Old 02-04-2012, 06:21 PM   #51
LakeAnna
LakeAnna's Avatar
Re: 72 Not sure what to call it yet resto!
I've never used anything other than the k36 because my dad started using it years ago... I'm still learning here but it sands a little harder than some of the cheap stuff. I can't remember the number of the sealer except that it's a DP something. The body shop where my friend has worked for the last 30 years are all ppg so we use what they say for the most part.
You like the epoxy?
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 02-04-2012, 06:24 PM   #52
LakeAnna
LakeAnna's Avatar
Originally Posted by fencepost View Post
I like K36 that is some great stuff. Just wondering if they had changed the receipe up any. It use to would stick to everything, over spray, which was good, but it was hard as a rock when it dryed. Very hard to sand. Still loved it for a sealer or trim out primer, good product. DP 90 black epoxy is real good too. truck's looking good.
What acid etch primer are you using?
Acid etch we use the U-tech... not sure of the numbers. We have something PPG in the cabinet also. I used U-tech on all this and we used it on the 56 last year with no issues.
Chris
72 RESTO
Old 02-04-2012, 07:43 PM   #53
VA72C10
VA72C10
VA72C10's Avatar
Everything's looking great!!! Nice progress!!!
Old 02-05-2012, 03:57 PM   #54
fencepost
fencepost's Avatar
I use to paint and body at the local Chevy dealership, 7 years total. We started out PPG then had to go to another brand for cost purposes. I really like the DP90. Ive used it for a top coat on a repaired lawnmower deck, that was over 6 years ago it is still holding up great, really good product. I use it on my sandblasted areas, but have seen others use it for a blocking primer. Use it on fiberglass too, for a sealer then over coat with a building primer for blocking. Everybody does it different. I don't use acid etch on blased areas just because a tech at one of the PPG classes said it would be to heavy of build up in the blasted pours of the metal and actually cause damage over time, he recomended epoxy blasted and bear fiberglass and acid etch sanded bear metal, so thats what I've always done. NCP250 was great blocking primer made by PPG, Im sure they've come out with some different stuff now but K36, DP90, and NCP250 were my 3 favorite ones to work with.
Ive always been curious how and what others use, you can always learn or find something new.
Great build.
fencepost is offline   Reply With Quote
Old 02-12-2012, 09:08 AM   #55
LakeAnna
LakeAnna's Avatar
Talking Re: 72 Not sure what to call it yet resto!
This truck is kicking my tail!!! Got some more done this week..
Chris
72 RESTO
Old 02-12-2012, 09:53 AM   #56
VA72C10
VA72C10
VA72C10's Avatar
Great progress!
Old 02-12-2012, 10:55 AM   #57
TXPinstriper
TXPinstriper's Avatar
Lookin good nice work !
TXPinstriper is offline   Reply With Quote
Old 02-12-2012, 06:13 PM   #58
LakeAnna
LakeAnna's Avatar
Thanks guys! Here are a few of the mess we got into on the bed... Somewhere in the last 40 years it got wacked down the side above the fender well. Rather than pull any of the dent and creased area out they just covered it with bondo... not even any fiberglass just straight bondo. I used the old school dent puller after drilling a thousand spots and got it pretty close. Welded it up and moved to the other side.
I hope maybe this coming weekend to have the body work done...
Chris
72 RESTO
Old 02-15-2012, 06:47 PM   #59
danw210
69 K20
Great progress on the truck. Just wondering why you plugged the heater box holes on the firewall, are you putting in an after market AC unit? This thread making me want to get out to the garage.
danw210 is offline   Reply With Quote
Old 02-22-2012, 09:45 AM   #60
brownge
Nice build Chris. You're moving along at a pretty fast clip. Looking forward to more pics and info.
Greg
brownge is offline   Reply With Quote
Old 02-22-2012, 08:22 PM   #61
TXPinstriper
Lookin good buddy I always liked the PPG products as well they make some great products...
Old 02-25-2012, 07:17 PM   #62
LakeAnna
LakeAnna's Avatar
Going with Vintage Air when it gets back together.
Chris
72 RESTO
Old 02-25-2012, 07:32 PM   #63
LakeAnna
LakeAnna's Avatar
Thanks for the replys fellows! Man am I tired of sanding and blocking... Will it ever end? Here are a couple shots... It's doesn't look like I have gotten anything done but really I have.
Finished priming everything today I hope for the last time... (fingers crossed)
Chris
72 RESTO
Old 02-25-2012, 07:52 PM   #64
VA72C10
VA72C10
VA72C10's Avatar
Parts look great from here! wish I was still traveling for work as I'd have been able to swing up that way to check it out...
Looks like paint is in the not too distant future???
Old 02-25-2012, 10:23 PM   #65
doubleb's69
doubleb's69's Avatar
Looking good!
Bud
doubleb's69 is offline   Reply With Quote
Old 02-26-2012, 01:47 AM   #66
RexDodge
Wow, it sure looks good. It would be great to be able to spread things out like that!
RexDodge is offline   Reply With Quote
Old 02-27-2012, 08:21 AM   #67
LakeAnna
LakeAnna's Avatar
Thanks, as you well know it's been a lot of work so far. Your welcome to stop in anytime. James helps me out every Saturday with the bodywork/paint stuff. I hope to get the paint together this week for it. If everything goes to plan I just need to 600 with the da real lightly and spray the sealer.
Soon I hope!
Originally Posted by doubleb's69 View Post
Looking good!
Thanks doubleB
Seems like there is never enough room but yeah the extra space helps a bunch. With all the sanding though it makes an extra large mess to keep up with also.
Chris
72 RESTO
Old 03-01-2012, 07:07 PM   #68
LakeAnna
LakeAnna's Avatar
I ordered the paint today!!!! Here is a pic of the truck when I brought it home... What a mess it was now that I think about it. I would have posted this to begin with but I just figured out my phone and how to email the phone pics.
Chris
72 RESTO
Old 03-01-2012, 07:14 PM   #69
VA72C10
VA72C10
VA72C10's Avatar
looked like a clean start and hasn't been as bad as some I've seen (hiding things) but you've definitely taken it from a nice truck to a Great truck already!
Old 03-06-2012, 09:28 PM   #70
LakeAnna
LakeAnna's Avatar
Well I finally got started on the paint!!! Going with the medium blue and white two tone. Here are some shots of the weekends work. We got the interior of the bed done. Underside of the hood and interior of the cab. Today I shot the top of the dash with satin black and worked on some of the little pieces. It's a work in progress...
I stuck the one wheel housing outside to see what it really looked like. The snow didn't hurt for a background. I love the color.
Chris
72 RESTO
Old 03-06-2012, 09:37 PM   #71
LakeAnna
LakeAnna's Avatar
couple more here: and the last one is my helper of course with her new "work glasses"
Chris
72 RESTO
Old 03-06-2012, 10:01 PM   #72
TXPinstriper
Very nice ! You can't go wrong with the blue & white combo. I think it looks great....Did you end up going with PPG...
Old 03-06-2012, 10:15 PM   #73
Nobby
Nobby's Avatar
Oh man that looks nice!!!Looks like your building my Dream Truck
Nobby is offline   Reply With Quote
Old 03-07-2012, 06:25 AM   #74
LakeAnna
LakeAnna's Avatar
I'm loving the colors and can't wait to see it with the new trim I just got from Brothers on it. I ended up going with CrossFire base coat and the Ultra line for the clear. I love PPG but so do they! 380.00 for a gallon of base...Not in the budget at this time. It's preped with all PPG primers but I just couldn't see throwing 1000 out for the base/clear. We used to get it from our friends shop but they've gone to the waterborne stuff so I can't get them to mix it like we used to. Crossfire has done very well for some of my fathers past projects and the finish is as good as any. I'm happy so far... after some trizact 3000 and the buffer it should be super slick.
Chris
72 RESTO
Old 03-08-2012, 06:12 PM   #75
LakeAnna
LakeAnna's Avatar
Shot the hood today and I guess it turned out decent. I had some trouble with the gun at first. It's okay though.
Chris
72 RESTO
1972 c10, 510 medium blue, cheyenne super, fastburn, lake anna
