Old 12-06-2011, 04:51 PM   #76
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How about some pics of Static Dropped C-10's
Originally Posted by kieth View Post
Mines a hybrid, trailing arms with bags in the rear, 6 cylinder coils in front with -2.5" spindles......17" wheels....
Attachment 835538
Noich!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-11-2011, 08:26 PM   #77
gearys 5600
gearys 5600's Avatar
Here is my 5-7 dropped 69 custom/10.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 12-11-2011, 11:47 PM   #78
69vetteside
69vetteside's Avatar
Thumbs up Re: How about some pics of Static Dropped C-10's
THAT is nice
69vetteside is offline   Reply With Quote
Old 12-17-2011, 08:56 PM   #79
Jarwood
Jarwood's Avatar
Advice please...I lowered my front end by cutting one round off the coil. Front looks good. It sits at 29'' to center of fender. I bought blocks (1.5") for the rear but have not put them in. I kinda like the stance, but the driver side is 31'' to from floor to center of fender and the passenger side is right at 32 ". How do get this to even out? The bed looks straight across the back of the cab..
Jarwood is offline   Reply With Quote
Old 12-17-2011, 09:02 PM   #80
Jarwood
Jarwood's Avatar
more pics
Old 12-17-2011, 09:07 PM   #81
Jarwood
Jarwood's Avatar
more pics
Old 12-17-2011, 09:08 PM   #82
lolife99
67-72 parts collector,…
lolife99's Avatar
Got any better pics of your inner tie rods.
Looks like something is assembled wrong.
I just can't tell.
Keith
Convert to disc brakes.
Old 12-17-2011, 09:16 PM   #83
Jarwood
Jarwood's Avatar
not from that angle but have these.
Old 12-17-2011, 09:18 PM   #84
lolife99
lolife99's Avatar
Looks ok from that angle.
Have you driven your truck since you lowered the front?
It may just need to settle or the spring may not be exactly in place on the high side.
Was it level before you cut it?
Keith
Old 12-17-2011, 09:20 PM   #85
Jarwood
Jarwood's Avatar
what can I do to get the passenger side rear down 1 inch?
Old 12-17-2011, 09:20 PM   #86
Jarwood
Jarwood's Avatar
I have driven the truck about 25 miles since cutting the coils
Old 12-17-2011, 09:22 PM   #87
Jarwood
Jarwood's Avatar
This was the ride height before cutting the coils.
Old 12-17-2011, 10:04 PM   #88
67swb72klb
67swb72klb's Avatar
old 6 cyl springs 3/4 of a coil cut on front 3" drop rear
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-18-2011, 09:45 AM   #89
CC69Rat
CC69Rat's Avatar
Jarwood - check the coil spring on the high side. Did you position (what I call index) the coil back into the lower a arm correctly? There is a possibility if the last turn on the bottom of the coil is just sitting in that pocket incorrectly, in could cause your leaning situation. Its easy to get that spring in there after its cut but there is a certain way it needs to sit in there.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-18-2011, 01:51 PM   #90
Jarwood
Jarwood's Avatar
I double checked and it looks to be sitting in the correct place. The front of the truck is dead even at 29". The rear is the problem and I have not touched the rear, however it always set uneven in the back. I have lower blocks but do not want to use them until I level the rear of perfect. I was just wonder if there is something I can do to level it out before lowering the rear??
Old 12-18-2011, 01:57 PM   #91
lolife99
lolife99's Avatar
I would remove the rear springs.
They are either sagging originals or torched originals.
(got any pics of them?)
Either way,... It would be a good time to install new springs.
I bet stock rear springs would raise the back of your truck WAY up.
Lowering blocks are a cheap way to lower the back.
Or a way to get your truck lower than 6" of drop.
I would install the spring you want first.
Check with www.performanceonline.com for drop rear springs and related components.
They have a sale going on now also.
Keith
Old 12-18-2011, 02:54 PM   #92
CC69Rat
CC69Rat's Avatar
Good time for some drop coils in the rear?
Chad
Old 12-18-2011, 07:28 PM   #93
Jarwood
Jarwood's Avatar
So do you think the springs are original? What size springs (drop) in the rear should I buy to match the front? I like the front at 29 inches for now. Maybe in the future I will put bags on...of course its all about money.
Old 12-19-2011, 02:50 PM   #94
Jarwood
Jarwood's Avatar
What would the cost be to put in air bags in the rear??? Maybe just the bags and adjust them to the height I like. Any suggestions on where to buy them? Also I am guessing a schrader valve is to fill the bag up at desired height and the valve keeps the bag at that height??
Old 12-20-2011, 09:40 AM   #95
Racie
Here's my 5-7 drop...
Racie is offline   Reply With Quote
Old 12-20-2011, 09:54 AM   #96
shawno72
C/10 junkie
shawno72's Avatar
that's nice. What size wheels and tires are you running.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-20-2011, 10:55 AM   #97
Racie
20x10 rears with 295/40's and 18x8 front can't remember my front tire size for some reason...
Old 12-20-2011, 07:55 PM   #98
Stickman
Stickman's Avatar
Re: static drop pics
It's just right.Did you get it painted or just a serious buff job? Looks great.
Stickman is offline   Reply With Quote
Old 12-21-2011, 12:39 AM   #99
zac78130
my 79 3" spindle 2" spring in front, self made flip and frame reconstruction in rear, saving for bags, also pic of good friends 84 dually with self made (9"total rear drop) flip kit,
zac78130 is offline   Reply With Quote
Old 12-24-2011, 01:17 PM   #100
68_chop_top
68_chop_top's Avatar
4/6 DROP. 2"lowering spindles and 2"lowering springs. 4"lowering springs with 2"drop blocks.
Riding on 17" TT and Goodyear Eagles. Dropped and Chopped!
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
