Old 09-23-2009, 05:51 PM   #1
psychobilly451
edelbrock inline 6 manifold?
I saw an edelbrock aluminum intake for an inline 6 cylinder. how do I find out more info? anyone know the model number of this intake?
1967 K20 Stepside Longbed 250-6 sm420
psychobilly451 is offline   Reply With Quote
Old 09-23-2009, 06:36 PM   #2
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: edelbrock inline 6 manifold?
www.stovebolt.com/
Might be a good place to start.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-23-2009, 10:56 PM   #3
Jimmy S.
You are looking for Edelbrock SP2P intake. I had one,I sold it,so I could buy a Offy 4 barrel intake.
The intake was designed to use a single,one barrel carb.
Jimmy
Jimmy S. is offline   Reply With Quote
Old 09-24-2009, 05:50 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I may be wrong, but I'd guess it fits the older 235, 261 L6s, not the "late" 230, 250, 292s that started with the '63 model year.
Old 09-24-2009, 10:16 AM   #5
68gmsee
Active Member
68gmsee's Avatar
I don't believe Edelbrock makes them anymore but they may make them for other companies. I did a search some years ago and the only two that I was able to come up with was the Offenhuser (Landon Stovebolt) and the one sold by Clifford Performance.
68gmsee is offline   Reply With Quote
Old 09-24-2009, 05:08 PM   #6
psychobilly451
Jimmy
so it only accepts a one barrel carb, nothing else?
Old 09-24-2009, 07:44 PM   #7
Jimmy S.
The intake was designed as a direct replacement for the stock intake.
The edelbrock intake used a Single, one barrel carb.
The intake was desiged to be used on 194,230,250 292 engines.
The edelbrock intake was not designed to be a performance intake.
It was designed for better fuel mileage.
Jimmy
Old 09-26-2009, 05:26 AM   #8
'68OrangeSunshine
Jimmy
OK. I'm always happy to learn something new.
Old 02-12-2011, 03:16 PM   #9
truckfan
truckfan's Avatar
i have one on a 1957 235 in my 1951 Chevy Fleetline. it has two Rochester one-barrels that run at the same time. it's finned and aluminum. i bought it in the 80's and have never seen another one. i'll try to upload a picture.
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 02-13-2011, 08:24 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
What Jimmy is talking about is true. The SP2P series of intakes were not high performance by any means. I actually got into collecting SP2P intakes a few years ago for some reason.
During the 70s, and the gas crunch, Edelbrock decided to market a full line of intakes aimed strictly at gas mileage improvements. Folks were trading their American cars in on Toyota and Datsuns because of the oil shortage. Edelbrock hoped to capitalize on this by offering increased economy. The SP2Ps were available for a lot of different engines, including the 194-292 series of inline 6 GM engines. I've also had them for SBC, BBC, small block Ford, and AMC engines. They really aren't worth anything so I just hang them up for shop wall bling.
It's a neat little piece of history.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-13-2011, 05:01 PM   #11
el_bole
Decided to just keep the Orig. 235 in my 61'. Consider going with an intake to put two single barrel carbs on it. What are the Pros and Cons of going with this set up? My dad says I'd blow the motor with two carbs on....What do y'all think?
el_bole is offline   Reply With Quote
Old 02-13-2011, 06:30 PM   #12
72chevyk10
I built it
72chevyk10's Avatar
ive never heard of a engine blowing up from multiple carbs.. especially a straight 6, they're pretty much indestructible
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 10-13-2011, 11:34 AM   #13
Chevy Iron
Chevy Iron's Avatar
Have one similar to this, can you tell me why they are water heated?
Chevy Iron
Fully customized 1968 C-10 Stovebolt 292, T-5 trans 3:73 posi
Wife says it's a "midlife crisis".....I'm okay with that.
Chevy Iron is offline   Reply With Quote
Old 10-13-2011, 12:21 PM   #14
Tx Firefighter
Because the intake manifold hangs off the side of the engine and doesn't get much heat from it. The intake manifold runners need to be somewhat warm to keep the fuel atomized well for decent drivability. Hence the lines to use warm coolant into the manifold.
The original manifolds didn't need this since they were married to the exhaust manifold and the heat conducted up into the intake this way. Your aftermarket aluminum manifold won't have that option.
Old 10-13-2011, 12:48 PM   #15
OJ1988
Just a car guy
OJ1988's Avatar
I had a clifford on my 6 before I ditched it for the 350.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 10-13-2011, 03:00 PM   #16
truckfan
truckfan's Avatar
i have had dual carbs on my 235 for literally 35 years. it runs great. it wont blow up.....
Old 10-13-2011, 04:01 PM   #17
68gmsee
Active Member
68gmsee's Avatar
Here's another explanation in more detail why manifold needs heating, if interested.
http://stoveboltengineco.com/index.p...take-manifold/
Old 10-17-2011, 01:20 AM   #18
'68OrangeSunshine
I won't argue that carb heat isn't a good idea with some sound theory behind it, but I've been running a 4 barrel on an Offy intake w/o carb heat on 292s for 33 years. I will admit that the truck runs better in the summer. I live in Tucson where 100*+ temperatures are normal in summer.
Old 10-17-2011, 06:10 AM   #19
D13
D13's Avatar
No heat in MI = fuel drop out, poor driveability and fuel economy. Particularly with any alcohol in the gas, it's rather settle out as a liquid then stay in the air column.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-19-2011, 05:14 PM   #20
Chevy Iron
Chevy Iron's Avatar
Thumbs up Inline 6 Manifold Heat
Went to the Link sent by 68gmsee and just as explained; my aftermarket has had a tube (nicely) welded to the bottom but then coolant lines aborted. It appears I may have found the answer to my 292's sluggishness. I will reroute the coolant lines to run through the tube and see how it goes.
Chevy Iron
Old 10-19-2011, 06:47 PM   #21
Redcap
Sounds like your dad shouldn't be dispensing any automotive advice.
Redcap is offline   Reply With Quote
