#76 |
Re: Captain America 68 short/fleetside
Thanks for the head's up. I got everything I needed for $38.00!! I swapped out the wheel cylinders. Of course, the only one that wasn't leaking is the one that broke the brake line. I both star adjuster wheels on the front axle were frozen, so I got those too.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
#77 |
My dad got some cool Low-back bucket seats for his 59 Chevy pickup, so he handed down his old racing seats. I installed them, and then we trailered the Captain to a friend's shop to get the exhaust installed. I've got the long tube headers and Magnaflows with pipes that will exit in front of the rear wheels. When I get the other bed installed, I want to run the exhaust tips through the bedsides in front of the rear wheels.
Two things that are bothering me. #1. When I replaced the hood, I broke the part of the old hood that latches into the hood latch assembly, and I can't find anywhere that sells it. After I broke it off, I realized it was attached to the plate that comes off with 4 bolts. #2, I've had my truck running, albeit with open headers, but it fired up every time. Today, the truck fired up, but then fizzled out, like someone was unplugging spark plug wires one at a time. I verified 12 volts to the distributor (HEI), even swapped out the coil, and eventually swapping out the entire distributor with a known good distributor, and still no spark. Any ideas?? -Josh
#78 |
#3 With the key off, I have 6 volts running through some wires, and it's killing my battery. The previous owner literally twisted wires together and wrapped them in electrical tape. The ignition wires about 3 inches off the switch are taped up that way.
-Josh
#79 |
I got my truck back from my friend's house, albeit with a gas can on the passenger seat and a long hose running to the fuel pump. Thus, my next question.
I"ve been searching relentlessly for a fuel tank to mount between the frame rails, behind the differential. My problem is the dimensions. I"ve sen the 49-52 tank swap, a Mustang tank swap, the 21 gallon Jimmy/ suburban tank swap. My framerail dimensions are 27wx24lx10d as the space available for a tank. Every tank I've seen is too wide. I don't want to drop $300-$500 for an aluminum tank. Any insight/advice from those who have done the swap already?? -Josh
#80 |
I just pulled the trigger on the poly 21 gallon tank. Thanks for all the help and advice. I"ll post pics when I install it.
-Josh
#81 |
I installed the poly tank today. Notched the bed rail for clearance, and ran 3/8 line inside the frame rails.
-Josh
#82 |
Does the tank hang super low? Not bad though and would be nice to have a 21 gal tank. what year suburban was it from?
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#83 |
http://www.ebay.com/itm/330548792252...252%26_rdc%3D1
It's a conversion kit. I thought it'd be too wide for the frame, but it actually has flanges molded into the sides that sit flush against the bottom of the frame rails. I don't think it hangs too low. I"m not going to lay frame, but I"d like to get it a little closer to the ground. -Josh
#84 |
I went to the junkyard today, looking to find some missing pieces for the truck. I picked up a duel filler neck out of a 1990 Nissan Maxima. It's 1 1/4 inch, just like the neck on the poly tank. I wanted to mount the filler neck inside the bed, but not on the floor. I cut the filler neck about 3 inched below the top bracket, then cut a hole on the inside of the driver's bed side, just in front of the rear stake pocket. I couldn't find and 1 1/4 pipe with a sharp enough bend to cut under the floor panel toward the fill neck on the tank. I ended up going to Tractor Supply and getting a 1 inch 90 degree elbow, and a 12 inch threaded 1 inch pipe. The outer diameter of the 1 inch pipe is 1 1/4 inches. I cut a length of 1 1/4 hose to connect the filler neck to the pipe elbow, then secured both ends. I haven't put the bed back on, because I need to get a fitting for the vent tube on the tank, and I get those free at work, so it'll have to wait until Monday.
-Josh
#85 |
I"ve been trying to dial in the drums brakes so I feel comfortable driving the truck on the road. I replaced the wheel cylinders, brake hoses and shoes, but I don't feel like the brakes are 100%. I pulled the trigger on a full 4-wheel disc setup with 2 inch drop spindle, and some air bags for the rear. I'll post pics when pats come in.
-Josh
#86 |
I got home from work last night to find 4 boxes on the front porch. Today, I tackled the rear disc setup. I bought the kits from Tom's Classics on Ebay. I'm very impressed that they include everything. Instructions are very clear, and it was a simple bolt in kit.
-Josh
#87 |
Rear Disk!!! That's awesome Josh. Looks good.
CHEVY/GMC VIN DECODERS |
#88 |
can you still use the original E- brake cables from the drums on the new calipers? i wam wanting to go to rear disc in my 67 and the last thing i dont know what or where to get for my application is the e brake cables.
#89 |
Nice brake kit!!! so shiny
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#90 | |
-Josh
#91 |
im not going to buy this kit. i have a template to make my own rear brackets and i have a list of all the parts that im supposed to get (calipers, rotors, pads, hoses ) but it doesnt say which e brake cable to get. thats why i was wondering id you could still possibly use the originals. thanks anyways though. your rear disc brakes loook really great! im sure they'll work just as good if not better then how they look.
#92 |
I installed the front disc and 2 inch drop spindles this morning. I still need to run new brake lines, and apparently, I need to order a front end rebuild kit. The passenger side has a lot of play in the upper control arm. I am loving the 2 inch drop in the front. I noticed as soon as I put her on the ground that it had a lower stance.
-Josh
#93 |
![]() Join Date: Oct 2012
Captain, Nice truck. For as far back as that was probably created, I think they did a great job. It'd be fun to have restored with it's current paint and detail scheme, minus the interior though. Red Paint with white bench would keep the theme going but Red and grey would be more practical. have fun. nice wheels too.
#94 |
Well, I ran all new brake lines and bled the crap out of my brakes. Turns out, my new master cylinder is bad, and the power booster leaks. So, more money spent, and now everything is brand new.
-Josh
#95 |
The Captain is making a turn for the better, That paint job made me laugh
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 10-21-2012 at 11:16 PM. Reason: spelling |
#96 |
The master and booster showed up yesterday. I installed everything, and, boom, instant brakes. Also, I had a friend help me put the bed back on. I rewired the tail lights. I need to get shorter shocks for the rear. The pic I have is with the bags aired out, but the shocks are bottomed out. There's still 3 inches before the bump stops touch. I like the height in the pic, but There's no travel. Any suggestions for shorter rear shocks??
-Josh
#97 |
VA72C10
![]() Join Date: Mar 2008
surprised the shocks are bottoming out...I have relocators on mine with bags, but it's not really the length they change but the angle....they are stock length shocks with performance valving for a lowered suspension (kyb's) ...so I'm guessing someone changed out your shocks at some point....
my stock length shocks aren't bottomed out and my rear bumper is 5" off the ground ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#98 |
VA72C10
Here's my stance w/ stock length shocks and bags aired out. No c-notch yet, but I did trim the bump stop and I also haven't lowered the front so the rear will come up a bit when I lower the front then back down a bit when I c-notch it...
#99 |
The rear shocks are air shocks, so they are definintely not stock. I'll see what the stock shock look like, and I'll probably just get those if they comress enough.
-Josh
#100 |
What size wheel do you run and were those rear disc brakes decently priced? I may have to pick up some to match my fronts
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
