09-25-2009, 11:27 PM | #51 | ||
Re: '89 3/4T 'burb front-end swap to '66 C20
I know of a few here in Ok....sorry I posted that after John's post but I guess you guys replied before I got it posted iehotrod, check craigslist. also your post is basically a WTB, which is against forum rules unless you are a supporting member, just a friendly FYI
CHEVY ONLY Last edited by joe231; 09-25-2009 at 11:29 PM. |
09-25-2009, 11:29 PM | #52 |
ok its a bit far...
09-26-2009, 09:50 AM | #53 | |
Hollister, CA.
Thanks man !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
09-26-2009, 10:31 AM | #54 |
If you asked the question. How many Johns on the site. I think that thread would be the biggest....
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-28-2010, 03:59 AM | #55 |
Great build up for your 3/4! I'm at the beginning stages of the frame clean-up. Big fan of the POR-15 as well! Nice job!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
06-03-2010, 02:10 PM | #56 |
subcribed Im in a litttle late but Im here
07-19-2011, 02:21 AM | #57 |
will the 73-87 k-memeber fir a 62?
07-19-2011, 03:25 AM | #58 |
a K crossmember? I would stick with 2WD crossmembers
1963 GMC Wideside powered by a LH2 32v Northstar |
07-19-2011, 03:27 AM | #59 |
what do you mean by "K" member(K stands for 4x4). if you are asking whether or not that a 73-87 frt axle fits in place of the 62 axle you would have to measure as unfamiliar with the spring spacing and the axle perches. the later (73-87) does fit in place on the 64-66 frt axle. spring perches have to be moved a little on the rear axle 64-66
ron |
07-19-2011, 04:13 PM | #60 |
60-66 Nut
I believe the 'K member' that iehotrod is referring to is a common term used for the front suspension crossmember on a vehicle.
To answer your question iehotrod, yes the '73-'87 'K member' will work on a '60-'62 frame. It is a little more work than on the '63-66's as there are more holes that need to be drilled. I know there are a thread or two on here that give more insight.
07-19-2011, 04:53 PM | #61 | |
07-19-2011, 05:06 PM | #62 |
Hilander you are the reason I tore into my truck, I read your thread and said well I can do that, it only took you 3 days and I am now on 10 months, but we are close to completely frame off---ing my 66 1/2 ton gmc. Thanks for the inspiration. Kieth
It started out looking like this: http://kieth.smugmug.com/Trucks/66-G...67555158_RNLWE Got stripped down to this: http://kieth.smugmug.com/Trucks/66-G...38809030_eUypo Put back together starting here, using a 91 burb 2wd chasis: http://kieth.smugmug.com/Trucks/66-G...05_PwoKs-X2-LB And right now it looks like this: http://kieth.smugmug.com/Trucks/66-G...847715_ctDzSfp All due to your inspiration-------thanks, what am I saying should I thank you for all this pain, loss of play time, money, busted knuckles ? Maybe I take that all back----------------ha ha thanks again, Kieth It should be running in a couple of weeks..... |
07-23-2011, 05:34 PM | #63 |
well, you're welcome I guess...
Johnny and I were trying to give a good "how-to" documentation of the front end swap. Given the response this thread has received over the years, I think we were successful. Keep in mind my brother that my 66 is no where near the state of completion yours is! Nice truck!!! In fact it's pretty much in the same state it was at the end of the front end swap! Now I have to move to Bakersfield and the restoration is once again put on hold. BUT..... I will have the means to finish it when I get settled in at Bakersfield since I will be making a lot more money, and spending a LOT less on rent, utilities, groceries, commuting, etc.. also there are many more resources for parts and donor trucks where I'm going than where I live now. I must say though, that I will miss my good friend and truck partner John terribly when I go. We have had a lot of good times together working on our trucks and trolling through junk yards.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
11-04-2012, 12:14 AM | #64 |
you guys did a great job with the pictures and documentation, i am just about to do the same but on my 64 1 ton.
you know when you said how its funny how life deals you the cards, like you comming back from that med. issue, and now you just dont want to stop moving, i hear you , after i lost around 225lbs i just hate sitting around. i know this is an older post but hope all is good with you. Henry.
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
01-21-2013, 06:33 PM | #65 |
This is just the information I was looking for!!! Geez, I love this forum. I have been looking for the answer if I can just swap a C20 crossmember and all just like a C10 crossmember and here it is complete with pictures.
I know this is an old thread as well, but I hope all is well with you still, healthwise and on a personal level. Side note, I used to be stationed out at Fort Irwin and have been through Bakersfield a time or two. Desert life wasn't for me, but it does have its own beauty and it sure is nice for having wide open spaces and awesome sunsets/temps at night. |
01-21-2013, 07:15 PM | #66 |
Still a great write up 3 plus years later.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
01-21-2013, 07:18 PM | #67 | |
i just got done with mine last week, and this thread was also what i used to make the decision to do it, yes pictures are good, i'm not sure if the guys who posted the original thread are still around here , i have sent pm's but have not gotten a reply as of yet.
01-22-2013, 11:13 AM | #68 | |
01-22-2013, 01:32 PM | #69 | |
well you guys did a great job, and i'm glad he is doing well as i hope you are also.
thanks John. Quote:
01-23-2013, 02:32 AM | #70 |
I like working on these old trucks.
01-23-2013, 08:09 AM | #71 |
i think most of us do, it's funny i was talking to my brother and he has just abandoned this hobby, said he does not like to play with cars anymore, i find that to be sad ! he is even selling his car
i dont understand him but hey his life his choice.
02-16-2013, 12:48 AM | #72 |
Hidey-Ho Chevy brothers! just checkin' in on this old thread!
Me & Johnny had a blast putting my '66 together that week. I remember the harrowing test drive after - sheesh what a ride! The clamp on the rag joint was stripped and the steering wheel was, uh shall we say, "less than responsive"! We had just as much fun a few months later scrapping out his '81 C10! My health is holding and I'm just getting ready to start back in on my truck. The truck is running great today. I still drive it to work now & again. We hauled our 26 ft Airstream camping trailer down 300 miles from Vacaville to Bakersfield when we moved. We had a few problems with the trailer, but the truck ran like a charm!
02-16-2013, 01:22 AM | #73 |
Im getting closer to tearing into the 3/4 ton and getting that rear diff to you.
02-16-2013, 02:24 AM | #74 | |
ron |
02-16-2013, 12:10 PM | #75 | |
