut a bellhousing crossmember out that was riveted in, disc brakes, and rear lug studs for a 70 didn't fit but 71's did, as well as a 71 type grill, & am noticing looseness in the rear end, anyway it is 5 lug with coils and the number on pumpkin is 3896838 and code on tube is RHA W143 1
09-01-2012, 09:37 PM | #17 |
Bump. I have a 72 with rha code. Hoping someone has a definitive source.
09-01-2012, 10:08 PM | #18 |
Member #1049
RHA= 1972, 3:07 ratio (Source: Hollander interchange manual)
09-01-2012, 10:11 PM | #19 |
09-02-2012, 02:53 AM | #20 |
RHA, '72 CS/CE10 3.07:1 Chevrolet Parts Manual
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
09-28-2012, 02:11 PM | #21 |
How about this one?
RA 0208 W2 |
09-28-2012, 02:25 PM | #22 |
Both 68 and 69 used RA for the 3.07 open for a Series 10.
09-28-2012, 03:09 PM | #23 |
On the edge of the ring gear there are going to be some numbers. There will be two numbers separated by a colon (. These numbers indicate the number of teeth on the pinion and the ring gear.
For example, mine is stamped 11:41. 41 divided by 11 equals 3.7272, so it's a 3.71:1 gear ration |
09-28-2012, 10:22 PM | #24 |
C10/G10 1968 or 69 open 3.07:1 ratio, February 8th, Warren Plant, 2nd shift.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 09-28-2012 at 10:30 PM. |
09-28-2012, 11:48 PM | #25 |
Gmpartswiki.com will answer all your decoding questions.
70 Chevy Custom 10 400SB, Tremec TKO600, 3.73 posi. LWB hope to chop frame and have it short soon! 71 GMC LWB in the works of getting going for the first time since 1996 |
