#26 | |
The Older Generation
Re: 1972 Chevy C20 Longhorn "Factory Dually"
LockDoc
#27 |
Hmmmmmmm, I wonder....
C-30 C&C with 133" wb. Got it! Just need the longhorn bed, cash and time. I guess my long term plans arent all that original. Nice looking and a shame GM didnt make one until 73. |
#28 |
6>8 Plugless........
![]() Join Date: Sep 2007
I happen to know where there is a decent Longhorn bed......................... And a Longhorn frame with SRW HO52.....................
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#29 |
![]() ![]() Join Date: Jul 2002
I like it. Not original, but still a very nice looking build.
#30 |
Actually I like the period conversion style better. But here is a picture of a member's truck with widened tubs for dual wheels. Can't seem to find a quarter view of it in my pictures. Anyone have it or a link?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#31 |
The Blue one is 72Freak's old truck and the tires are tucked in the bed side. It is a very nice truck and he sold it really reasonable too!
#32 |
![]() Join Date: Mar 2003
To get the duals to fit without fender extensions, a total custom job would have to be fabricated. As in the frame rails would have to be moved inward to clear the inner tire and rim assy. You can see by the pics how far the inner fenders were extended.
#33 |
That is why you use a cab and chassis dually rear axle. The outer tire barely sticks out. That is how that blue truck is done and the same with this truck in this thread. No frame mods required.
#34 |
Here are a couple of threads on 72Freaks dually. Ryan is correct, no frame mods required with the C-30 Chassis. Basically all you have to do is widen the tubs and install front bed mount brackets on the frame for the Longhorn bed... http://67-72chevytrucks.com/vboard/s...d.php?t=260748 http://67-72chevytrucks.com/vboard/s...d.php?t=307114 LockDoc
#35 |
What was I thinking?
Pretty cool trucks! I was going to put a utility bed on mine, but having a hard time finding one I like. Think I need to cut it down to a long wheel base and put a bed on it! Now if I can just find that straight factory blue paint so I can keep the patina... Yeah right!
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=530720 Posted via Mobile Device
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
#36 |
So, you're not using a longhorn frame, you're starting with a flatbed. I've got a 68 longhorn that I did a dually conversion on the rear. the springs do not allow the tires to stuff in that far. Now if you start with a 133'' flatbed, I'm sure that is different
#37 | |
Currently Blazerless
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#38 |
Hmmm, like I said I just did this to my 68. and the tires stick out each side by about 2-2-1/2'' inches. Tires are about 3/4'' from the springs. This is using stock dually rims with a 7.50-16 tire. Using a C&C rear axle wouldn't have worked by my measurements. I have a C&C axle assy in my tow truck and took the measurements of of that.
#39 |
very nicely done and i would LOVE to have it. however, it is by far an original. it screams restoration and customization. the tubs are clearly fabricated with a filler piece. and as stated before....the longhorn didnt release until 73.
I'd Rather Push My ![]() 1988 GMC Sierra SLE, 2 door, shortbed (Ol' Blue) (http://67-72chevytrucks.com/vboard/s...d.php?t=528216) 1995 GMC Sierra SLT Z71, ext-cab, long bed (The Beast) (http://67-72chevytrucks.com/vboard/s...d.php?t=531244) 1996 Chevrolet Tahoe LT, 4 door grocery getter (Mama's Ride) |
#40 | |
#41 |
There are LOTS of variations.
#42 |
OK, I looked under the truck to remember what i did. The 3/4'' measurement I remembered was from the inside of the tire to the AIR BAG bracket that comes off the frame rail, that's why I had to move them outward. What I did about a year ago was convert the rear to a 14b axle to get a decent ratio. So what I did was use the single wheel 14b (3.42's and detroit), and put a dually drum on it for the brake drum clearance on the indside of the rim and I moved the backing plate inward to accommodate the drum and shoes. It always seems to be complicated when I do something
#43 |
That still looks nice though!
#44 |
I do like the look of a SRW converted to a DRW and I need the 50" between the inner fenders. What are the options for a period looking truck? The cutout style works I'm just not a fan of the fastener pockets. The stepside conversion look is out for me. If I wanted a step I'd widen a set of fenders like the old Dodges did but bed volume and width are currently important. Are there any sources left for these early type of fenders? Arrow started about '74 but J.C. Whitney had them for their spool dual wheel conversions much earlier. Looking back I think learning to read with J.C. Whitney/Warshawsky and Popular Mechanics may have altered my life! :-)
#45 |
#46 |
![]() Join Date: Aug 2008
I wonder if the eBay truck at the start of the thread was a 3/4 ton longhorn that got dual wheels, or a 1 ton that someone put a bed and longhorn emblems on (?)
Posted via Mobile Device |
#47 |
The VIN and the model numbers presented confirm it to be a '72 C/20 pickup 133" wb Longhorn as built.
#48 |
I'm guessing it got a cab and chassis rear axle and they widened the wheel tubs when it was done. When ever it was done, they did do a nice job on it as it still looks great today!
#49 |
If someone wanted to buy it and store it at my place, I could probably find room for it... ![]() LockDoc
#50 | |
