Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-09-2011, 12:23 PM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Double flaring tool: Finally got what I paid for with Harbor Freight
WHAT A PIECE OF CRAP!!!!!!!!!
I have had outstanding luck with HF tools and I think it's because I know what to and what NOT to buy from them. My cheapy air tools just keep working and working and working!!!!
Now let's talk about the $16 double flaring tool I bought to make my new brake lines for the 9" in my Camaro. I could have and should have done a better job with a ball peen hammer and a tube of chapstick! Maybe it flairs the bigger stuff okay but who cares if it's 3/16th line I'm working on!
Enough of that. I see that sears and Home depot both carry the "general tool" kit in the $50 price range. Anyone used this? Is there a decent one out there in the $50 range? Can't justify spending $150+ for something I won't use very much at all.
Thanks guys!
P.S. I notice that I end almost every sentence with an exclamation point!
prostreetC-10 is offline   Reply With Quote
Old 08-09-2011, 12:57 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Double flaring tool: Finally got what I paid for with Harbor Freight
I've heard that the Napa flaring tool set is a good one. I'm not sure if they sell different brands or if there's only one but I'd check them out also.
68gmsee is offline   Reply With Quote
Old 08-09-2011, 01:10 PM   #3
Southcity
Southcity's Avatar
Hey ProstreetC-10 - I feel your pain, I just finished a brake and fuel line project. Went through two double flaring tools (Jegs and Local parts store) and they both failed me in a big way. I ended up with the double flaring tool from Craftsmen that I purchased at Sears and it worked flawlessly, was about $50.00 and well worth it.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 08-09-2011, 01:51 PM   #4
hlp-3
The Ridgid no 345 is the best and it is available for under $50 online. If you need the double lap mandrels it will go over your $50 budget. Hopefully you can re-use the ones from the HF flaring tool. I have done numerous brake lines with this tool - all absolutely perfect. Really holds the tubing well.
________________
2007 Trailblazer SS
1996 Corvette (sold)
1987 Silverado LWB (R20)
1985 Silverado SWB (C10)
1973 Nova SS
1965 Chevy C-10 SWB (sold)
hlp-3 is offline   Reply With Quote
Old 08-09-2011, 02:01 PM   #5
prostreetC-10
My Carbon Footprint
You mean Sears as in the Sears that is just down the road from my house?? Sweet!
I actually think that is the problem. The clamp and the other part work just fine. I believe the problem is in poor machining in the flaring adapters. They look like they were machined with a Dremmel and a blindfold!
Old 08-09-2011, 02:09 PM   #6
Southcity
Southcity's Avatar
"You mean Sears as in the Sears that is just down the road from my house?? Sweet!"
Yes sir, good ole Sears and Craftsmen, held the tubing well, double flared my ends perfectly over and over again, have lent it to some friends and they report excellent results as well. I've never tried the Rigid #345 that HLP-3 suggests but it looks like a quality tool and comes highly recommended.
Old 08-09-2011, 02:16 PM   #7
Shane
Shane's Avatar
you will need to buy used to stay under the $50 budget, but there is no better flaring tool than an Imperial
http://shop.ebay.com/i.html?_from=R4...All-Categories
Shane is offline   Reply With Quote
Old 08-09-2011, 02:27 PM   #8
hlp-3
While Imperial is also a very product, I think the two wing nut design of most flare tools is poor. In my opinion the hinge design and the clamp right over the tube makes all the difference. (No I do not work for Ridgid) I was actually in the same boat as prostreetC-10 and bought a new one (the Ridgid 345) at Home Depot for like $30, but that was probably 10 years ago.
________________
2007 Trailblazer SS
1973 Nova SS
Old 08-09-2011, 02:46 PM   #9
prostreetC-10
My Carbon Footprint
Okay guys....I am an absolute complete moron. Started looking at the Imperial stuff and their directions. It appears that double flaring is a 2 step process and I was only completing the first step. Got my practice line back out and did BOTH steps this time. You know what....the little tool works pretty good. I'm still going to look for a better quality one but at least I know it's a 2 step process to success. Thanks Shane for getting my brain working again.
Old 08-09-2011, 06:49 PM   #10
bighaas79
Lol! hence the name DOUBLE flare! 2 steps. ehh gotta learn somehow.
bighaas79 is offline   Reply With Quote
Old 08-09-2011, 06:56 PM   #11
ERASER5
ERASER5's Avatar
Prostreet, I'll jump in. Go to Auto Zone and get their Nickel/Copper alloy line. A HUGE part of your problems will be solved. This stuff bends like butter and does not rust.
DO NOT try to double flare stainless steel. That requires expensive equipment.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-09-2011, 09:19 PM   #12
Shane
Shane's Avatar
folks who work with connectors and flared tubing for a living use Imperial flare tools ... I know this from experience.
Old 08-10-2011, 02:08 PM   #13
hayhauler71
hayhauler71's Avatar
If you look at a snap on or mac there are also made by Imperial Eastman
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 08-11-2011, 11:38 PM   #14
cableguy0
I would let you use my mastercool hydraulic set but I would need you to send me at least 2 good working carbs for collateral. Plus your a tad far away.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-12-2011, 11:05 PM   #15
bighaas79
I've got the mastercool as well. by far the best i have ever used.
Old 08-20-2011, 07:52 AM   #16
68C15
blood type; Retumbo
68C15's Avatar
same here. did you get it with the push connect adapters?
I have dinked around with manual flaring for 20+ years and finally decided it was time to get serious. and with the way brake lines rust in my area it gets used quite often.
for bending lines though I have the Imperial ones.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-20-2011, 01:22 PM   #17
bighaas79
Yup. I also got all the 37* dies to do an fiitings as well. I have used the push connect fittings a couple of times but the tube like to get stuck in the die. if you grease up the tubing before you form it it seems to help.
