Old 08-24-2012, 11:50 AM   #76
Woody's Hot Rods
Re: 1965 C-10 LS build
Nice truck! Looking forward to the finished product.
Woody's Hot Rods is offline   Reply With Quote
Old 08-24-2012, 11:31 PM   #77
rmvlt1100
rmvlt1100's Avatar
Thank you for the complement. I just took a look at your truck. WOW hope mine turns out even half of what yours looks like. Great Job.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 08-27-2012, 03:45 PM   #78
Woody's Hot Rods
Thank you! It's not without flaws but I'm happy with it.
Old 09-14-2012, 10:34 PM   #79
rmvlt1100
rmvlt1100's Avatar
A little update. With most of the mechanical work done its time to work on the body. Not my favorite thing to do but it needs to get done. I finished up the rear roll pan and the reverse lights in the roll pan.
The other major issue was the drivers side cab corner. The previous owner changed it but it was touching the bed edge when I put the bed on the truck. The passenger side was fine the drivers touched. After I cut the old corner off and went to put on the new corner I did not fit very good. The corner stuck out the back of the cab about 1/2 of an inch. I guess it was not the previous owners fault on the first try. These after market parts really s@&k. I had to section out about 1/2 of an inch. Below is a picture of what had to be removed.
Posted via Mobile Device[/QUOTE][/QUOTE]
After that cut I had to cut the back side of the new corner and bend it down to make if fit with the rear of the cab. Then filled it in with a piece of metal.
Well got that finished and ready for primer. Also blocked sanded the door and will prime the both in the morning. Well I was going to post a picture of the final sanding before primer but the photo bucket doesn't like me tonight. That's it for now have a great night.
Old 12-06-2012, 01:26 AM   #80
rmvlt1100
rmvlt1100's Avatar
It's been a while since the last post. So a little up date. Pulled the motor and trans out and put them in the corner for now. I was able to get the hood own and it fits good. Just finished a little work on the upper fender extensions. Now just have to decided on the colors and start priming and block sanding. I'm going to try to get it done by early spring.
I put down a couple coats of Lizard Skin on the floor, fire wall and part of the rear wall.
Well that's all for tonight have a good night👍👍
Old 12-06-2012, 02:04 PM   #81
rmvlt1100
rmvlt1100's Avatar
[[IMG][/IMG]
Well that's all for tonight have a good night����
The pictures didn't load on my post last night. So I will try them again.
Thanks for looking.....
Old 12-06-2012, 03:09 PM   #82
flips72
flips72's Avatar
looks great
flips72 is offline   Reply With Quote
Old 12-08-2012, 01:54 AM   #83
Sanchez Garage
wow great build.
Sanchez Garage is offline   Reply With Quote
Old 12-12-2012, 07:55 PM   #84
rmvlt1100
rmvlt1100's Avatar
Originally Posted by flips72 View Post
looks great
Thanks for the look and comment Flips.
Old 12-12-2012, 07:57 PM   #85
rmvlt1100
rmvlt1100's Avatar
Originally Posted by Sanchez Garage View Post
wow great build.
Thanks for the look and comment.
Old 12-27-2012, 02:48 PM   #86
rmvlt1100
rmvlt1100's Avatar
Well I'm getting closer to paint. It was a little nerve racking but the trim is finished with the mockup on the new fenders and doors. It was hard to drill holes into new metal but its done.
I tried something different with bumper. I made new bumper brackets and flipped it over. Just wanted to do something different. ?????????
Also got the interior painted.
I did have a little slip with the paint gun. A little to long in one spot. This is an easy fix though.
I guess not bad for my first time with a finish coat. It's going the paint shop for the second week of January. So hoping by March I can start putting it back together.
Old 12-27-2012, 04:11 PM   #87
McMurphy
McMurphy's Avatar
I really like that bumper flip !!
Mind if I steal that for my build?
Though I may modify it some.... seems I cannot leave well enough alone on my build.
That air box you made in the engine compartment turned out really nice too. Where did you move your battery to though, did I miss that?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-27-2012, 05:44 PM   #88
rmvlt1100
rmvlt1100's Avatar
The bumper flip was eaiser than I thought it would be. I also moved it in closer to the grill to close up the gap. The hardest part was figuring where to cut off the bumper mounts on the frame.
I put the battery on the drivers side. The drivers side is where the battery connections are on the LS motor.
Thanks for looking at my build and stay warm up there.
Old 12-27-2012, 08:37 PM   #89
62 Barnfind
62 Barnfind's Avatar
Looking good! Like the bumper flip!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-27-2012, 10:06 PM   #90
rmvlt1100
rmvlt1100's Avatar
Thanks for the nice words. I wasn't sure about the bumper but I like the way it turned out. I just read your build. It looks great. You doing everything in your garage? I was originaly going to use the Hot Rod Flatz paint but I read some horror stories about it streaking. I did use the Gun Metal Gray Metallic on the interior and only had 1 little issue with a slight run. I am going to use that color for the roof and the strip between the chrome. The going to use a PPG paint and a flatten clear for the rest of the truck. I can't spray that much in my garage to paint the entire truck so a friend of mine is going to paint it. He never used that Hot Rod Flatz before so he got a deal on some PPG for me. Any way keep up the good work on your truck. I will check for your updates on it.
Old 01-01-2013, 11:25 PM   #91
rmvlt1100
rmvlt1100's Avatar
Been working a some small details the past couple of days. Nothing much to talk about. But I did get the power door locks installed. I purchased a kit from VH Coachworks. Its made for a 1967-72 truck, I was able to get it to fit. It was eaiser than I thought it would be.
Here are some pictures:
Had to do some work on the latch. Here are some pictures:
There is another post some where that shows the work on the door latch but I can't find it again. But I will keep looking. Hope everyone has a good night.
Old 01-02-2013, 06:44 PM   #92
flips72
flips72's Avatar
man, you have been hard at it, great work, love the bumper as well, people always ask if they are upside down
Old 01-03-2013, 11:18 AM   #93
structures
structures's Avatar
great build!
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 01-03-2013, 07:05 PM   #94
rmvlt1100
rmvlt1100's Avatar
Thanks Flips, I hope mine turns out even as half as nice as your is. I'm not a body man but I learned alot with this one. Have a great day.
Old 01-03-2013, 07:14 PM   #95
rmvlt1100
rmvlt1100's Avatar
Originally Posted by structures View Post
great build!
Thanks structures. I see that you had some fun with those cab supports. I went through the same great time on mine. Every thing is looking good on your build.
Old 01-03-2013, 08:38 PM   #96
flips72
flips72's Avatar
i too am not a body man but i sure did learn as well, i learned to let somebody else do it next time just kidding you will be glad your doing it yourself when your done though, and your doing a great job looks like to me
Old 01-06-2013, 10:59 PM   #97
rmvlt1100
rmvlt1100's Avatar
Not much going on, been working alot and fitting the lovely midwest cold and flu season. Hopefully this week get the the priming and block sanding done. I did get the heater box painted and the new heater core and blower motor installed and ready to go. A couple of pictures below. Have a good night.
On another note maybe some NHL Hockey in the next few weeks.
Old 01-07-2013, 09:14 PM   #98
flips72
flips72's Avatar
nice...
Old 01-10-2013, 04:06 PM   #99
aggie91
I'm just glad to be here!
aggie91's Avatar
Just read thru you build. Looks good! I might have missed it, but what did you use to coat the floor in the cab?
Also, what did you do for headers for the LS?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-10-2013, 06:09 PM   #100
rmvlt1100
rmvlt1100's Avatar
Thanks for the look at my build.
I used Lizard Skin sound control on the floor.
The headers are Doug Thorley. There for a 1967 model year C-10. Had to do some clearanceing on the frame but they fit good. A bit expensive too.
Thanks,
Robert
