03-14-2014, 07:36 AM | #1 |
Sharing my bump steer fix with this Great community of truck nuts!
I know there are a lot of post and information about bump steer on our trucks that have been lowered with coil springs. Specifically ones like mine that have been lowered with 3" shorter springs only. I tried this solution on my truck and after 500 miles of driving I am very happy with the results.
I could not find a set in stone solution to this problem, so I wanted to share this with everyone because I am very excited how much better this thing drives now. Bump steer in my case has been eliminated. In a nut shell, I moved the outer tie rod ends to the bottom side of the arm on the spindle. Because of the cost of a tapered reamer, (not to mention exactly what taper is the tie rod end anyway), and the problem of having to add some type of tapered sleeve to take up the void when flipping tie rod ends and not enough meat at the arm of the spindle to do all of the above, this is what I did. 1. Replaced the adjusting sleeve with a solid adjusting link. 2. Replaced the outer tie rod end with a Heim joint. 3. Drilled the tapered hole in the spindle with a 5/8 drill bit to accept a 5/8 bolt which is the size of the Heim. 4. Reset the toe and Wow! what a difference it made. Here are the P/N's of what I used. I found all of this stuff at Speedway Motors. 1. 91001449 JAM NUT 11/16 LH PLAIN, it takes 2 of these. 2. 91001249 JAM NUT 11/16 RH PLAIN, it takes 2 of these. 3. 91634-10.75 LINK,11/16",RAW, this is the adjusting sleeve and is 10.75 inches long, and it takes 2 of these. 4. 1750128 11/16"RH HEIM W/5/8" HOLE, it takes 2 of these. 5. You also need the 5/8" grade 8 bolts, washers and nuts. All of these parts worked on my 1971, The new adjusting sleeve is designed to fit the stock inner tie rod end thread pitch and the outer Heim fits the other end. The only modification to my truck was drilling the spindles tapered hole to a non tapered straight 5/8 hole. As I mentioned above I have been 500 miles so far with no problems and a very fun to drive lowered truck!!! |
03-14-2014, 07:23 PM | #2 |
Re: Sharing my bump steer fix with this Great community of truck nuts!
Very nice. The alignment shop I had my burb at tried telling me they needed to heat my tie rods and bend them to correct the bump steer. I like your way better
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-15-2014, 06:48 AM | #3 |
laying low
Keeping the steering linkage horizontal minimizes bump steer and you have that corrected ok. For an occasionally driven truck the heim end may work out very well. I have to wonder just how long it would hold up under a daily driven truck since it has no dust cover or lube to keep it smooth.
I would most certainly drill that bolt and put in a cotter pin too.
03-15-2014, 07:06 AM | #4 |
subbed
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-15-2014, 07:45 AM | #5 |
Old member
Yea I would be putting a cotter key in that bolt for sure. The hem's should be OK, but a little oil are grease on them every so often wouldn't hurt I guess. You can buy them with zerk fittings for grease. Here is the 5/8" from Speedway.
http://www.speedwaymotors.com/AFCO-1...ale,41039.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-15-2014, 08:35 AM | #6 | |
72MARIO Thanks. I wouldn't want to heat and bend those either. Andy4639 I sure didn't see the heim with the zerk fitting when I bought mine. Great idea though. Thanks |
03-15-2014, 08:45 AM | #7 |
Nice set up. How much do you have invested in it?
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
03-15-2014, 09:02 AM | #8 |
The 2 heim's, 2 adjuster sleeves, and 4 jam nuts were around $110.00 The 5/8 bolts, washers and nuts were bought local and I can't remember the price on those. And I am able to do the alignment at work, so no cost there.
03-15-2014, 09:09 AM | #9 | |
03-15-2014, 09:50 AM | #10 |
I have a radical idea!
I ran custom adjustable lower control arms and panhard bar that I built on the rear of my '82 Z28 for years with heim joints and they held up well. I was also skeptical of their lifespan on a regularly driven vehicle, but they did really well. The only issue I had with them was the noise. Are your's quiet over bumps, etc.?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-15-2014, 11:42 AM | #11 |
67-72 parts collector,…
Great idea,... but that big flat washer on the bottom is going to affect the pivot ability of the heim end as the suspension compresses.
I suggest running the "misalignment spacers" on either side of the heim and to use a lock nut. Check www.rodendsupply.com for the spacers. Here is another picture I found, of a similar fix, on these year trucks.
03-15-2014, 12:02 PM | #12 | |
this guy knows!!! we do this on our race cars and its really very simple to do, but you do need these washers and lock nut and you be ready to go! |
03-15-2014, 03:19 PM | #13 | ||
03-15-2014, 04:10 PM | #14 |
Does anyone have the part number or size for the misalignment spacers? This thread is awesome!!
Neil............... 1972 C10 SWB - Shop Truck in the Works 5.3 LS / Full Air Ride / Rear Notch 20" American Racing Daytonas IG - neilioustx - pictures of build/progress Born and Raised in the Promised Land.... TEXAS Y'ALL!! |
03-15-2014, 04:16 PM | #15 | |
Page 17: http://rodendsupply.com/RodEndSupply-Catalog.pdf
03-15-2014, 08:55 PM | #16 |
i have a bumpsteer kit from steeda on my mustang and its not grease-able..i drive the **** out of it daily its been on there for about 20k miles no problems. I have heard of one person having theirs break in all the searching i have done...someone said that a guy with a bmw broke his before around a turn. it happened on a track car and i dont know what the manufacturer was. i dont think its any less strong than a normal tie rod end.
03-15-2014, 09:48 PM | #17 |
Couldn't someone just machine a tapered sleeve to insert into a drilled spindle that fits the original tie rod so you could just turn the tie rod upside down on the spindle in effect reversing the taper? Follow?
03-16-2014, 08:36 AM | #18 | |
I took a close look at drilling the tapered hole from the other side of the spindle and flipping mine but there would not be be much of a tapered hole left. I could not come up with any good solid solution when trying to flip the actual tie rod. |
03-16-2014, 08:46 AM | #19 |
I was thinking something like the tapered washer thingy's on the top knuckle of a Dana 44 4wd front axle steering arm. Maybe those would even work? I really like your setup- I'm just cheap-and already have New Moog ends, So I'm trying not to toss them in the corner.
03-16-2014, 09:35 AM | #20 |
Do they make the rod ends with a insert[bushing] of some kind for street use. I seem to recall when i was messing with those wallet draining drag cars that when you put the 4 link stuff in the back you could opt for different rod ends with some sort of insert the name escapes me now but it was to help a small bit on noise and with the other slight issues that might arise with daily use of driving a car/truck with rod ends on it. Jim
03-16-2014, 02:45 PM | #21 | |
Sam >> http://www.speedwaymotors.com/Seals-...t-6,33063.html << |
03-16-2014, 07:26 PM | #22 |
Speedway also sells the cone spacers.
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
03-16-2014, 09:05 PM | #23 | |
What cone spacers?
03-16-2014, 10:13 PM | #24 |
This just keeps getting better and better! Thank you to all of you for the input. Those seals are going to be the icing on the cake.
03-17-2014, 08:56 AM | #25 |
the big washer on the end of the stack is still a good thing to have to keep everything together if the ball and socket comes out of the joint....I know, I've crashed a few race cars....
1970 short step c10 leaf spring 454 |
