#51 |
Re: crew cab short bed build " clifford"
These pics are not very good but here ya go. I will plate the inside after i final weld. I need to bring the bed home before i cut the rear. I guesse the 1 ton rear frames are diffrent than a 1/2 ton? If i cut 6 inches off the rear my bumper will have to have holes cut through the rear hangers? Someone know if this is right?
#52 |
rear of frame
#53 |
![]() Join Date: Aug 2002
Are you going to box or fish plate the frame??
#54 |
#55 |
Part of me would like to weld it up and dress it out so its not visible but I know it needs more strength. I will box mine and clean it up nice. It could also have a fish plate behind it. I just want a clean look. I know frames flex some, Just don't want cracks.....
#56 |
These are some plates I have made for boxing in the frame.....
#57 |
Following along!
#58 |
#59 |
Yes.. and a few inches on each side... Open to all suggestions....lol
#60 |
Bed ready for first prime. Just need to get right fender in and fitted.
#61 |
Cant wait to see how this turns out, I have a cclb dually that I am wanting to cut down to a swb. Not sure if I would want to make it a dually or just go single wheel.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#62 |
What are your plans for the suspension. Lowering it, or stock ride height?
Posted via Mobile Device |
#63 | |
Keep it a dually, the ones i have seen are sweet!! Last edited by rs72z; 11-15-2011 at 06:01 PM. |
#64 |
I plan on lowering it. Looking at hangers and shackles for the rear and 3" spindles for the front. I want it to be low enough to look good but not so low that it's not functional. Bags are not in the budget, i don't think that i have mentioned that this is a budget build.
#65 | |
6>8 Plugless........
![]() Join Date: Sep 2007
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#66 |
I measured back 7 inches from from the rear cab mount, that put me about a inch behind the front bed bolt hole.
#67 |
Did you just go 7" back from the rear edge of the cab mount, or 7" from center? (I'm reading it like 7" from the rear edge of the cab mount but just want to be sure) Thanks for the help. I'm going to try to cut mine down soon.
#68 |
Yes rear edge.
#69 |
Thanks!
#70 |
No problem.
Plans are to take the truck to work this weekend to shoot the firewall so i can get started getting the engine and trans in. I will set the bed on while it's there so i can figure out how much needs to come off of the rear of the frame. I will post up after i figure it out. |
#71 |
Don't forget the pictures!! This is exactly what I plan on doing to mine. Shortbed, 5.3, 4l60, and a 6/8 drop. So I'm watching this build close......
#72 |
#73 |
Definately keeping it dually. I havent decided on wheels yet. Probly just stock 16's. Semis are not really in the budget. Plus I don't know if I wanna mess with the adapters and all the added weight.
#74 |
#75 | |
