01-31-2013, 10:54 PM | #751 |
Re: My 57 Pro Street
Well I finally made a little progress on the frame.
Got started on the front suspension. Upper and lower control arms and springs are in. Still need to decide on what shocks I will be using. The rubber hose is there until I get it on the ground with some weight on it so the upper arms wont hit the frame. Kim |
01-31-2013, 10:56 PM | #752 |
A couple more pics.
I also got the brake brackets mounted. Kim |
01-31-2013, 11:33 PM | #753 |
Kim, that is looking so sweeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
02-01-2013, 04:39 AM | #754 |
lookin very very good !!!!
02-01-2013, 06:38 AM | #755 |
WOW, a lot pieces coming together. and to think you are going to cover all this work up with the body ! Maybe another look at the saw horses and total weight !
I love this part of the build!
02-01-2013, 11:59 AM | #756 | |
Thanks Quote:
It will be coming off the tall horses before I add anymore parts to it. They did make it a lot easier to work on it though. Kim |
02-01-2013, 12:39 PM | #757 |
Certified Car Nut
Looking good Kim, looking really good. Good job buddy.
02-01-2013, 01:30 PM | #758 |
Man this thing is gonna be soooooo sick!! I'm in on it!! Good luck man!!
WWW.TASKFORCEERA.COM '47-'59 Chevrolet Truck Clothing |
02-01-2013, 02:30 PM | #759 | |
Thanks Bam.
Kim |
02-01-2013, 06:09 PM | #760 |
56 - autocross
Hey Kim:
Thought about fuel and brake lines? What are you going to use (aluminum, stainless, steel, etc.) and size? |
02-01-2013, 08:02 PM | #761 | |
I used braided steel from the tank into my pre-filter and pump and then hard lines from there to the front of the frame. I'll use braided steel from there to the engine fuel rail. Kim |
02-01-2013, 09:07 PM | #762 |
56 - autocross
They look clean. Where did you get the steel lines? Were they straight or coiled when you got them? What did you use to bend, flare, and cut them? I have talked to a lot of people and get the gammot of "u should use stainless, aluminum, stainless cracks, aluminum is too soft.....etc. I am thinking that steel is the way to go. That is what they use in most cars.
02-01-2013, 10:00 PM | #763 |
So Kim, did you end up putting 2 or 3 coats on the frame? You mentioned earlier using a small roller. I did that on a small bench top project I did and even on that the paint starts to get tacky or kinda "thread-y" half way through the job. I'm wondering how it worked for you? I waited the full 7 days and put a second coat and that stuff gets pretty damn hard.
02-01-2013, 10:07 PM | #764 |
It's the standard steel lines you can get at any auto parts store. I get the straight lines that already have the ends on them then I only have to worry about flaring the ends I cut off. You can get them in various lengths up to 5'. I didn't get the coiled ones because I didn't want to have to get a tool to straighten them.
I use tubing cutter and a flaring tool that will do double flares. You should be able to get them at any auto parts store. Hope this helps Kim |
02-02-2013, 12:27 PM | #765 |
frame looks good kim.
i enjoyed the frame fab portion of my build. not much block sanding on the frame
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-06-2013, 08:15 PM | #766 | |
Kim |
02-06-2013, 08:19 PM | #767 |
Just a little up-date.
Got the rear end all together. I used SS straps to hold the brake lines. Hope to have it in the frame by the end of the week. Here are a few pics. Kim |
02-06-2013, 08:58 PM | #768 |
omg~ unbelieveable!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
02-06-2013, 09:00 PM | #769 |
Nice work!!!!
02-06-2013, 11:44 PM | #770 |
That is super nice...Jim
02-07-2013, 01:41 AM | #771 |
Thanks guys. I appreciate the kudos.
Kim |
02-07-2013, 06:58 PM | #772 |
Well the rear is in.
Next will be the plumbing. Kim |
02-07-2013, 07:05 PM | #773 |
56 - autocross
Hey Kim:
Where did all this energy come from all of a sudden? That looks GREAT! |
02-07-2013, 07:35 PM | #774 |
That is so sweeeeeeet. Who's coil-overs are you running and spring weight??...Jim
02-07-2013, 07:37 PM | #775 |
Certified Car Nut
Look grrreat.lol Nice work buddy.
