Old 04-07-2015, 01:30 AM   #601
RockTonka
RockTonka's Avatar
Re: 1958 Apache 38 Dually Dump Project
Originally Posted by 47 Fasttoys View Post
Thanks for the details and pictures, your at a good point for me right now as I may be doing a tilt on mine soon. Do you know how much weight you will be able to tilt? Are you going to use hydraulic or electric ram? Your fab skills are top notch.
Rob
I'm not sure of the weight capacity of the lift, but it's a lot...the hydraulic ram is fairly large! I'm trying to build this out so it's simply heavier/stouter than I'll ever need.
Thanks for the props!
Originally Posted by Kim57 View Post
Looks real nice.
Kim
Cool, glad ya like...thanks Kim!
Not much more to add, but finished the lower pivot mounts. There will be 3/8" rubber strips between the frame and bed feet, hence the gap between feet and frame/gusset...hope to quiet some of the rattling.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 04-07-2015, 05:44 PM   #602
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work guys! That should be able to lift more than you can haul!
Ryan
1969 Chevy milk truck
Old 04-07-2015, 07:05 PM   #603
ptc
ptc's Avatar
Originally Posted by RockTonka View Post
We've been struggling with exhaust clearance issues with the clutch slave, PTO, and even engine to frame (modified mounts to lower engine in chassis). Stock exhaust manifolds still fit (barely), but are my least favorite option.
We brought a set of fenderwell headers in to try, but a lot of inner fender would have to disappear to let these work...but we're kinda digging the look!
Nice project guys! looking real good. Who makes these headers? and is that a 454 Gen 4 block you got them on?
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 04-13-2015, 02:13 AM   #604
RockTonka
RockTonka's Avatar
Thanks DW! I think you're right on the lift vs. haul deal!
Thanks ptc...Gen IV block with '55-'57 chevy fenderwell headers from Speedway Motors...kinda hard to beat at $319/pair (ceramic coated).
We finished up the lift mounts today (upper pivots)...boxed the front two feet of the bed frame and welded in sleeves. The pins slid right in and the scissor part of the lift is done!
My build thread
Old 04-13-2015, 08:32 AM   #605
Kim57
Kim57's Avatar
As always very nice clean work.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-13-2015, 03:07 PM   #606
ptc
ptc's Avatar
Nice thanks for the info.... just may do that with mine so I can run electric cut-outs too. For track days I want to just run straight "FIRE" out the sides behind the front tires like a zoomie !!!!!
Old 04-14-2015, 02:44 AM   #607
RockTonka
RockTonka's Avatar
Kim
Appreciate that Kim.
We added a bit more tonight, welding in a support bar for the back of the lift which is also the upper rear shock mount...then had to fit the sway bar in before figuring out where the shocks would lay, but we like how it all fell into place.
My build thread
Old 04-14-2015, 06:21 AM   #608
Advanced Design
Advanced Design's Avatar
Nice, heavy duty, useful and cool looking all at the same time!
Advanced Design is offline   Reply With Quote
Old 04-14-2015, 03:56 PM   #609
Dieselwrencher
Very nice! Those shocks are sweet!
Ryan
Old 04-15-2015, 12:27 AM   #610
RockTonka
RockTonka's Avatar
Thanks y'all!!
My build thread
Old 04-17-2015, 02:00 AM   #611
RockTonka
RockTonka's Avatar
Working out sway bar details...apparently a 1 9/16" bar is unheard of, couldn't find replacement bushings anywhere. We ended up ordering some 1 1/2" bushings...should be fine.
Made the sway bar links/tabs tonight...baby steps.
My build thread
Old 04-17-2015, 08:30 AM   #612
Kim57
Kim57's Avatar
That sure looks nice.
Kim
My build thread
Old 04-20-2015, 02:15 AM   #613
RockTonka
RockTonka's Avatar
Thanks Kim.
Fab work on the bed is done. We pulled it off for deburring and final smoothing, hope to get it into the sand blasters this next week. Now, we'll jump back into the cab again.
My build thread
Old 04-20-2015, 08:24 AM   #614
Kim57
Kim57's Avatar
It,s going to have a great stance.
Kim
My build thread
Old 04-20-2015, 11:58 AM   #615
ptc
ptc's Avatar
Chassis work is incredible guys!.... very nice job! ]
Ive got a friend that is doing a bunch of fab-work for CDF right now. I know our firefighters would love to have a fleet of trucks looking like this!!!
Old 04-22-2015, 12:52 AM   #616
RockTonka
RockTonka's Avatar
Kim
We hope so Kim. Kinda tall in the last pic, it sits a fair amount higher with the bed off the chassis...we're making bets over here on how much this is going to end up weighing.
Thanks ptc. I hope your friend works alot faster than we do...fire season is about there.
While welding/smoothing some seams on the front of the bed, we had to torch just a few more holes.
My build thread
Old 04-26-2015, 12:37 AM   #617
RockTonka
RockTonka's Avatar
Got the bed and scissors cleaned up...knocking off dingleberries, and a bit of smoothing.
We hauled those to the sand blasters today for both cleaning and painting...blast to white metal, primer, and heavy gloss black paint (industrial level, these guys do alot of oil field stuff).
We decided to go ahead and prep and paint the rear of the frame next (more de-dingleberrying and smoothing right now), in preparation for the finished bed coming back...maybe within this next week.
My build thread
Old 04-26-2015, 08:51 AM   #618
Advanced Design
Good progress! Is that your yard? Nice...great tow Burb too.
Old 04-26-2015, 09:08 AM   #619
Kim57
Kim57's Avatar
Real nice.
Kim
My build thread
Old 04-27-2015, 11:56 PM   #620
RockTonka
RockTonka's Avatar
Thanks AD! Yep, front yard. The burb is our go to ride when chasing/working with parts on the projects.
Real nice.
Kim
Trying to get there...thanks!
My build thread
Old 04-28-2015, 10:20 PM   #621
RockTonka
RockTonka's Avatar
Checked in on progress with the bed today...parts are blasted, should be painted within a day or two.
My build thread
Old 04-29-2015, 08:34 AM   #622
Kim57
Kim57's Avatar
Nice and clean.
Kim
My build thread
Old 05-02-2015, 01:20 AM   #623
RockTonka
RockTonka's Avatar
Yea, the blasters did a great job.
While we're waiting on the bed to be painted (should pick it up Sat.), my son smoothed some glaze into the low spots and laid the first coat of black onto the rear frame rails...
My build thread
Old 05-02-2015, 07:27 PM   #624
RockTonka
RockTonka's Avatar
Picked up the bed and scissors today, very happy with the work done.
Primer coat+couple coats of black+clear coat=
We'll let it sit for a couple days to fully cure before fooling with it too much.
My build thread
Old 05-02-2015, 08:28 PM   #625
Kim57
Kim57's Avatar
Looks great.
Kim
My build thread
