Old 03-12-2013, 10:52 AM   #76
AGearHead4Life
AGearHead4Life's Avatar
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
subscribed. hopefully you guys come back with updates.
I did the C5 swap on my 3rd gen Camaro and would love to do the same on my C10.
AGearHead4Life is offline   Reply With Quote
Old 03-12-2013, 11:55 PM   #77
maxxxy
maxxxy's Avatar
I Did the Camaro 1LE rotor swap on my truck. I Had a set of wheels in the 5x4.75.
Before and After:
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 03-13-2013, 05:35 PM   #78
gringoloco
A guy with a truck
gringoloco's Avatar
Confirmed. Nice work! The C5 swap works,too. I have them on my 70 (in sig)
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-18-2013, 10:47 PM   #79
BULLITT65
BULLITT65's Avatar
gringoloco, thanks for posting those pics what are the 2 bolt patterns on your rotors?
I have a curve ball for you guys, I have a 64 C/10 and I want to run a 5 x 4.5 bolt pattern wheel!! Yes this is the anti-christ of ideas, it happens to be a Ford wheel, but almost nobody will identify it as such. I plan on running a Ford 9" in the rear so I think I have a handle on the rear. ANY HELP HERE??
BULLITT65 is offline   Reply With Quote
Old 04-02-2013, 08:11 AM   #80
khan1369
khan1369's Avatar
k... this thread gets a little confusing... I have some drop spindles on my truck installed by the PO. not sure what the brand is. The front is disc brakes though... Can I put the g10 rotors directly on the spindles I have now? I am pretty sure that the G10 spindles use an A3 outer bearing and an A5 inner bearing. I am trying to confirm that now, and its driving me nuts. Also, what does height mean on a rotor?
"Live, Love, Build cool s***"
Jesse Chapman, 2013
My Truck..
http://67-72chevytrucks.com/vboard/s...d.php?t=567219
khan1369 is offline   Reply With Quote
Old 04-02-2013, 08:26 AM   #81
SCOTI
SCOTI's Avatar
C10's, G10's, Caprices (& many full size GM cars), & Camaros w/the 1Le option rotors are all approx 12" OD.
The difference is in the thickness of the rotor. The 1.25" rotors are considered HD & use one combo of bearings. The 1" rotors are considered lt duty & use a diff combo of bearings. The trucks utilized each type of rotor by using different spindles & brake assemblies (vans were the same deal).
Aftermarket drop spindles are available for each brake type (HD & lt duty). You have to have the lt duty spindle to swap off the shelf car pattern rotors. To determine if you have the right spindle, measure the thickness of the rotor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-02-2013, 08:32 AM   #82
khan1369
khan1369's Avatar
thanks SCOTI, that helped a bunch. I love my drop spindles, and I don't want to have to change spindles and springs to get the same height... while searching for rims I have found it a bit difficult to find 5x5 rims I like for cheap.. and I wanted to run the 2010 camaro steelies. I guess I will just find another cheap rim.
Jesse Chapman, 2013
My Truck..
Old 04-02-2013, 08:46 AM   #83
khan1369
khan1369's Avatar
hmm. with 81+ c10 lt duty brake drop spindles, what calipers work? the c10 or the camaro or both?
Jesse Chapman, 2013
My Truck..
Old 04-02-2013, 09:08 AM   #84
SCOTI
SCOTI's Avatar
More than likely both but I would spec them for a lt duty C10 since that's a no-brainer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2014, 11:30 AM   #85
mattcrp1
mattcrp1's Avatar
Hi all I know this is an old thread, but I have a question. I have a 76 c10 with the 1.25" rotor. I bought a set of used drop spindles that appear to be for the LD 81-87 truck. Both my inner and out bearings do not fit the spindle. The grease seal appears to correct. My caliper, that I just rebuilt, slides into the "pocket" of the spindle and appears that i would bolt up. My question, is this a simple change of rotors and bearings? Or am I going to need the later calipers as well, possibly brake lines too?
I am not opposed to going to the thinner rotor, I just want the least hassle. Money is an object but safety is a bigger factor. If I have to get the HD spindle I will, but if I can make this work for less I would like to go the direction I am headed.
Thanks,
Matt
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 01-26-2014, 11:47 AM   #86
mattcrp1
mattcrp1's Avatar
I think I should add that the outer bearing will not readily slid onto the spindle. The spindle itself has GM T cast into it as well as N357-87.
IG mattcrp1
Old 01-26-2014, 12:34 PM   #87
lolife99
67-72 parts collector,…
lolife99's Avatar
Spindle, bearings, caliper and rotor ALL have to match.
So if you have 1.25" rotors now,... EVERYTHING will have to be switched to work with the Light Duty spindles.
Keith
Convert to disc brakes.
Old 01-26-2014, 02:30 PM   #88
mattcrp1
mattcrp1's Avatar
Thanks for the response, I will find the correct spindle and keep it simple.
IG mattcrp1
Old 01-27-2014, 11:13 AM   #89
broey
Square
broey's Avatar
i just had a machine shop re-drill my rotors and shave down the outer part of the hub a little bit, cost me 20 bucks to switch to 5x4.75 in the rear i swapped the axle for a 80's camaro. super easy.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-30-2014, 11:15 AM   #90
AGearHead4Life
Originally Posted by broey View Post
i just had a machine shop re-drill my rotors and shave down the outer park of the hub a little bit, cost me 20 bucks to switch to 5x4.75 in the rear i swapped the axle for a 80's cmamaro. super easy.
Wow, That easy huh... cool.
Old 01-30-2014, 11:24 AM   #91
AGearHead4Life
Originally Posted by SCOTI View Post
The rotors on my 74 were re-drilled to car pattern & the snout of the hub was turned down to car pattern as well (they were stock Raybestos GM 1/2 ton 1.25" 5x5 rotors). They've seen daily use since '02 w/no issues (been turned one time).
The use of 1LE rotors on LT duty truck spindles would work for a limited use application. But one of the first upgrades made to F-bodies is bigger/better brakes (rotors) that don't warp as easily as the stockers would/could.
I guess this guy had already said it was that simple. Been a while since I've read this thread.
Old 04-05-2014, 10:53 AM   #92
Flatpat
Flatpat's Avatar
Is it possible to adapter hubs like these to work?
http://www.flynbye.com/catalog/i225.html
Or maybe the Kore3 version?
Flatpat is offline   Reply With Quote
Old 04-05-2014, 10:58 AM   #93
Flatpat
Flatpat's Avatar
Like these?
http://www.kore3.com/proddetail.php?prod=10038-F3
Then we could use the slip on rotors?
Old 04-05-2014, 07:33 PM   #94
SCOTI
SCOTI's Avatar
Like these?
Sure it's possible. KORE3 makes (made) a billet C10 hub w/5x5 & 5x4.75 pattern (I have a pair) that went on the HD 1.25" version spindle. Problem is the cost as most people doing this are tring to do it on a low budget.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-28-2015, 08:43 PM   #95
vettemad
[QUOTE=502tripower;3031272]Now we all know that the 73-87 front crossmember and suspension components can be swapped into the 60-72 trucks. The 73-80 Chevrolet C10 pickups used a 1.28 rotor. Then in 81-86 GM switched to a 1" rotor. I did a bit more digging and found that the calipers are different for the 1" rotor but use a common bolt pattern with 73-80 so, it looks as if the 91 Camaro rotor will work on the 73-86 spindles if the 81-86 calipers are used as well. Also the flexible brake line will need to be changed if you have the 73-80 caliper as one of the calipers uses American standard thread and the other uses a metric thread. The parts house could not tell me which one used what thread but that they were different. I will figure that out when I purchase the parts. I have not done this yet but it does look like it will work. fones1966 a member here PMed me telling me about this possibility and I want to thank him for that. I just thought I would post this information in case there were others that could use it. Olympic Brake here in Washington is who provided this information. One note I want to point out is the specs that I have all show the same bearings on all three rotors. I was told by fones1966 that the 73-80 1.28 rotor used a A-5 inner bearing so that bearing would have to be replaced when switching to the Camaro rotor but, what I found was the 73-80 heavy duty 1.28 rotor used the A-5 inner bearing and the 81-87 light duty rotor used the A-6 as shown in the specs I have provided. I hope this information is helpful. Here are the specs on both the truck and Camaro rotors:
73-80 Truck rotor specs are:
Height 4.88
Diameter 11.85
Min. Thickness 1.220
Hub 3.06
Outer bearing A-3
Inner bearing A-5
Seal Part # 8871
Bolt Circle 5X5
81-86 Truck rotor specs are:
Height 4.63
Diameter 11.86
Min. Thickness .96
Hub 3.20
Outer bearing A-3
Inner bearing A-6
Seal Part # 8871
Bolt Circle 5X5
91 Camaro 1LE Performance Package rotor specs are:
Height 4.65
Diameter 11.85
Min. Thickness .97
Hub 2.78
Outer bearing A-3
Inner bearing A-6
Seal Part # 8871 ok....I know this post is old and I'm gonna ask for info outside of this forum but any possibility of swap knowledge or ideas could help....I want to convert my 1996 tahoe 2wd to 4.75 bolt pattern up front and run a 96 corvette IRS in rear....looked at camaro rotors no good and several more....any imput here would be welcome...Thanks, cliff
vettemad is offline   Reply With Quote
Old 08-14-2016, 03:38 PM   #96
c10-72 II
Active Member
c10-72 II's Avatar
i know this is an old thread but, does anyone have the part number for the drop spindle or stock spindle for the 81-86 c10? when i look them it it just shows 73-87. i looking to do the 81-86 spindle with the camaro 1LE rotors. thanks
c10-72 II is offline   Reply With Quote
Old 08-14-2016, 04:51 PM   #97
lolife99
lolife99's Avatar
Belltech 3200 drop spindle.
These work with all 73-87 balljoints and tie rods, but you have to use the 1" width rotor.
https://www.summitracing.com/parts/b...0/applications
Keith
Old 08-14-2016, 05:09 PM   #98
c10-72 II
Active Member
c10-72 II's Avatar
cool thankyou
Old 08-27-2017, 05:56 PM   #99
BULLITT65
BULLITT65's Avatar
Originally Posted by gringoloco View Post
Got some parts today-early measurements say it's gonna work More to come...
Sorry i know this is an old post. But are these pics you posted, the 1LE rotors you are refferng to ?
Can you provide a part number for them. I have a 66 chevelle and my current rotors make the front wheels sit to close to the fender lip, these low profile rotors look like they could solve my problem. will they work with the stock calipers?
thanks
Old 08-28-2017, 12:21 AM   #100
gringoloco
A guy with a truck
gringoloco's Avatar
thanks
Those are billet hubs from kore3 used to adapt C5 brakes to our trucks
-Chris
