07-27-2012, 09:46 AM | #126 |
Daring to be Different
Re: Any Dash Ideas
It's well worth it though, especially with your dash. It will make it look complete.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
11-09-2012, 10:32 PM | #127 |
But Found Her 25yrs Later!
Re: Any Dash Ideas
11-28-2012, 05:32 AM | #128 |
Re: Any Dash Ideas
'63 cluster before & after paint - spare piece of sheetmetal and autometer gauges. Kept the layout similar to stock, plus the tach. No turn signal indicators, I wired them into the two left and two right gauges so they blink.
Posted via Mobile Device Posted via Mobile Device |
11-28-2012, 10:36 AM | #129 |
Re: Any Dash Ideas
Here is my copper patina dash and glove box
11-28-2012, 10:55 AM | #130 |
Re: Any Dash Ideas
11-28-2012, 11:02 AM | #131 |
Re: Any Dash Ideas
I didn't see where anyone mention they 'needed' a 10K tach?? Some guys like the 10K display; others don't. I don't care for a 200mph speedo range when I know I won't come near it. Same for the tach; 8K will do for me & even that's excessive....
11-29-2012, 12:04 AM | #132 |
LIGHTMUP,BURNMDWN!
Re: Any Dash Ideas
Posted via Mobile Device61 caddy and a roll up bbw
64 LWB Chevy " EL DEVILLE" 61 Caddy ambulance 56 Coupe deville 64 Coupe deville 29 Ford roadster |
11-29-2012, 10:54 AM | #133 |
Re: Any Dash Ideas
That was makin' me dizzy....
11-29-2012, 12:25 PM | #134 |
Re: Any Dash Ideas
Here is mine. Replaced gauges, steering column and steering wheel. Still factory paint on dash.
[IMG][/IMG] [IMG][/IMG] |
12-02-2012, 12:01 PM | #135 |
Re: Any Dash Ideas
Ok guy's this is my dash i'm working on...
it might be a little out there for some of you but i wanted something different..i will be doing a complete build on my truck soon so look for it "Orangepeel" Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-02-2012, 01:13 PM | #136 |
Re: Any Dash Ideas
Daring to be different. I LIKE IT.
12-02-2012, 01:55 PM | #137 |
Re: Any Dash Ideas
Here is what I am doing in my 1964 GMC
Ordered the Dakota Digital gauges from Travis at Pro Performance yesterday. They are intended for a 1964-67 Pontiac GTO, Lemans, Tempest VHX Instruments P/N VHX-64P-GTO-C-R (Carbon Fiber/Red) Not much to choose from for A GMC but I think with a rubber mallet and some caulking I can make them fit. They come altogether in one self contained unit with just a CAT5 cable running from the control module to the back of the unit, the module can be mounted up to 6 feet away. Length: 18-3/4” Height: 4-3/8” Depth: 1-1/16” Gauge opening sizes from Left to right: 3-7/8” / 4” / 4” / 3-7/8” I plan on having a brushed metal dash panel laser cut to fit the stock outer bezel with opening for the new gauges. I priced out Classic Instruments, and Autometer to try and fit into the stock opening and the Dakota gauges worked out to be less money and offered more functions. |
12-02-2012, 02:29 PM | #138 |
Re: Any Dash Ideas
I was thinking something along these lines. Price isn't bad and full electronic. Would work out good when I eventually install a 4L80E trans since there is no speedometer drive cable coming out of the trans.
http://www.ebay.com/itm/64-65-66-CHE...item35a01e751f |
12-02-2012, 02:36 PM | #139 |
Re: Any Dash Ideas
hey reaper that is an amazing looking dash!!! nice work man
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
12-02-2012, 07:04 PM | #140 | |
Re: Any Dash Ideas
12-02-2012, 07:11 PM | #141 |
Re: Any Dash Ideas
I would like to make these work in my dash. Just a little slice & dice.
12-02-2012, 09:30 PM | #142 |
Re: Any Dash Ideas
Thanks coulter! Its been a ton of work and ALOT of welding...Posted via Mobile Device
12-02-2012, 09:38 PM | #143 | |
Re: Any Dash Ideas
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
12-03-2012, 01:57 AM | #144 |
60-66 Nut
Re: Any Dash Ideas
I agree....
12-03-2012, 12:40 PM | #145 |
Re: Any Dash Ideas
Thanks guys, when i get my pics off my old comp.(mother board crashed) i'll start my build thread and the entire dash build will be on it as well...
Mark
07-02-2013, 06:27 PM | #146 |
I put the laughter n slaughter
Re: Any Dash Ideas
I've acquired a dash out of a 1960 GMC that I plan on putting in my truck. I want to have air conditioning as well. I've searched and came up empty, but do any of you guys have a pic of a factory GMC A/C dash?
I still dont care how you did it in California!!! |
07-02-2013, 11:05 PM | #147 |
Re: Any Dash Ideas
Autometer Phantom Gauges
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
11-06-2013, 10:42 AM | #148 |
Re: Any Dash Ideas
Ttt
11-06-2013, 10:56 AM | #149 |
Re: Any Dash Ideas
Why does everybody hate California??
11-06-2013, 05:45 PM | #150 |
Re: Any Dash Ideas
