#301 |
Re: 1954 3100 C4 Tube Chassis Build
looks real good, engine mounts are a good idea, nice to think a head. I often make stuff a bolt on application just for that "incase" factor. For instance my running board brackets, I welded some tubing to the frame that the brackets bolt to, so they aren't in your way all the time on the rolling chassis. Maybe something to think about for yours.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#302 |
![]() Join Date: Apr 2010
Looking killer Josh.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#303 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Thanks guys, made some progress on the cab today. Got the inner and outer cowl panels and firewall cut out and fit all new stuff. Big props to Dynacorn for the best fitting patch panels Ive ever seen. Here are some pics, more to come once its all welded up.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#304 |
O yeah, dont be hatin' on my home made cave man like press brake!
#305 |
lol
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120 1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806 1966 C10 SB Custom Cab, Fleetside, BBW. 1968 Chevelle SS 396 1937 Chevrolet Coupe |
#306 |
![]() Join Date: Jul 2012
Nice! The press brake looks like it is doing the job.
#307 |
![]() Join Date: Jun 2011
This build is a BAMF! Seriously considering this as an option now for my 53.
#308 |
Sorry Ive been so slack lately. I have however made some small progress. I cut out all the fishplates I needed to strengthen the joints in my chassis over the axle. Also ordered my rear coilovers from Flat Out. Now I need to decide how to mount them. I thought Id seen guys putting them on the factory Corvette shock stud on the spindle but not sure about that. Anyone whose done the Vette rear have any opinions on this? Thanks guys. Hopefully some progress pics soon.
#309 |
Still Learning
Very nice work on the cab Josh. Looking good.
#310 |
Thanks Mike!
#311 |
I have not done it yet, but been doing a lot of research. I noticed that they are mounted to a bracket that spans between the shock bolt and upper dog bone. Look closely at the pic on flat out's website.
#312 |
I've seen that bracket as well. There is also a small bracket available that mounts only to the spindle where the shock stud mounted. I'd think with no more weight on the rear of a truck than there is it'd be ok? Seems to be a popular option on a lot of the road course web sites I've seen.
#313 |
Looking great man. Looks like I'll be doing a vette suspension under one of these this winter. I'll be referencing your thread for sure!
#314 | |
#315 |
I'm sure the mono spring would be ok, but won't let me adjust as much as I want. I'm definitely using the coil overs.
#316 |
I'm definitely ditching the monospring, too. What I meant was to fabricate a bracket that attaches to the knuckle where the monospring attaches vs. using the shock mount. I haven't looked at it close enough to see if there is clearance behind the half shaft.
#317 |
That point is waaaay too high though. I'll get back on it next week sometime.
#318 |
Im planning on putting a C4 IRS in my 95 C1500. Im going to fab a cantilever behind the suspension somewhat like a KP 6-link and attach at the stock spring mount. I'll most likely use an airbag too, but its not necessary.
#319 |
Stockish, I see what you mean about the spring mount being too high. I found this closeup pic on the net:
http://www.customclassictrucks.com/t.../photo_28.html ccreddell, I'd love to see how you do this. LFD's Tahoe build did a bag behind the axle, but it's not cantilever. |
#320 |
Just out of curiosity, why a cantilever setup? That is designed to keep the axle centered under the truck during suspension travel. You dont have that issue with an IRS setup so it seems like a lot of extra work. Youll still need to solid mount the batwing and trailing arms so Im not sure what the cantilever would even do except just sit there, look cool, but have zero function.
#321 | |
![]() Heres what they look like on a truck. [IMG] ![]() You could put a coil over there in place of the bag. Or you could put a coil spring in there and run the shock in the stock location. |
#322 |
I dont understand how thats supposed to work with a C4 IRS though.
#323 |
Im not sure what to tell you. Either youre not familiar with the C4 IRS, or Im not being clear enough. Maybe this pic will help....
[IMG] ![]() Here it is hooked up. [IMG] ![]() And here it is from the top. [IMG] ![]() Last edited by ccreddell; 08-29-2014 at 05:54 PM. |
#324 |
at first as I look at that setup, I wonder, how conflicting it might be. But.... there are guys running it. http://www.s10forum.com/forum/f125/i...n-here-429547/
I didn't even look too far into it, if your not bagging it, I think its overkill.
#325 |
I'm still in the planning stages of a 57 GMC with 1996 C-4 both front and rear suspension. I'm calculating how much to remove form the vette fiberglass leaf so I can use a shockwave shock.. I figure use the original design, adjust the mounting points for the shockwave and have the leaf carry about 60-70% of the weight and have the adjustibility from the air system, you know adjust on the fly and all. Just thought I'd through more gas on the fire..
Been there, wrecked that ![]() |
