#176 | |||
Registered Mail
Re: Build: I've never done bodywork...but I can change if I have to! (bagged '67 SWB
thanks, it's quite simple really.
thanks Quote:
no, just an old local small town feller. did awesome work at an extremely reasonable rate, but he got old and started forgeting where he put his shoes, yet alone my seat. thanks! thanks, i like the work getting done on your truck!
'67 chev 496, lwb to swb, bagged - pro street project |
#177 |
Registered Mail
well had another long day, got some stuff done, but always seems like its never enough.
wired in the dome light, painted a bunch of black things, like heater box, rad support (which i had to fix for 2 hours before paint), hood hinges, filler panel below rad support. also wet sanded my driver door again (didn't do good enough the first time), well I wet sanded it twice, first with 1200, then with 2000, then compound buff, then polish, so really I have visited these panels quite often... I think we are on first name basis already! I hesitated putting on the passenger door as I don't wanna have troubles putting the seat in, so for now it will have to do looking like a UPS truck. had some progress with the bed, put all the wood on, drilled all the holes and fit it all, then went in and hacked it all up so the tubs and tires would fit and cut a hole for the pumpkin to peek through.
#178 |
Registered Mail
well had some reasonable progress this last few days..
stained and urathaned the oak floor to a nice cherrywood colour, the texture looks a bit rough here, thats because I took the photo before the final sanding and then coated it again twice for a nice smooth finish. here I am working on the wheel tubs/compartment for battery and accuair. here is where I was explaining how I bend the sheets to the right fit, I simply tack it all up and just roll it and tack it slowly as I roll it, then weld in supports after I have the shape.
#179 |
Registered Mail
and here it is all finished! (and functioning) just doing up some filler on the welds for a nice finish. the lid does close flush, I just dont have the fastening bolts installed inthe photo to pull it snug.
I was gonna put gas struts on it, but decided not to, as I don't think this thing is really gonna be open that often, it's plenty strong without any supports, I'll just put a towel down when I do have it open so the lid doesn't get scratched by the floor when it is all the way open, as it can swing wide open. and here are the bed sides...finally painted up!
#180 |
VA72C10
![]() Join Date: Mar 2008
Nice work! Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#181 |
Nice work, amazing actually. I was wondering how the tub would turn out and that is way above what I thought it was going to look like.
Scott |
#182 | |
Registered Mail
Thanks!
i am just finishing up the paint on it today, so either late today or tomorrow I will be putting the box together!! Gonna start looking like a truck soon. Posted via Mobile Device
#183 |
the rear tub hatch looks badass, gunna make things even easier.
great idea keeping everything accessable and bolt on. keeping alot of stock components with a twist
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#184 |
Subscribed. Lookin great
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
#185 |
You could always do a selt belt style material strap that won't let it rest all the way down when you need in there. That way you don't have to worry about putting a towel down.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
#186 | ||
Registered Mail
thanks, hope you enjoy viewing. Quote:
well had been working on it hard the last little bit, got the box all together and put on installed the instrument cluster (temporarily), did the wiring in the engine area, added some fuel and... hit a major milestone at about 11:59 the other night, I got to hear it run for the first time! wowzers!! she is loud without mufflers on, just coming off the headers, and boy is that engine lumpy, shakes the whole truck at idle like a top fuel car (mind you the no exhaust adds more emphasis) was so nervous about putting that tub in, just being on piece, it had such little margin for error on the width, but it just fit right on the money. was so nice to hear it actually run!
'67 chev 496, lwb to swb, bagged - pro street project Last edited by smoknbarrels; 05-08-2013 at 12:42 AM. |
#187 |
That sits pritty low, looks good.
It's a good feeling hearing it fire up for the first time at which seems forever Posted via Mobile Device
#188 |
![]() Join Date: Dec 2006
Truck looks great, nice job on the rear tub
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#189 |
Looks great. I am impressed that you never had done any body work before yet your results are amazing. Also, congratulations to getting her running! that is so much fun after a rebuild and wiring to hear them fire up.
#190 |
Nice job, the truck is looking great.
Scott |
#191 |
motor exploder
Congrats on firing that beast up - your build is coming along nicely. Thanks for all the pics and inspiration!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#192 |
Real nice job, your C10 is coming along nicely. Looking forward to more pics.
#193 |
I hope it's too wet to seed so we can see the finished product, man you are getting so close.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#194 |
Any updates on this build?? You did an amazing job, I would have never guessed youve never done any body work..
#195 | ||||||||
Registered Mail
#196 |
I was just wondering if this thread was still alive lol
Anything new? Posted via Mobile Device
#197 |
You back on your truck yet?
#198 |
so, what has happened lately with this truck?
Have you finished it? ... still in progress? |
#199 |
yea man I'm on the same page as WoodyBoat....whenever you get some time bring us up to date on what you've done...if anything in the past three years bud....we will be patiently waiting for the post =D
#200 |
Registered Mail
well I ended up selling the truck, one day I was frustrated that it was in my way in the shop, and put it up for sale, it ended up selling the next day.. sold it for about .35 cents on the dollar - just in new parts alone. zero for my labour.
obviously I regretted it later, especially since I was so close to getting it finished. but currently I am working on a 66 mustang and a 67 nova, so hopefully I don't get annoyed with those ones as they are a long way away from completion (just picked them up!) I will try calling the young guy I sold it to, he must have finished it as he said it was going straight to a custom shop to get it finished off.. mind you that was a few years ago now..
