Old 09-25-2011, 02:18 AM   #1
mfd574
Today's 8 bolt versus yesteryear's 8 bolt.
Tried searching for this answer but could find it. Do the 8 bolt rims for today's Chevy 3/4 tons fit on the 67-72 Chevy 8 bolts? Thanks in advance!
mfd574 is offline   Reply With Quote
Old 09-25-2011, 12:52 PM   #2
vectorit
What?
vectorit's Avatar
Re: Today's 8 bolt versus yesteryear's 8 bolt.
The lug nut size is larger on the newer 8 luggers.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-25-2011, 01:47 PM   #3
mfd574
Sorry about the rookie question, just getting my 72 burb today. So inorder to put different rims on it I will have to find rims specifically made for this year of 8 bolt, correct? Any newer year 8 bolt will not fit?
Old 09-25-2011, 02:09 PM   #4
vectorit
What?
vectorit's Avatar
The only thing I know to be different is the lug nuts on the newer 8 luggers are of a larger diameter, so they will fit the bolt pattern on the old axles but you will as far as I can tell would need to upgrade the lugs on each hub to the larger size.
Someone who has had direct experience with this will chime in sooner or later.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-25-2011, 02:14 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Newer year 8 lug wheels will fit. The lugnuts are what is different. I know a lot of members run the newer wheels on their C-20's... some have bought the correct lugnuts from E-bay. As stated above, someone will chime in with the lugnuts you will need to pick up. I think the size of the lugnuts are the same....I think the difference is in the way they seat (not 100% sure though)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-26-2011, 11:34 AM   #6
CMACDONALD1
CMACDONALD1's Avatar
I believe as mentioned the lug nuts are different. The reason you need the new style lug nuts is because the center caps are attached to the new style lug nuts. I'm not sure where you would find these new lug nuts but I would start with a tire shop and go from there if it was me.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts.
1972 Cheyenne Short Bed
1958 Apache short fleet
1980 Chevy short bed
http://67-72chevytrucks.com/vboard/s...d.php?t=761005
1959 "Henry"
http://67-72chevytrucks.com/vboard/s...d.php?t=670461
1966 Biscayne
http://67-72chevytrucks.com/vboard/s...d.php?t=444419
1972 Suburban
http://67-72chevytrucks.com/vboard/s...d.php?t=478828
CMACDONALD1 is offline   Reply With Quote
Old 09-26-2011, 04:48 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I ran some on my 3/4 ton I sold. You can get lug nuts from lugnut king on ebay.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-26-2011, 05:19 PM   #8
mfd574
So is it just the lugut that needs to be changed or is it the actual bolt? Also how do you get rims to fit good on the back with such a big hub? Do you need to get some sort of a spacer to get the rim to fit out far enough to get a center cap on? Thanks again guys!
Old 09-26-2011, 09:53 PM   #9
zellway
zellway's Avatar
Just a Idea. I put 2008 Dodge wheels on my 1967 3/4 ton with no problems. The rear axel in my truck is from a 72 and the studs were bigger so I could use the lugs off the dodge. When i put the disk brakes on the from the rest will fit. I like the look of them.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 09-27-2011, 10:17 PM   #10
Burb 71
Burb 71's Avatar
I put a basic aftermarket set of wheels on mine. I went to the tire shop locally and ordered the "narrow shank?". They go one with the special lug tool. I had no issue with these. I had the basic open style acorns prior to that and they worked well too. You can run a spacer to bring out the rear if you'd like. I haven't yet but will in the future when I find the set one wheels I like. I also bought a basic center cap from the tire shop as well. I went with the large one on the front and back so it looked the same.[IMG]IMG_20110721_103629[/IMG]
Burb 71 is offline   Reply With Quote
Old 09-27-2011, 10:17 PM   #11
Burb 71
Burb 71's Avatar
Sorry was trying to post a pic but it won't let me attach it
Old 09-27-2011, 10:28 PM   #12
Burb 71
Burb 71's Avatar
Added it as my profile pic if you want to check it out sorry I couldn't get it on here
Old 09-28-2011, 01:12 AM   #13
mfd574
I think I will be doing what Burb 71 did. Checked with a local shop today and the old guy working new exactly what would and would not work, he didn't have to look at the burb he just new. Think we will do a polished mod rim for the time being. Thanks for everything guys!
Old 09-28-2011, 02:12 AM   #14
mcmlxix
Collector of Projects
mcmlxix's Avatar
I just test fit some Hummer H2 wheels. The bolt pattern is 8 x 6.5 (same as the Dodge wheels above). The wheel studs were 9/16 and the aluminum wheels need a 60 degree conical seat.
Rich
1972 K5 Blazer CST Click HERE
Old 09-30-2011, 03:44 PM   #15
justcuz
justcuz's Avatar
The big reason for changing lug nuts on newer wheels are that the old trucks have SAE threads on them, newer trucks have metric lug nuts. If you want to use the original center cap that came with the newer wheel you can buy specialised lug nuts from different vendors as mentioned above.
I am actually going to use Ford F-350 Alcoa aluminum wheels on my 72 with Chevy center caps from a set of steel wheels.
justcuz is offline   Reply With Quote
Old 11-03-2011, 09:06 PM   #16
hdman6465
hdman6465's Avatar
Sorry for the delayed reply, but I am new to this site. The lug nuts can be had from a number of sources, such as lugnut king. Have run these for several years, never ceases to amaze me that people still ask what kind of wheels they are!
hdman6465 is offline   Reply With Quote
Old 11-05-2011, 10:53 PM   #17
jeffg1010
jeffg1010's Avatar
Man, that is one sweet Burb! I had those same wheels on mine and it looked terrible. But they definitely look good on a lowered Burb.
In fact, I just stuck those rims and tires on CL.
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 11-05-2011, 11:07 PM   #18
jeffg1010
jeffg1010's Avatar
I had to dig deep, but I knew I could find an old pic of it.
Jeff
