Tie Downs in bed?
I was getting ready to redo the inside of my bed.
I was wondering if anyone has tried to add tie downs to there bed similar to what a new truck has? Pics would be good Thanks |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Tie Downs in bed?
Maybe not what you're after but GM offered accessory tie-downs that slip into the stake pockets...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Heres what i used, although i wish i would have maybe welded somthing lower in the front to hold shorter things like coolers and such.
![]() Plasi-dipped ![]() ![]() ![]()
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
sboris,
Where did you find these? I was thinking of something similar but replace some of the bed to floor bolts with these so that the points will be lower in the bed. This would also allow them to be removed if needed in the future. |
Picked these up at Northern tool. Kinda pricey, but it was exactly what i visioned. And i had a gift card
![]() Join Date: Sep 2010
I put five eyebolts on each side of my 70's floor ( on the metal lip ) . . . . . . you can " kinda " see them in these pictures: . . . . |
Good idea. Will help to keep stuff from scratching up the floor. Post a link for those please.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Good idea on those Steve. Something I could probably add..
The eye bolts in the floor are a neat idea! Would that work for a stepside bed? I'm trying to find a tie-down option that doesn't involve drilling into the metal bed walls.
I used these stainless marine tie downs
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#14 | |
Below, are some I've seen in stepside beds: ( you just have to take an original bolt out and put the eyebolt in it's place ) . . . . |
#15 |
i have been thinking of insettng these into my bed
#16 |
Here's another kind I've seen: . . . . |
#17 |
I filled the smashed stake holes in mine , but added threaded inserts in each corner before filling , then the same in the bottom four corners , each a 3/8 long nut , welded to a floor cross member below , and the side of the pocket up top.Did it again in my 68 gmc , Won't even think twice about doing it to the 69 I'm doing this winter. I'll take pics later if you would like - Bob
#18 |
Excellent thread! I like a good looking truck but nothing I own is for "show only." Even my competition pistols must be "combat ready."
#19 | |
#20 |
Alot of good ideas here.
#21 |
Agree. The "marine" pieces are a nice fit.
I have design/release responsibility for the K2XX pickup box so I'm gettin' a kick out of this thread. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#22 |
#23 | |
#24 |
I had a friend that used U bolts in the bed of his dodge, drilled them through the bed supports, and then dropped them in, installed the nuts, and tack welded the nuts. They sat flush with the floor and then you could just pull them up with your finger and hook a tie strap to them. They were great, simple, and cheap.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
#25 | |
