Old 11-26-2012, 09:21 PM   #101
emikstone
Re: Where is my 60-66 Chevy or GMC vin number?
Still confused about the VIN on the title of a supposed 66 pk I am looking at to buy.... haven't checked the tag on the door againt the title yet... 11002PD19514A ???
emikstone is offline   Reply With Quote
Old 11-26-2012, 09:33 PM   #102
padresag
is there something that you want for someone on here to do. is there a question?
ron
padresag is offline   Reply With Quote
Old 11-27-2012, 12:03 AM   #103
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
here is what I came up with:
It is a gmc vin.
the first number "1" is actially an "I" - a common mistake by the dmv -they will often mistake I's and O's for 1"s and 0's.
the "I" stands for inline 6 motor.
10= 1/2 ton
02= 127 wb-long box wheelbase
P= pontiac michigan assembly plant
D= 1966 inline 6 gmc
19514= serial number
A=6000lb weight rating.
hope this helps
all this info is from here: http://www.6066gmcguy.org/VinNumber.htm
Old 11-27-2012, 08:19 AM   #104
emikstone
Thanks jonzcustomshop! You are awesome. Now to I'D the.motor. any ideas?
Old 12-04-2012, 02:39 AM   #105
Bigffjoe
Bigffjoe's Avatar
Here is mine.
If I seen most of the comments of this thread I have...
1961, 4x4, 1/2 ton, surburban(or carryall), from Oakland(CA?), production #8476.
I'm not sure if the stamped 061 or the 97 on both sides of the Chevrolet are stock or added on by someone. Does any on know or have an idea?
Joe.
1961 K14 Suburban 4x4
My suburban build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=555159
CList stuff. http://67-72chevytrucks.com/vboard/s...=428759&page=7
Bigffjoe is offline   Reply With Quote
Old 12-04-2012, 06:29 PM   #106
jonzcustomshop
1961 crewcab
Originally Posted by Bigffjoe View Post
Here is mine.
I see some forest service green hiding there under the door weatherstrip.... I am going to guess that the 061, and 97 were stamped there by the forest service to keep track of the vehicle...
Old 12-04-2012, 09:36 PM   #107
Bigffjoe
Bigffjoe's Avatar
Hmm, I will have to do some checking around, My dad had mentioned that too, thinking it was a old forest service rig because of the darker green color. I will see if he and I can find out more info and get more history on this rig. That sure would make a good story about it!
Thank you, jonzcustomshop.
Joe.
Old 12-13-2012, 12:10 PM   #108
jayoldschool
Moderator
Can someone give me a hand with this one? There's a couple things I can't seem to figure out. Truck's in Canada, but that doesn't mean it was made here. It's a 65, btw:
C154A102495
jayoldschool is offline   Reply With Quote
Old 01-08-2013, 06:31 PM   #109
jonzcustomshop
1961 crewcab
here is a good link from padresaq for titling vehicles in all 50 states.
this should help with all the different requirements for each state.
http://www.bipac.net/page.asp?conten...olbox&g=SEMAGA
Old 01-08-2013, 06:46 PM   #110
jonzcustomshop
1961 crewcab
C154A102495
seems like there is a # missing if it is an american vin tag: c=2wd,15=1/2 ton lwb, 4= pickup, there should be a 5 here for 1965, a= atlanta, 102495=the vin.
here is the vin wiz with a "5" added in the right spot:
.VIN Format: 1965-1966 Chevrolet truck
Decoding: C1545A102495
Digit Usage VIN Decoded
1 Type C Conventional (2WD)
2-3 Model 15 1/2-Ton, Long Wheelbase
4 Body 4 Pickup
5 Year 5 1965
6 Plant A Atlanta GA
7-12 Sequential Serial # 102495 102495
Old 01-13-2013, 05:50 PM   #111
66 C30
Don't think this has been mentioned before, but for the body(4th digit) a 3 designates a cab and chassis.
Also, in my vin, KC3836T120636, what does the first K stand for? The truck is a 1966 2wd 1 ton, 157'' wb. I decoded the vin already, and the only thing that i didn't get was the K and the 38, which i assume is for the 1 ton part. Thanks in advance for the advice.
66 C30 is offline   Reply With Quote
Old 11-03-2013, 03:29 PM   #112
Mjkids
This helped I could not find it thanks
Mjkids is offline   Reply With Quote
Old 03-15-2014, 01:52 AM   #113
Riverbuzzrat
Riverbuzzrat's Avatar
Im having problems decoding my vin here it is if anyone can help 2C2530125048 I know it's a 62 3/4 ton fleetside long bed with a 235 straight 6 ,3 peed manual tranny I suspect the bed to be a 66 , it has holes for back up lights , any ideas where it was made and what type of bed it had and if it's a c 10 or c20 , any ideas ?
Riverbuzzrat is offline   Reply With Quote
Old 03-25-2014, 01:55 PM   #114
88k5jimmy
Can somebody run this frame stamp so I can see if my conclusions are correct:
5S141205
I'm mainly concerned about what year it is.
88k5jimmy is offline   Reply With Quote
Old 03-25-2014, 06:14 PM   #115
jonzcustomshop
1961 crewcab
the first # is a 5 , so it is a 65, s= stlouis plant., the other part is the serial #
Old 04-03-2014, 11:34 PM   #116
Apache809
Apache809's Avatar
Hello, I have been told several times that I have a rare truck. It's a 1961 longbed stepside 1 ton c30 with 4 on the floor.. This decoder doesn't specify 1 ton nor the 61 longbed stepside. Is there a reason for that?
Also, I've been looking and can't find another owner so im curious to know if i have the only one. Im not sure if thats a good thing or not but it tikles my curiosity. I was checking out the 1961 Chevy truck series poster i didn't see it there either. I'll post a few pics for you to see it for yourself. The one circles is the short stepside.
My vin Number: 1C364B116824
61 Apache
C30 Longbed StepSide
Named "BigBoy"
Build Page:
http://67-72chevytrucks.com/vboard/s...70#post6545970
YouTube Build Videos (Click 2 Watch)
Apache809 is offline   Reply With Quote
Old 04-04-2014, 12:06 AM   #117
Apache809
Apache809's Avatar
Literature thread
http://67-72chevytrucks.com/vboard/s...erature&page=2
61 Apache
Named "BigBoy"
Build Page:
Old 04-04-2014, 02:25 AM   #118
Lo Blu62
My 1962 VIN's sixth digit (assembly plant) is an "L". It doesn't match any of the assembly plants listed. What the L?
Lo Blu62 is offline   Reply With Quote
Old 04-04-2014, 02:30 AM   #119
Apache809
Apache809's Avatar
You might have a Canadian?
61 Apache
Named "BigBoy"
Build Page:
Old 04-16-2014, 05:37 PM   #120
Ronw435
Ronw435's Avatar
I got a number off the left front frame just in front of the a-frame. 5S203265. Can anyone decipher this? I looked at a GM site and it said the S was for school bus. I don't think this short wheel base step side truck was a school bus...................was it?
Ron
Ronw435 is offline   Reply With Quote
Old 04-16-2014, 08:27 PM   #121
jonzcustomshop
1961 crewcab
"L" is for the los angeles plant
Ron
the frame used an abbreviated vin, only the year, plant , and #, so yours is 5 = 1965, S= St Lois, and the vin#
Old 04-17-2014, 07:38 AM   #122
Ronw435
Ronw435's Avatar
Well now I have a dilemma. The title I was provided says the VIN number is 4C144S118226. Does anyone know how to trace this down? There was not a VIN tag on the door opening. I was told I am the third owner of this vehicle. Can anyone tell me some of the differences between a 64 and 65? I took the motor out and according to my engine guy it was a 65 283. But he did say that it could of been a late year 64 with a early built 65 283. Just something sounds fishy here.
Old 04-17-2014, 11:45 AM   #123
Ronw435
Ronw435's Avatar
Does anyone know who can do a title search on the partial number I got off the frame?
Ron
Old 04-17-2014, 11:55 AM   #124
padresag
ser# that you did show(frame) should match what your documentation but that doesn't seem to be the case does it. sometimes you have to look at the top of the door jam to see a vin plate.
by the sounds of it perhaps you should go and ask for your money back unless the PO can straighten up the documentation and make it legal.
ron
Old 04-17-2014, 03:50 PM   #125
Ronw435
Ronw435's Avatar
Well I have talked to the PO and he said that number was the one given to him in 2009. And he was not aware of any other numbers. The frame did have a lot of oil and dirt on the frame so I believe what he said. He has registered it every year and said no one has ever said anything to him about it. He is going to try and find the original owner to see what they say about it. I tried putting the number( on the title) in and it showed up in the data base. I put the number in off the frame with a 5c144 before it and it showed up nothing in the nation wide data base. I am going to go to the Texas DMV and have them do a title history search done on both numbers to see what that tells me. The truck has a current registration on it until 1-15 and when I transferred the title they did not say a thing about it. ??????
Also the tag is not on the door frame.
The saga continues.
Thanks for the reply.
Ron
