12-27-2013, 10:57 PM | #1 |
Chasing leak
Any one use that flex seal clear or black yet.. How is the texture, pros, and cons.... Mainly did it work...
12-27-2013, 11:06 PM | #2 |
Re: Chasing leak
You might want to try to fix it the right way, and/or post the problem before rigging it with TV BS fixes...
12-28-2013, 06:54 AM | #3 |
Re: Chasing leak
I used it to coat my inner wheel wells and inner fenders... So far not too bad. I used it on part of my frame on accident by overspray and it isn't scratched off yet. Some area's have come off due to poor prep on my fault...
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
12-28-2013, 10:17 PM | #4 |
Re: Chasing leak
I have a leak some where by my vent. .. and it could be coming throw my wire loom from door to can. .
12-28-2013, 10:24 PM | #5 |
Re: Chasing leak
Through the wire loom? Seems odd. How would water be getting down there? Is the seal on the cowl in place? And i agree with franken. Do it right the first time and forget it.
12-28-2013, 10:38 PM | #6 |
Robert Olson Transport
Re: Chasing leak
all that stuff is is undercoat marketed well and sometimes in clear.. but again fix it right replace the seal that's leaking
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-29-2013, 11:28 PM | #7 |
Re: Chasing leak
I took passenger kick panel off it looks fine.. basically just going to start pouring some water down the front and side, hopefully see where it's coming from..
12-30-2013, 12:44 PM | #8 |
Re: Chasing leak
Probably the kick panel gaskets. Then again, I had the same phantom leak and it turned out hat the corner of my windshield frame was rotted
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
01-02-2014, 08:32 PM | #9 |
Re: Chasing leak
I left it outside in the snow so I can see a leak and this is what I end up with. .some how moister is getting drawn up through the floor pans... any one ever see this happen ..
the other side is bone dry. . |
01-02-2014, 09:10 PM | #10 |
Re: Chasing leak
How can I fix it.. Can I just use some rust prevention paint
01-02-2014, 10:13 PM | #11 |
Re: Chasing leak
steel doesn't let moisture come through it unless its rotted it is coming from somewhere above prolly in the cowl or where there is a hole in the firewall or something.... keep checking
01-03-2014, 12:17 AM | #12 |
Re: Chasing leak
open the hood and look at the cowl area. anywhere that crap and water can sit
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
01-03-2014, 11:14 PM | #13 |
Re: Chasing leak
Ok I took off the cowl and looked at every thing... So I poured water down the side and bam water ran right out the air vent.. I think I got it fixed... If not this time ,I'll just block it off..
