![]() Join Date: Apr 2007
Porterbuilt compressor / tank mounts
Just got these from Nate...Know some of you have been lookin for these...setup for 3 gal tank and compressor in Accuair setup......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
Re: Porterbuilt compressor / tank mounts
will these work with the exo brackets also?
Tot Roddin'
Is there an off the truck w/ compressor tank installed pic? If that made sense. haha!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
67-72 parts collector,…
![]() Join Date: Nov 2002
Here's an "installed" pic from Old Aux, with a 3 gallon tank,...
that is really slick
-- 1968 fleetside - nolimit wide ride front and rear + ridetech |
68 C 10
![]() Join Date: Aug 2010
Any info on Pricing for these
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
AIRBAGPARTS.COM
Beautiful Tank...
Tot Roddin'
Thanks Keith. Do you know does that tank run a drain?
I should have my accuair stuff in this week....will look for drain hole....mine were packaged price but I think less than $150....Maybe Nate or Dave will chime in.....thanx for picture Keith.....was trying to get that pic on here.............jim
![]() Join Date: Sep 2012
I just ordered my accuair setup thru dave. It is basically the same money either way because the brackets are 75 ea and the extra tank was close to 100. Total aprox 250. Same as exo mount price but with their 10% off on accuair it could possibly be a few bucks cheaper with exo. All it comes down to is which works for u. I was out there recently and it looks like they did that because of running out of room on that truck.
Posted via Mobile Device |
I agree....just which way U want to go.....these also come with about $30 worth of grade 8 hardware!!.............jim
![]() Join Date: Oct 2012
i looked on PB website for these, could NOT find them.......
I wonder how big there Company would be With a better website.... how much do they cost????
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
#13 | |
We don't want to be the biggest... just the best! ![]() Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Nope. This are not compatible with the EXO mounts.
#15 |
Wide n'Low
![]() Join Date: Jan 2007
Nate,
Can you tell me the distance between the mounting holes for the tank? ![]() I believe I have a 5 gallon and wonder if I can make it work. Thanks!
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#16 |
Right at 9.5". What spread do you have?
#17 |
Wide n'Low
Nate,
I won't know until I get home this evening, but thank you for the quick response. I'm pretty sure (using eyeball differentiation mathematics) that it's the same or very close. I'll post what I have tonight.
#18 |
Nate, you guys are one of the best. Avs
Has a nice website. Posted via Mobile Device
#19 |
![]() Join Date: Dec 2006
These brackets look awesome, just another Porterbuilt part I will have to put on my wishlist. Thanks Nate
![]() Posted via Mobile Device
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#20 |
Wide n'Low
Turns out I have a couple with a 9.5 spread as well.. I'll be sending you a pm soon,
thanks!
#21 |
Man of Mini-Talents
It may not be obvious looking at the pix, but there is a left side box and a right side box. If you order just one be sure to specify which one you want.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#22 |
#23 |
Not exactly sure on the manufacturer, but an aluminum 3-gallon. I have 1 set of the brackets left in stock, and I have the tanks in stock as well in black.
- Travis |
#24 |
I plan to run a pair of RideTech 3-gallon tanks,... because I already have them.
I will have to make them work, since they are on 16.926" centers. http://www.ridetech.com/store/air-ta...-1-8-port.html
#25 |
RideTech does have a 2 gallon tank also,...
