#76 |
Re: New project
Was just talking to my brother about your truck seeing as he has a thing for Luv's. He told me yeah I think I know the truck. Told me to ask you if you know Ronnie Luv. Said he bought his last Luv truck from ya if you are who he thinks ya are.
Posted via Mobile Device |
#77 | |
mini truck racer
Re: New project
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#78 |
mini truck racer
Re: New project
Chassis dyno friday . Chromemoly going in the mopnday following .
#79 |
mini truck racer
Re: New project
New rear wheels
![]() Chassis dyno sceduled Friday @ 10 . Then Chromemolly the following monday. Here is the currents . Added some LED boat lights . Truck had a direct short im the running lights . Everytime i pulled the lights on it blew the fuse . The horn didnt work either . Dash lights had none factory lights scabbed in , so i cut all that out and fixed the factory dash lights . All connections soldered and heat shinked . Put the dash back together and installed new horn and Mikado wheel Everythong is legal except emergency brake , but it think i can still get a sticker Probably end up with a disc on the rear end yoke . I also pulled the old tach and added one of the new auto meter auto sticks . Ordered a 1 gallon fuel cell for the Nitrous fuel system . I will run race fuel in it Ready to put tunes in . A/C & heat next . Plate ,, noids and hoses going to Induction solutions coming up . Then power steering . ![]() ![]() ![]()
#80 |
Resident of Here
Re: New project
Updates?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#81 |
mini truck racer
Re: New project
Yea , I got a call the night before , apparently the computer for the chassis dyno crashed and it lost the program . They are working to get the software back . They will be down for a week or so . I tore into it this week and changed more stuff . Installed the 1 gallon fuel cell and moved the fuel pump . I am also replacing the rear cell , which is plastic , with an aluminum one . I plan on running C16 in the Nitrous cell and 93 in the main cell . A local forum im on is having a meet on the 17th so my goal is to make some shake down passes then .
I also had everything to build a 4.11 center so it is in the diff shop . I tried to set it up myself but didn't feel great about the pattern so i took it in to have it double checked . Seriously considering moving to 1350 u-joints as i currently have 1330s . Also planning on moving the new rear cell , bottle and battary all the way back to the tailgate . Anyway here are some progress pics of last weeks work . ![]() ![]()
#82 |
Mean Green
Re: New project
The 1350's is a good call.
I never broke the 1330's I had in my 4100lb truck on a T-brake. I did swap to the 1350's once I got some real tire under it. I like the C-16 cell being up front. Less work the pump has to do. I think it helps fight against the G's on the launch and the run down Broadway. Good luck on your shake downs.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
#83 | |
mini truck racer
Re: New project
I also took the -4 elbow and on the threaded side i drilled and tapped it for a Holley jet . I took the smallest brass holley carb jet i had and soldered it up then drilled a .042 hole in it . That runs through braided line back to the top of the cell . This is a return line to keep the regulator from "creeping" . I am hoping to keep the fuel pressure steady . Some say run return lines others say don't . Hope i didnt go to big on the hole i drilled .
#84 |
Mean Green
Re: New project
If any thing it might be to small. I'm sure it will work.
I ran a race pumps fuel pump and reg. I believe it had a 71 Holley jet in it. I personally like return lines. Keeps fuel psi steady and the temp cooler. Posted via Mobile Device
#85 |
mini truck racer
Re: New project
Looks like my run without bars is over . Just put $500 down for the materials , Chromemoly 12 point .
#86 |
60-66 Nut
Re: New project
Are you having someone local fab the cage?
#87 |
mini truck racer
Re: New project
QUOTE=Captainfab;5195589]Are you having someone local fab the cage?[/QUOTE]
Yes , there is a guy here in Baytown that has a chassis shop . I went in on a big tubing order with another guy , so we got a break in the price . I want to say $5.30 a ft . X 70 Ft . It will come with the documentation from the manufacterer for the chassis cert . Which will be done at the chassis shop before i pick it up . This is so the inspector can tell the chassis guy directly if there are any problems . I did Mild in the last truck and it's cheaper to do it right the first time . Plus it adds value to the truck to have Chromemoly certed cage . Looking at a 12 point with 2 swing out bars . I will post picks as im going through the build . He has to 25.2 a Nova before me as they are trying to get to the Goergia race . |
#88 |
mini truck racer
Re: New project
Went a few rounds in Baytown todat 1/5th mile bracket race . 7.001 off the trailer . on motor
#89 |
mini truck racer
Re: New project
Pulled the th 350 today 400 is in . Have to mod the cross meember and add a driveshaft loop while im there . Need new drive shaft yoke so 1350 it is . I had a 1350 rear yoke , so ill have a new shaft made . going 4.11 .
Man was getting the 400 in a pain .
#90 |
mini truck racer
Re: New project
2570 after the last pass . guessing the bars will add 100#s . Thinking i can put coilovers in place of the front shocks and lose the torsion bar crossmember and bars to get back down their . Also Having some idle curcuit problems with my speed demon so i bought a bigs stage 5 750 for it .
#91 |
Registered Truck Offender
Re: New project
wow,, 7.0 to the 1000' mark is kicking right along!!!! NICE job!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#92 |
Re: New project
If you dont mind can you take a few more pics of the fuel and lines , regs up front?? I am at that point and working around a few ideas but to see a few always is a big help. I have that Comp dual cheater kit I am getting into place. On the fuel cell are you running a say -8 TEE with a ball valve to swap from one tank to the other?
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
#93 |
Under Construction
Re: New project
nice progress!!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#94 | |
mini truck racer
Re: New project
1/8th mile on motor .
Thanks .
#95 |
mini truck racer
Re: New project
Pic update . Caltracs on , new hood painted , rear fenders painted 1 installed . Swapped to 4.11 . TH400 with transbrake is in .
![]() ![]() Golf cart getting painted and ready for this season of racing . ![]() ![]() ![]()
#96 |
mini truck racer
Re: New project
Here is the new hood installed .
#97 |
60-66 Nut
Re: New project
Looks good
![]() I noticed your CalTracs front brackets are on the ourside of the front spring hanger. Was there not enough room between the spring and the hanger? Do those new rear fenders have a larger opening? I see the flare, but they look like they have a bigger opening.
#98 | |
mini truck racer
Re: New project
The rear fenders are wider and will give me 1 1/2" more tier room . I think they were originally off a courier ( so i was told ) , but could have been off a full sized truck . They are glass and lighter than the gray ones .
#99 |
Re: New project
i recognize those endmill markings for dishing the pistons. nice work. subscribed....i'd like to see more of this.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#100 |
mini truck racer
Re: New project
Just got the pics of the finished golf cart . Let me know what you think .
