![]() Join Date: Jan 2002
Rockwell t221
Where can I find one.... Mine went out.....
2003 2500 HD Crew Cab 1965 GMC K10 1972 Chevrolet k5 blazer |
![]() Join Date: Sep 2008
Re: Rockwell t221
you saw mine in the ad. PM me we should be able to work something out.
andrew |
Re: Rockwell t221
Only way i would put another one back is if you want your truck 100% stock.If not i would use a np205 or even a np203.
Re: Rockwell t221
By changing it out would require changing the brackets and both driveshafts, wouldn't it?
![]() Join Date: Feb 2014
Re: Rockwell t221
Shifters are in a different location. Rockwell T-221 is on the drivers side of the high hump. Cross member is different. Drive shafts are different.
Re: Rockwell t221
And those are the reasone I will keep a t221 in it......
Re: Rockwell t221
whats wrong with it?
1961 chevy K10 my build is------------61K10 build |
Re: Rockwell t221
Well evidently it had a crack in it when I bought it and the PO neglected to tell me about it.... Got it here and used it in the snow.... After a day it popped out of 4wd.. Crawled under it and it has a nasty crack in it.... I don't think I can weld it where it cracked.... Soooo... Hence looking fear a replacement
Re: Rockwell t221
Crack in the t case or the adaptor? I have seen the adaptor for sale on this site. I will run my T-221 also, there are a few of us left. Detents may need tbe looked at also. Bruce
![]() Join Date: Mar 2011
Re: Rockwell t221
I assume yours is married? not the divorced T221 correct.
63 k20 with cummins 4bt, owned sence 1982 |
Re: Rockwell t221
It is divorced
Re: Rockwell t221
There are a few on ebay i have seen recently. not mine. But I have seen them in the past. Shipping would be a nightmare. But its dependent on how bad you want it. Best of luck. I just finished repairing mine. Everyone says to change to an np205. I still like the t221. May have a bit more gear noise. But it's a truck.
![]() Join Date: Aug 2008
Re: Rockwell t221
I would recommend retrofitting a divorced np205 from a dodge. You can find these without too much trouble. Should be fairly straight forward to make some brackets to mount in place of the t221. Front driveshaft shoukd be the same and I bet that the rear driveshaft could be reused as well even though the output is high on the np205 versus low on the t221.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Re: Rockwell t221
I'm with argonaut a np205 would be better in the long run you can get parts for it anywhere if you need them.The rockwell parts are like rooster teeth.
#15 |
![]() Join Date: Feb 2015
Re: Rockwell t221
#16 |
Re: Rockwell t221
Here's one...
http://sacramento.craigslist.org/pts/4882218457.html |
#17 |
Re: Rockwell t221
#18 |
Re: Rockwell t221
searchtempest is the bestsearch engine. I just picked a NOS T221 bearing seal kit out of MN, because of searchtempest. Bruce
#19 |
Re: Rockwell t221
I got a transfer case from a forum member.. It was rebuilt and in excellent condition. Drove to Indy to pick,it up went in smooth and I'm back on the road. Thanks to all for help and advise.
