72 suspension
Does 72 c10 front and rear suspension swap over to a 66 c10?
Re: 72 suspension
The front should bolt in the rear im not sure on.
Re: 72 suspension
thanks andrewmp6
Re: 72 suspension
The front you http://67-72chevytrucks.com/vboard/s...d.php?t=444823 that shows what will work with what
Re: 72 suspension
The front swaps over but there can be a couple minor differences.
The rears can swap over as well. The coil set-ups utilize a different frame mount for the Panhard bar & the mount on the rear housing is possibly in a different place. The mounting pads are the same width but the 72 housing is going to be wider vs the 66 housing. Prob minor differences on leaf set-ups too but I haven't seen too many pre-67 leaf trucks to know them.
Tags |
66c10, 72c10 |
