Show me your Edelbrock throttle return!
How do YOU hook up your throttle return spring for your Edelbrock Performer carb?
I'm not real happy with the options I've been using and thought I would pick the brains of the Wise Ones (everyone but me ![]() Thanks! |
Rolled on Paint Club
![]() Join Date: Jan 2006
Re: Show me your Edelbrock throttle return!
I'll state first off that I am not one of the wise ones, but I'll post a pic of what I did: I made a small steel tab bolted to the right water neck stud.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
Right turn Clyde
I like how you made your vacuum lines out of metal tubing and rubber ends. That is something I would like to do with mine. Do you know what size tube is used?
I have the same spring setup for my 1406 also. But I have seen a pretty slick throttle bracket. It kind of looks like a bracket for a cable shifter. Bolts to the driverside studs for the carb. It mounts the springs lower on the throttle shaft setup kind of like stock does.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
![]() Join Date: Feb 2002
[QUOTE= But I have seen a pretty slick throttle bracket. It kind of looks like a bracket for a cable shifter. Bolts to the driverside studs for the carb. It mounts the springs lower on the throttle shaft setup kind of like stock does.[/QUOTE]
I don't know if the size of my avatar helps seeing detail that close, but I have that type of throttle return spring bracket on the EDL-1405 on my 292 L6. It was perfect for my application, since with the 4-Bbl rotated 90* on an Offy intake, I had nowhere to attach a return spring -- once I went to a cable accelerator set-up. A long brake spring going to the brake lines on the master cylinder was too scary. Mine's a Jeg's house brand but both Edelbrock and Holley list them. Here's the Holley p/n from a Summit catalog: HLY-20-112. My cat's old so look up the current price at www.SummitRacing.com.
On a budget like Fred Sanford
I've got mine hooked to the throttle bracket:
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 05-01-2007 at 09:37 AM. |
Sorry the booster hose is kinda in the way on the pic but this is my setup. Lokar cables and bracket. Been pretty happy with it so far.
Just a hint of advice, if you have the springs pulling back with the throttle cable it is harder on the trottle blade shafts then if you put the springs pulling forward counteracting the force from the cable. They will wear less that way.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 05-01-2007 at 11:13 PM. |
#9 | |
Wow that is a nice engine!!! Thanks for the advice! Next time I'm in the garage I will take a look and see what I need to do to change it. Great point. |
Here's that p/n of Jeg's version of the throttle return spring bracket:
555-15227 $40. About half the price of the Holley, but it's still made in USA.
#11 | |
Bob
Thought I should poste where I ended up. This is the Summit throttle return, the Holley TH350 kick-down cable mount, Spectre (I hate their stuff, but it was handy and cheap
![]() I suspect I'll pick up the really nice Holley or Lokar bracket sometime in the future - likely when I transfer this engine to the soon (?) to be restored chassis. Yes, I know about the frayed water temp sender wire - fixing it now ![]() Last edited by Billla; 05-10-2007 at 02:45 PM. |
Let's see if I can pull it up...
OK, This is from my 2005 292 build. You can't see it, but I had to cut off the last inch of the throttle return assembly to avoid contact with the valve cover.
