Old 10-19-2014, 08:30 PM   #26
Re: My 1961 crew cab- XRMYCRU
Nice!! Can't wait to see what you do with it.
Old 10-19-2014, 09:37 PM   #27
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Is that not a standard vinyl mat for foyers into businesses or industry? I'll swear I've purchased a similar runner at Home Depot, but not as wide as you require.
allmats.com
americanfloormats.com
industrialrubberresource.com
Thanks for posting all the pictures. Nice of you to share the details.
Why red under the headliner?
The outer roof panel is in 3 pieces or 2?
thanks for the links I will check them out.
the red is a red oxide primer that the coach builders put on , a couple different pics I have of other c/c's show the same primer
the outer roof panel is 3 pieces : the front and back shaped "C" channels keep the roof shape. the 2 side pieces form a square, the og roof is folded at a 90 degree angle over the "C" channel front and back, some fabricated side pieces run from the rain gutter to the brace , and are folded over as well, then a square piece with the edges folded around it at a 90 degree angle is inserted, and all the inside edges are welded up. I do not know if the piece is welded on the top too, or if the seam is just filled in with lead. the way it has bubbled up around the seam I feel that it is probably not welded on the outside.
Old 10-19-2014, 09:58 PM   #28
jonzcustomshop
1961 crewcab
today I did a little more cleaning , and more investigating, I was able to get the left rear door panel off, and checked out how it and the door were built.
the inside door handle was frozen to the mechanism , and I ended up cutting the handle apart with a cut off wheel, because I did not want to pry against the door panel.
the coach builders used a lot of lead on the doors and jambs.
the coach builder cut the cab in 1/2 at 29 inches from the front of the rocker, or 12 inches measured from the back.
they bent and fabricated a sheet metal piece for the floor, the inner rockers were a separate piece. by holding up one of my rocker patch panels I could see how they were probably able to use just 2 extra rockers in their build, cutting them in 1/2 and then using the back on the front, and the front on the back. this is the piece that is completely gone on the passenger side, and dented into oblivion on the drivers side...
the center pillar is made from an extra rear door pillar, then an extra front roof pillar at the top, and thick piece of plate steel on the bottom, the whole thing is slathered in lead.
I got to measuring on my 2 cabs with good floors. and it looks like I have all the stuff to start cutting and pasting...
still thinking on the best method for the roof: duplicate what they did? use this roof skin and fix it?... I'll keep you posted....
** notice in the pic, all the leading and welding being done... they did not weld up the 2 factory holes for the vin tag on the replacement pillar they used to create the rear jamb... I am seeing lots of this kind of stuff... maybe because this was just for an army contract, it was just rushed together with not much attention to detail. * also notice the rough unfinished file marks in the lead on this door..
Old 10-19-2014, 11:45 PM   #29
duallyjams
duallyjams's Avatar
All CC should be dually's, well in my little world.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-20-2014, 01:08 AM   #30
Captainfab
60-66 Nut
Sorry to see you have so much work to do Jon
But if anyone can get it done you can.
Thanks for all the detailed pics on how these were made....quite interesting. I think there wasn't much attention to detail on the CC's because most of them were genuine work trucks. As long as they functioned and looked presentable, that was good enough.
Do you have any parts Suburbans or Panels in your area that you could scavenge some replacement parts from?
Old 10-20-2014, 10:55 AM   #31
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
A Suburban/ Panel truck roof has a different curve to it at the front but has seperate ribs to support. I wonder if the roof wing section of a regular cab mates to the raised section and curve of a burb roof?
Old 10-20-2014, 11:27 AM   #32
Grizz1963
Grizz1963's Avatar
You are a brave man.
However, I can see the attraction of the truck, despite its condition.
This will take a while, but I am sure it will all be good in the end.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 10-20-2014, 11:56 AM   #33
Clyde65
Clyde65's Avatar
Congrats on the find!
I know the crews were kinda sloppily put together, at least that is my take on them, I have seen a few and when dad got his, it wasnt done " cosmetically to please anyone".
I know yours will be a nice job!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-20-2014, 01:55 PM   #34
64chevycrewcab
I miss it already lol, glad your going to get it back on the road.
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Chevy Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
1966 GMC 4X4 Suburban
64chevycrewcab is offline   Reply With Quote
Old 10-20-2014, 02:26 PM   #35
piratexpress1369a
piratexpress1369a's Avatar
nice find ...this will be a hell of a job.
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-20-2014, 10:28 PM   #36
jonzcustomshop
1961 crewcab
the 'burb roof is just completely different, it is much taller, I did take a look at the 'burb headliner supports to see if I could use them, but I think they have a taller arch.
the 'burb roof even has a different shape next to the rain gutter, looks similar to the truck, but different.
I do have several roofs that I can part out, I did more studying of the roof today, to see what I want to use, and what gets replaced.
Old 10-20-2014, 10:31 PM   #37
jonzcustomshop
1961 crewcab
hopefully sooner than later, I am getting on this cab repair soon, and after that the rest should be cake!
Old 10-20-2014, 10:53 PM   #38
jonzcustomshop
1961 crewcab
this photo I have of a crew that was for sale in calif. a few years ago, is probably exactly what mine looked like before the state of Montana yellow that was brushed on over the green..
this is a 61 short step 6 cylinder 3/4 ton, even the door mirror bracket is the same.
if I look real close at my driver door I can see the faint raised edges of the "us army " logo, and also the "IG", and a 8, or a 3.
A friend of mine mentioned that when the army was done with these, they went into a pool, and states could get first dibs, so my truck could have been from anywhere before Montana got it... however I assume it was probably a western base.....
any of you military guys know what the "IG 8373" stood for? was it just a #, or does it tell the base too?
Old 10-21-2014, 12:18 AM   #39
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Here you go Jon, A 1961 C20 Crew Cab Step Side in yellow. Not sure what your plans are for color?
66Gilbert is offline   Reply With Quote
Old 10-21-2014, 05:32 AM   #40
My guess is that it was more than likely assigned to an Inspector General crew. The number was probably their unit number. I believe that is how ours were in the Air Force in the 70s, so I would think the Army was similar.
Old 10-21-2014, 08:17 AM   #41
Clyde65
Clyde65's Avatar
I agree with Palf70Step. Inspector General and unit #.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-21-2014, 11:07 PM   #42
66Z71
66Z71's Avatar
Awsome find. I will be following this one. I picked up a suburban roof to use on the one I started.
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 10-21-2014, 11:42 PM   #43
CheyenneShop
CheyenneShop's Avatar
So cool, can't wait to see what you do with it.
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 10-21-2014, 11:54 PM   #44
tinydb84
tinydb84's Avatar
Man that is a lot of work! I'm sure it will be awesome when you are done with it!
David
Instagram: myfabguy
Old 10-22-2014, 04:22 PM   #45
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Congrats on a cool find and good luck with the build.
ksbrktracer is offline   Reply With Quote
Old 10-22-2014, 05:22 PM   #46
3 On Da Tree
I curious.
What end are you going to start on?
3 On Da Tree is offline   Reply With Quote
Old 10-22-2014, 07:59 PM   #47
jonzcustomshop
1961 crewcab
Originally Posted by 3 On Da Tree View Post
I curious.
the rear 1/2 will be first, I can cut the rockers long on the donor cab, and they will just fit under the center pillar, and to the front of it about an inch.
then when I use the front cab donor I will be able to use the full rocker with out cutting it... that is the plan now for
got the front clip off today, and did lots more eyeballing to see how I will go about this...
here is the back 1/2 donor (literally!) cab, box, axle!
Old 10-23-2014, 09:47 AM   #48
aerotruk63
aerotruk63's Avatar
You'll have to keep track of how many trucks it takes to make this one!
Old 10-23-2014, 10:09 AM   #49
jonzcustomshop
1961 crewcab
haha, its gonna be a few, believe it or not , that green 61 short step was a good purchase, it came with a few good parts from a 60 long step, and I will be using quite a bit of that, and the good stuff off the 61...
Old 10-23-2014, 10:47 AM   #50
pope
pope's Avatar
Glad to see that you made it home safely with it!
Where the hell did my coffee cup go?!!
pope is offline   Reply With Quote
