#326 |
67cheby
![]() Join Date: Sep 2008
Re: Slosh Tubz SEMA 2015 Build "BOOSTED BERTHA"
next step figuring out where to cut and fitting the lower front door brace with the LMC Truck patch panels
#327 |
67cheby
Next step cleaning off the inner rocker panel brace from the cab mount and fitting the inner rocker / floor patch panel also from LMC Truck
#328 |
67cheby
I chose to leave the rear 10 inches or so of my factory rocker since it was in excellent shape and I like to save all the original metal I can ! I also like to cut a panel where it leaves my weld on a bend to keep it cleaner (in my opinion) after trimming your patch panel lay it over the original panel and mark it off to give you an exact pattern to cut out.
Those clamps are the $8 ones from Harbor Freight and I must say I cant believe I haven't had a set until now, they are Awesome ! |
#329 |
67cheby
Next panel the lower side kick panel. I did have to modify this panel slightly to get it to line up like I liked, and once i get it welded in solid i will be using a step bit to align all the bolt holes exactly.
#330 |
67cheby
That is all at the moment, more to come. I did the drivers side New Years Day and it took me 6 1/2 hours , this side has gone much faster once you figure out what your doing it goes pretty quick. The Harbor Freight clamps give you the perfect welding gap and once it is ground down you have a nice flat butt panel connection, i will post some finished pictures on Monday.
Once again thank you LMC Truck for your support ! |
#331 |
Nice work Mike. Making it look easy!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#332 |
67cheby
Thanks man, its really not that bad. I have actually been really enjoying it !
#333 |
![]() Join Date: Mar 2011
Nice repairs Mike...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#334 |
![]() Join Date: Apr 2007
Liken' this.....that kind of work is like meditation for me...."frustration" for some....and a good example of why you dont "HAVE TO" use entire patch just because it came that way ....it's not so much original metal as it is the original "FIT"....... and your right .....a little planning ahead and you can minimize the weld pattern that is seen........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#335 | |
67cheby
Thank you !
#336 |
there spotweld drill bits available for when you want to save the metal behind the rusted piece
![]() it only cuts the top metal leaving enough fles on the bottom one to weld the new piece on it takes a little practice to know how deep to drill but other than that there nice tools to have talking bout tools but not related to sheetmetal ...... i seen this today : ![]() https://www.youtube.com/watch?v=MyZEaPQinO0 its expensive but so is a gas rig and its a lot safer too you could basicly do this near a gasleak and nothing would happen unlike when using an open flame , as long as you dont damage the coil it will keep going too ans not run out of gas
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-03-2015 at 03:23 PM. |
#337 |
![]() Join Date: May 2007
Huh you made it look like a 15 min episode the slosh tubz channel.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 01-03-2015 at 07:10 PM. |
#338 |
![]() Join Date: Oct 2009
nice work man... you got it going on.
got a few pass-side fenders to look at. and the wing to return... lets hook up this week, if not tomorrow. |
#339 |
![]() Join Date: Dec 2012
In post #327--how did you know where the factory spot welds were? I doesn't look like they were still visible on the surface.
JK |
#340 |
Metal work is looking great Mike.
Scott |
#341 | |
when the material is blasted you just see them it might be the lighting doesnt make the dimples show up or they whent a little thick on the primer usually there pretty clear te see
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#342 |
Very nice progress Mike! Keep it up. I'm hopefully gonna get started on my cab soon.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#343 | |||||
67cheby
thanks man ! Quote:
Go Big Daddy ! |
#344 |
67cheby
Ok well here is the second set of pics.
Metal finished the floor welds. Welded in the LMC Truck side kick panel bottoms bolted the outer bottom of the LMC Truck A pillar back on and welded it in
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 01-05-2015 at 10:45 AM. |
#345 |
Nice build man! I'm following you in Instagram. That sheet metal work is top notch!
#346 |
67cheby
Next up fitting the LMC TRUCK replacement rocker panels.
First since I used the rear of the stock rocker and I wanted to get an exact fit, I cut the rocker a 1/2 inch or so long. Then Layed the rocker over the existing rocker and marked it for an exact cut Cut the rocker and now it is ready for final weld in |
#347 |
67cheby
Next up the front part of the High hump sent all the way from Germany from my friend Patrick Koch , Thank you Patrick !
First step drilling holes around the edge to plug weld Marking the holes on the cab side Grinding off the epoxy so the weld will take Weld it in and smooth off the welds ! |
#348 |
67cheby
That leaves one last step on my floor repairs the hole in the high hump needs filled.
Cut out a patch panel Weld it in and smooth it off ! Also welded up the gas neck, a little hammer and dolly work and she should be good to go ! |
#349 |
67cheby
Here are a few shots of the whole floor after I finished with all the LMC Truck patch panels !
#350 |
![]() Join Date: Sep 2010
Awesome Work Mike... are you sure you don't want to do the finish work on "Class Act"???...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
