Old 01-22-2012, 03:15 PM   #1
Ranger6202
lq4 6.0 swap into '85 Crew Cab Shorrbed
I actually started this project at the beginning of this month, so i've got quite a bit of progress into it already. I'm putting a 2005 6.0 in my Crew cab that had a 350. I'll be keeping the turbo 400 for now and will eventually put a 4l80e behind her later in the year. I just barely bought this crew cab back in August for $3k as my designated hunting truck. The 350 and turbo 400 was supposedly built 38k ago. I guess the truck originally had a diesel in it, but whoever swapped the 350 did a pretty good job. And to be honest, the 350 ran great, but i've been obsessed with these LS's since my recent Ford to Chevy conversion 2 years ago (bought an '06 Vmax).
after i added bushwacker flares, replaced rear chrome bumper
the designated 6.0....unfortunately no harness or ecm
Ranger6202 is offline   Reply With Quote
Old 01-22-2012, 05:28 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: lq4 6.0 swap into '85 Crew Cab Shorrbed
my 6.0 had the harness all hacked up, I talked to jon@ psi performance, he's going to send me a new harness ($525) and a reflashed pcm. ($200)
mooseknuckles is offline   Reply With Quote
Old 01-22-2012, 05:58 PM   #3
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Looks like a clean 6.0. I'm sure someone on here has an extra harness and computer. Looks like your setup is Drive by wire. Did you get the gas pedal to go with it?
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 01-22-2012, 08:41 PM   #4
Ranger6202
Sorry guys, i didn't explain. I have a harness now. I bought one on ebay for $200 a month ago and already have it hacked up and about installed. I still have all the pictures of my progress to post. All i have left is to get an ecm and the tune to go with it.
Old 01-22-2012, 08:43 PM   #5
Ranger6202
I do have a pedal and Tac that i paid $125 for. The only thing i'm a tad worried about is that i think it was for a slightly different year and a 5.3. I've been told you want the TAC and pedal to be compatible with the throttle body. I wish they had a list with compatible S/N's for both TB's and TAC/pedal combo's.
Old 01-22-2012, 08:47 PM   #6
Ranger6202
Here she is when i first bought her in August
Old 01-22-2012, 09:06 PM   #7
HavinSomeFun
I have an extra ECM from a 2003 5.3 and the guy that did mine charges $75 to flas them I think. Not sure what the computers are worth...
Old 01-22-2012, 09:09 PM   #8
Ranger6202
i do have a slight hang up you guys might be able to help me with. I bought the adapter bung for the passenger side head, and have already installed it, i belive its a 12mmx1.5? Anyhow, i need a 1/8 npt temp sender for the stock gauge in my truck. I'm definitely not sure if i need the full sweep, or short sweep. I do know that it needs to be the shallow temp sender (doesn't have the 1/4" unthreaded end) in order to fit in the bung. I found the autometer 2254, but it doesn't specify if its the shallow one or the long one.
Old 01-22-2012, 09:10 PM   #9
Ranger6202
Does that ECM have the blue and green or the blue and red labeled sockets?
Old 01-22-2012, 09:15 PM   #10
HavinSomeFun
I'll have to go look....
Old 01-22-2012, 09:18 PM   #11
HavinSomeFun
Blue/Red
Old 01-23-2012, 12:10 AM   #12
Ranger6202
From what I just read in one of my swap books I need the green blue ecm to be compatible with the year of pedal and tac I have
Old 01-23-2012, 04:51 PM   #13
Ranger6202
front clip detatched
front clip removed
350 removed
Old 01-23-2012, 07:06 PM   #14
noonzor
sweet, this is gonna be a fun ride with that new lq4! cant wait to see more!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 01-23-2012, 07:50 PM   #15
Ranger6202
got the 350 hangin', the 6.0 at the bottom of the pic, and a 5.3 i got for $200to the right of the pic
the stock motor mounts with the triangle dimples ground down
the stock motor mounts bolted to the adapter plate (has holes for 1" foward, stock, or 1" back)
Old 01-23-2012, 08:09 PM   #16
mooseknuckles
looks good in there.
Old 01-26-2012, 12:52 AM   #17
Ranger6202
What service # is the ecm you have and how much would you want?
Old 01-26-2012, 01:04 AM   #18
Ranger6202
Old 01-26-2012, 01:11 AM   #19
Ranger6202
Got my fuse box today. Its made by blue sea systems, and cost me about $50.
Old 01-28-2012, 01:43 PM   #20
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-28-2012, 05:34 PM   #21
noonzor
nice
Old 01-30-2012, 10:19 PM   #22
Ranger6202
I've been going crazy trying to find some decent price exhaust manifolds for about a month now. In my research i found that the F-body manifolds would be the best bet to fit, but no guarantees. So after looking for the past week for some, i finally had a set turn up on ebay. I bid on them and then decided it would be wise to sell a few of my truck manifolds that i had in my parts box. As i got pulling them out, it turns out, i have had some f-body manifolds all along. I remembered i had got off a blown up motor a friend gave before he moved last summer. I just bolted 'em up on my '85 and they fit perfect....tons of room. If you need any measurements off these manifolds let me know. The SN's are: 12611640 and 12611641. I google'd them and it looks like they're about $83-$100 a piece.
I had originally started notching the passenger side frame for the truck manifolds but then stopped when i realized the driver's side was gonna be a lot worse to pipe up due to it sticking outward instead of rear-of-truck-ward. Driver's side frame is not notched in these pics (stock)
Old 01-30-2012, 10:22 PM   #23
Ranger6202
Here's the clearance issues with the stock truck manifolds.
passenger side
driver's side, its resting right against the frame. I'm positive it would consistently hit every time you revved the motor.
driver's side underneath where it fits into the frame rail. Its turned sharp enough towards the frame that you could pipe it up, but it'd be a pain and kinda ugly.
Old 01-30-2012, 10:34 PM   #24
Ranger6202
The other hang up i've had was trying to get my temp sender installation figured out. I initially bought the autometer adapter for a 1/8 temp sender i had sitting around, but the snout on the temp sender was too big to fit into the adapter. Not to mention, i don't even think the temp sender itself had the right ohms ratio to match my stock gauges. But i did try to drill out the inside of the autometer adapter and actually got the temp sender to fit. Problem is though, when i installed it and snugged it down, it broke the adapter threads off at the collar and so i had to use an easy out to back the brass threads out of the hole. I thought of buying the S&P adapter to fit my 1/2" stock sender, first they're spendy and second they're so freakin' long it looks ugly sticking out not to mention i was a lil worried about clearance with the A/C box. So i found where people have been Milling the stock 1/2" senders down and Dying them to 12mmx1.5. Turns out i have a friend at our church that machine's for a hobby. So I had him turn it down and dyed it for me and it fits like it belongs there. I HIGHLY recommend this approach. Looks good and is very easy to have done.
Old 01-30-2012, 11:24 PM   #25
gringoloco
A guy with a truck
gringoloco's Avatar
What year F-body? They look like newer Camaro or G8 manifolds. The fit is nice
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
1985, 6.0, crew cab, lq4, swap
