02-03-2012, 08:53 PM | #1 |
No Limit Spy Photos
Spy Photos
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-03-2012, 09:36 PM | #2 |
67-72 parts collector,…
Re: No Limit Spy Photos
New "NoLimit Member" jig?
02-03-2012, 10:40 PM | #3 |
Very interesting.....
02-03-2012, 10:55 PM | #4 |
Kinda Chris Alston looking,... isn't it.
02-10-2012, 06:50 PM | #5 |
New Parts
02-12-2012, 09:23 AM | #6 |
You going to offer it coilover or air bags?
02-12-2012, 02:17 PM | #7 |
your choice, we'll have both.
02-12-2012, 03:36 PM | #8 |
How long before there's a product info/marketing release?
02-13-2012, 01:31 PM | #9 |
Hopefully in two weeks. - need to make sure there ready to go. Plus, No Limit dealers get first crack at a pre-release.
02-25-2012, 09:34 AM | #10 |
Any spy photos for the rear ?
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-26-2012, 08:32 PM | #11 |
What gen is this for? 73-87?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
02-26-2012, 08:39 PM | #12 |
We are working on an updated version of our Wide-Ride 3 to fit as a bolt-in for 63-72, and 73-87
02-26-2012, 08:40 PM | #13 |
probably a stupid question, but would this work on the old square body 1 tons? or is the frame a different setup on them compared to the 1/2's?
02-27-2012, 12:41 AM | #14 |
03-05-2012, 08:15 PM | #15 |
Is the spy still on special assignment ?
03-19-2012, 05:15 PM | #16 |
any updates?
Doug Looking for a 67-72 short bed driver..... |
03-19-2012, 06:12 PM | #17 |
The spy is wet sanding today. We are finalizing motor mount towers at this point. Complex forming is holding us up, have to make new forming dies.
04-06-2012, 08:13 AM | #18 |
update ?
04-06-2012, 10:00 PM | #19 |
Motor mount towers are done, and after a week, we're finally rested up from the Del Mar thrash. We are shooting an install this weekend, well saturday, I'll post up some on monday. Happy Easter.
04-15-2012, 08:06 PM | #20 |
tomorrow is Monday.
04-17-2012, 03:28 PM | #21 |
Will this work with the current rack & pinion set up you offer? Is there going to be control arms offered also?
04-18-2012, 11:21 AM | #22 |
This crossmember is on a bit of a different track than most. We are moving away from the C-10 components. This will be a new version of our Wide-Ride IFS, a complete IFS package including the crosmember, A-arms, coil-overs, shockwaves, or bags/shocks, spindles, brakes, power rack, and sway bar. The spindle is based on a late model Impala, with 12" drilled/slotted rotors, your choice of any 5 lug pattern, sorry, no 5 lugs yet. The track width is 63" hub to hub. Groung clearance on the crossmember is raised 2" over stock, and ride hieght, without a dropped spindle is a 4" to 5" drop from stock, and 2" drop spindles are avail. Motor mounts are included, and will fit SBC, BBC, and LS.
04-18-2012, 12:22 PM | #23 |
Looks good Rob!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-20-2012, 01:43 PM | #24 |
Update
04-20-2012, 07:22 PM | #25 |
Is the Impala spindle taller them the c10 spindle ?
