10-10-2011, 01:28 PM | #2 |
Re: body mt - rocker panel,what is it called?
Sounds like the floor support. Where is it located? Front or back? Driver or passenger? If you take a flap disc to it you will find the spot welds the factory used to install it. You could drill those out and replace with a new pc. If it's not totally rotten, you could cut away rot and patch with new metal that way also. I had a couple on my truck that were bad and did both. I can tell ya from experience, I wish I had replaced the whole thing.
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
