09-10-2014, 07:01 PM | #1 |
Welding v-bands on truck manifolds
Looking to see if anyone has modified a set of truck manifolds from flanges to v-bands. I'm mostly looking for info on the weld of it, and if its something that needs per and post heating like older cast iron manifolds.
09-10-2014, 07:12 PM | #2 |
Re: Welding v-bands on truck manifolds
I have done them with no pre/post heating. The LS manifolds are like a cast steel and actually weld pretty easily.
Way easier than an old cast iron manifold! I know Wasted Income has also welded some vbands on his. Maybe he will chime in.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
09-10-2014, 07:23 PM | #3 |
I read a bunch of threads on LS1tech because I am going to do mine (eventually)
Without pre or post heat it was a mixed bag. Some people had them crack some didn't. Everyone that pre/post heated didn't have them crack. I plan on pre post heating mine when I get around to it.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
09-11-2014, 12:04 AM | #4 |
Always a work in progress
I pre and post heated, mig-welded and I haven't had any issues.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
09-11-2014, 11:01 AM | #5 |
Boosted Member
I preheated mine, and they've been perfect. I agree with boostedC10 that they weld more like steel than iron....it's like GM knew what we'd be doing to these poor engines...lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
09-11-2014, 12:26 PM | #6 |
i cut my flange and rotated it to fit the frame rail on the driver side. Gave it to my buddy to take to work where he could preheat it and weld it with inconel filler. When he gave it back he said he welded it with mild steel and i'm not sure he even had to preheat it. I have been driving the truck for over a month now (heating and cooling) and not had an issue knock on wood!! If that was truely the case i could've done it myself with my MIG..
09-11-2014, 01:47 PM | #7 |
Boosted Member
I was able to weld a stainless elbow to the manifold to avoid the master cylinder, and it's been holding up great, through much abuse.
09-11-2014, 08:04 PM | #8 |
Thank for the info guys, it's looking like per and post heating is the way to go but what are you using to heat them? If your using a oven I can only imagine the GF's reaction if she fond my cooking car parts lol.
09-11-2014, 08:30 PM | #9 |
I plan on using my oven hahah. I have seen people welding cast iron use BBQ's, Fire pits, OA torches, etc. Then either let the fire die down or wrap the part in a welding blanket and cover it in sand.
09-11-2014, 09:55 PM | #10 |
I MIG welded my manifolds without pre/post heating and they have held up just fine. Ive got over 5k miles on my build now.
1968 C10 5.3/4L60E LS6 cam and a 3600 stall 1968 Camaro 6.0/4L65E T76 turbo 9" 1960 Impala LS1/4L60E all stock cruiser |
09-15-2014, 09:01 AM | #11 |
Boosted Member
My wife gets a little pissy when she comes home to car parts in the oven.
09-15-2014, 09:10 AM | #12 | |
I tell ya...some women!
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
09-16-2014, 10:49 PM | #13 |
Is there a specific temperature range that the manifolds need to reach for the pre/post heating?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
09-17-2014, 12:38 AM | #14 |
meowMEOWmeowMEOW
just take a rosebud torch and heat the general area for 5-10 minutes before welding. I'd say your in the 4-500* range. Most guys I know that do them in the oven set the oven to "clean " which is max or usually 500*.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-17-2014, 08:31 AM | #15 |
Thanks. I figured they'd probably have to be pretty hot.
