oldschoolblazer@yahoo.com
Prom queen goes Ls
Been after this for a while, and felt since I have gotten so much info & ideas out of this great forum, that I would at least try and share my journey. ...
Right off the bat let me tell you I am trying to do this on a budget but at the same time I don't want to step over a Dollar to pick up a dime. What we are after is a simple swap that can give us lots of reliable miles to enjoy, without too much "Bling" |
Re: Prom queen goes Ls
Few more pics
Can't seem to post more than one pic at a time for some reason. . (I haven't had this issue before ?)
It's alsways something.....
![]() Join Date: Nov 2008
Very nice.
I did the 5.3 /4L60E swap in my 71 2wd Blazer runs so good and it just made it a blast to drive.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
![]() Join Date: Dec 2006
Very nice, I'm planning to switch over to LS power soon too.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
67-72 parts collector,…
![]() Join Date: Nov 2002
subscribing,...
You'll never go back.....
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
Subscribing also...
2WD Jimmy
![]() Join Date: Mar 2005
When will we see this on the road this year John?
My Hero Tom Vogel !
This out of order pic is just for you... |
Wow, fast work, looks great in there.....could i get some info. about your brake booster, mine is HUGE oem, and i would like to change it. Looks like you are using a one ton m/c?
#12 | |
![]() and my friend Tom Vogel knows this... that master is a 8inch dual diaphragm with an aluminum master. The brackets are the short ones and I had to bend the shifter lever in order for the gear shifter to get into Park. everything in that setup came from Cpp. (which by the way, I happen to be a dealer for... ![]() |
#13 | |
Does Cpp use aluminum bores, or do they sleeve the m/c?
