#151 |
Re: 68 c10 6.5 turbo diesel
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
#152 |
Got some work done. I finally got the Fluid Damper and installed it. Crank pulley is installed so is the fan and the spacer. My buddy machined this spacer to my specs to get the fan were I wanted it. The spacer also adapts due to the wp hub being 3/4's and the fan pilot is 5/8's he made it very precise. I got the belt ran finally so that wraps up the front of the engine. I mounted the oil fill with new grommet in timing cover. I also welded a v band flange to the top intake and installed it. I have the ceramic coating for the exhaust manifolds I still have to finish them. I also installed the timing tab.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 Last edited by marvgarr68; 11-15-2014 at 10:46 PM. |
#153 |
Some more pictures.
#154 |
I also got the steering all wrapped up.
#155 |
6>8 Plugless........
![]() Join Date: Sep 2007
Looking good. Is there not enough room for a fan clutch, or did you just not want to use one?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#156 |
No room for fan clutch.
#157 |
I was wondering if that was the issue.
#158 |
Should run cool not sure on the noise or mpg though.
#159 |
Got the exhaust manifolds all ceramic coated and turbine housing on turbo ceramic coated also ceramic coated all the manifold bolts. Also a pic of the top hat all finished.
#160 |
WOW! That sure looks NICE! I've said it before, you do nice work.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
#161 |
Thanks. I really appreciate it.
#162 |
got injector return lines installed. I also got the ignition bezel and scratch guard installed. Also replaced the headlight knob and wiper knob.
#163 |
Nice work. Where'd the scratch guard come from?
#164 |
Brothers is where I bought it.
#165 |
Cool, thanks.
#166 |
Here are some pics of what I have done lately. The first pic is the circuit breaker for the glow plugs. Next is the oil pressure gauge line. The rest is the exhaust cross over I made and the v band flange I welded on to the turbo. I still need to ceramic coat the cross over and put the bottom connecting flange on.
#167 |
More of the cross over.
#168 |
Here is the turbo finally mounted, heat shield on, and turbo drain and oil supply line done. I also wired up all the glow plugs and made my own harness and in cased it in a heat sleeve good for 2000 deg.
#169 |
I got exhaust crossover ceramic coated and v band welded in.
#170 |
Nice work on it!
#171 |
thanks.
#172 |
I got the crossover wrapped and installed with new gaskets. I also got the oil cooler lines ran.
#173 |
very nice. i love the attention to detail.
#174 |
Junk Yartist
Attention to detail ends up fixing everything GM did wrong. I can say that because I have a 6.5 that needs something every time I drive it. This 6.5 is the cleanest, smartest 6.5 I have ever seen. Every little thing is built better and looks better. I love the 2 piece cross over. Genius!
Edit. Almost forgot. Did you already post what you are doing for a lift pump?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#175 | |
