Old 10-17-2012, 09:59 PM   #951
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Got one side of the front brakes done today--the drop spindles require much less material to be removed than the stockers.
Last look at the D52 'ears'
Carnage! Sawzall and a grinder made quick work of it. Also drilled out the backing plate bolts and tapped them to 1/2-13
Painted the cuts and installed the mounting bracket and hub
...and complete. The paint will wipe from the rotor face at first application.
Also installed one of the braided lines I got from Kore3. They are nice pieces, custom made to my specs for length and fittings, and are a matching set of 5 with the rear drop and caliper lines...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-17-2012, 10:15 PM   #952
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I guess I missed it. What rotors/hubs/brackets are you using there?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-17-2012, 10:25 PM   #953
gringoloco
A guy with a truck
gringoloco's Avatar
The hubs and brackets are from Kore3--they adapt 13" C5 rotors and calipers. Paired with the CaptainFab rear discs, I hope this thing will STOP
-Chris
Old 10-17-2012, 10:36 PM   #954
68GMCCustom
cool....and thanks!
Kurt -
Old 10-17-2012, 10:38 PM   #955
gringoloco
A guy with a truck
gringoloco's Avatar
Also cut up a poly bushing to fit the front of the upper shocks to the CPP extenders. Lopped them in half and took about 1/8" off and they fit perfectly
-Chris
Old 10-17-2012, 10:40 PM   #956
gringoloco
A guy with a truck
gringoloco's Avatar
Wheel on--it's coming together...
-Chris
Old 10-17-2012, 10:45 PM   #957
Bennett68C10
Bennett68C10's Avatar
Brakes look really good, I don't think you will have any problems stopping now.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-18-2012, 07:21 AM   #958
raull
raull's Avatar
nice mods bud !!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 10-18-2012, 08:05 AM   #959
67cheby
67cheby
67cheby's Avatar
Sweet !
67cheby is offline   Reply With Quote
Old 10-18-2012, 10:59 AM   #960
buckstoy
Originally Posted by gringoloco View Post
I am with ya on that one--had my heart set on another Dropmember, just couldn't put together the scratch right now. Maybe an assembled pic of the lowers will help you decide
Gringo, love your truck. On your PB lower a-arms did the shaft come with those or did you have to buy it elsewhere? I ask because mine didn't come with it.
Thanks, buck
buckstoy is offline   Reply With Quote
Old 10-18-2012, 11:36 AM   #961
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, I sure hope not. Really looking for that nice, confidence inspiring, firm, effortless pedal feel. Am I asking for too much?
Originally Posted by raull View Post
nice mods bud !!!
Thanks!
Originally Posted by 67cheby View Post
Sweet !
Thanks for taking the time--now get back on yours--SEMA is in a few days...
Thanks, buck
Call PB--they should have come with your arms if you're using them with a stock crossmember. I think they are set up for use with a Dropmember unless you specify otherwise...
-Chris
Old 10-18-2012, 11:50 AM   #962
Madmartigan
I am patiently waiting on the 1" forward lower a-arm install. Want to see how much they actually move the wheel before I pull the trigger. Great truck and write up!
Madmartigan is offline   Reply With Quote
Old 10-18-2012, 04:16 PM   #963
gringoloco
A guy with a truck
gringoloco's Avatar
Coming soon! I figure the wheel will move forward around a half inch or so, due to the position of the spindle between the balljoints--would probably be a little more with stock height spindles... I'm excited to get to that part as well, for not only the looks, but also the driveability. Thanks for the kind words and welcome to the forum
-Chris
Old 10-18-2012, 04:54 PM   #964
CC69Rat
CC69Rat's Avatar
Looks killer brother! Great job. I'm hoping my McGaughys turn out half this nice.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 10-18-2012, 05:37 PM   #965
big_al_71
big_al_71's Avatar
Great job it looks great!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-18-2012, 05:51 PM   #966
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! With your attention to detail, I'm sure they will turn out great.
Thanks! The first one took a few hours longer than anticipated--hopefully have the pass side wrapped up soon...
-Chris
Old 10-18-2012, 06:17 PM   #967
69gmcc10
69gmcc10's Avatar
Nice to see you back at it, those brakes look good! You almost have me convinced to do it.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-18-2012, 10:02 PM   #968
gringoloco
A guy with a truck
gringoloco's Avatar
They do look nice--hoping they perform as well. Should know in the next day or two...
-Chris
Old 10-19-2012, 05:53 PM   #969
shearjs
shearjs's Avatar
I love this truck! I'm glad I re-stumbled upon this thread again. Awesome progress!
shearjs is offline   Reply With Quote
Old 10-19-2012, 09:22 PM   #970
gringoloco
A guy with a truck
gringoloco's Avatar
Hey, thanks man! We love it, too
Update: WHOLLY SHNIKEYS! This. Thing. STOPS.
After assembling the passenger side, I took her out to rub the paint off the rotors and bed the Hawk HPS pads. The initial impression was a bit lackluster, but I continued with the recommended break-in, then let them cool. Went back out for a follow-up and WOW! These things have some serious bite and the firmness and responsiveness of the pedal feel reminds me of my old C5 'Vette. I may need shoulder harnesses to keep from bouncing my passengers' faces off the dash
Amazingly, this is with basically no rear brakes at all--when I went to bleed the fronts, I found the rear reservoir empty--I've known for some time that I had a leaky wheel cylinder, but was putting it off until I got the rear discs swapped in. I dumped a little fluid in, but did not bleed the rears, so their contribution to braking is questionable at best.
No matter, the fronts lock up with ease. It has gone from 'push-and-pray' to 'don't push too hard' Can't wait to see what four-wheel discs feel like
Pic, 'cause you can't have an update without one...
-Chris
Old 10-19-2012, 10:24 PM   #971
lolife99
67-72 parts collector,…
lolife99's Avatar
I think your truck deserves some fender emblems.
Maybe a set of Custom emblems.
Not Custom/10,... just Custom,... cause it is so cool.
Love the brake upgrades.
Keith
Convert to disc brakes.
Old 10-20-2012, 12:25 AM   #972
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- thanks! I've thought about adding some, but also like the 'slick' look--notice the truck has no side mirrors? I have a hard time deciding what to add that doesn't subtract...
-Chris
Old 10-28-2012, 11:49 PM   #973
Low68
Low68's Avatar
I have a couple of quick questions. I checked on Kore3's site and those appear to be the hubs for the GM tall spindle? Is that correct? Forgive me if I missed it in a previous post, but what spindle are you using? Is that 5x5 or 5x4.75 bolt pattern? Thanks
Low68 is offline   Reply With Quote
Old 11-03-2012, 09:27 PM   #974
gringoloco
A guy with a truck
gringoloco's Avatar
Hey, sorry I missed this before. They are technically made for the B-body cars, specifically Impala SS. The spindle shaft is the same on the 'tall' spindle, late '70s F-bodies, big cars, and light trucks, which is the spindles I have (1" thick rotor Belltech 3" drop). The hubs can be had in 5 or 4.75--mine are 5, just 'cause I already had wheels. Kore3 also offers hubs for the 1.25" thick HD truck rotor spindles, though not on their website. Member Scoti has this setup somewhere in his pile o' parts...
-Chris
Old 11-03-2012, 09:40 PM   #975
gringoloco
A guy with a truck
gringoloco's Avatar
Minor progress today--started assembling the CaptainFab D52 rear disc brakes. QUALITY components. Putting them together was pretty straight-forward, so I'll save you guys the gory details.
Of note: I cut off the backing plate on the driver's side and found that it is not a whole lot easier than just pulling the axles--oh well, live and learn Also found my massive wheel cylinder leak that had everything inside the drum soaked; the brake shoes literally fell apart when I pulled the drum...
Before, carnage, and tear-down pics:
-Chris
