Old 08-09-2015, 03:25 PM   #101
tinydb84
tinydb84's Avatar
Re: Intro and Some Photos of my '63 Project
Damn that looks good!!! I'm not usually a fan of dark green (I like mint green) but that looks great.
Can you tell me a bit about the front bars you added from the frame to the body?
I saw your post on it originally on another thread about stiffening up a frame. I have been reading "Chassis Engineering" by Herb Adams and saw something similar in his book. I wouldnt mind adding them to my truck but I dont want to do it incorrectly and just add unnecessary weight and junk.
David
Instagram: myfabguy
Old 08-10-2015, 09:12 AM   #102
vin63
It's Better With Nitro
vin63's Avatar
Thanks. I mainly did it to help manage the torque my Pontiac was/is producing (I had cracked a bellhousing before), and I couldn't think of a workable way to box the frame all the way up front without eliminating access to the fasteners for the crossmember and upper control arms, etc. In my case, the forward bars provide a front motor plate mount, as well as a little additional chassis stiffness.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-10-2015, 09:41 AM   #103
greg65
greg65's Avatar
Great job and beautiful color choice.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 08-12-2015, 08:19 AM   #104
vin63
vin63's Avatar
Thanks! Got the doors and front fenders hung along front sheet metal mocked up, and the boys started color sanding...
Old 08-12-2015, 08:53 AM   #105
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Looks great
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-24-2016, 10:08 AM   #106
vin63
vin63's Avatar
After a little hiatus spending a lot of time fitting an outlaw Fuel Altered '32 Bantam body and wings to my funny car chassis, so I can run FC and FA, here's an update on the C10...
...I finally got back onto the C10:
Old 01-24-2016, 11:24 AM   #107
HAULIN' IT
That is going to be one AWESOME lookin' truck! Keep us updated on the progress. Lorne
HAULIN' IT is offline   Reply With Quote
Old 01-24-2016, 11:29 AM   #108
66-PMD-GMC
66-PMD-GMC's Avatar
Freaking sweet dude..
Hopefully I'll get a chance to meet you at Steve's Pontiac event.
Projects..
440CID 2X4 Pontiac
Old 01-30-2016, 09:21 AM   #109
vin63
vin63's Avatar
Thanks, guys! Cutting and buffing in progress...
Old 01-30-2016, 09:59 AM   #110
chad64chevy
chad64chevy's Avatar
great to see that your getting to work on your truck again! color is just perfect, I'm going to copy that color when I build a suburban next!!
chad64chevy is offline   Reply With Quote
Old 01-30-2016, 10:16 AM   #111
vin63
vin63's Avatar
Thanks! It's a PPG shade of the 1998 and up GM dark metallic green (Chevy/GMC trucks). There are about 7 or 8 different factory shades that were used...be sure to look at the paint chips in direct sunlight - the differences appear subtle, but in direct sunlight they are significant.
Old 01-30-2016, 10:24 AM   #112
66-PMD-GMC
66-PMD-GMC's Avatar
I'm very anxious to hear that truck run..
Projects..
440CID 2X4 Pontiac
Old 02-09-2016, 09:18 AM   #113
vin63
vin63's Avatar
Thanks...me, too! Since the paint job is almost done, I put in a call to a fellow drag racing family business. This is what they delivered:
Old 02-09-2016, 09:34 AM   #114
66-PMD-GMC
66-PMD-GMC's Avatar
Nice
Projects..
440CID 2X4 Pontiac
Old 02-12-2016, 04:53 PM   #115
vin63
vin63's Avatar
I guess it's been awhile, but I had a couple of questions about my front fender modification since my rear wheel opening modification has been posted in other threads a few times. Here is what I did to remove the area over the front tire to help balance the wheel opening proportions between the front and rear.
After lowering the front suspension as much as I felt was practical, I measured the space between the lower lip of the fender and the top of the tire. I felt that if I lowered the wheel opening lip by 2.5 inches, it would create a nice balance while being very subtle. So, I sectioned a couple of reproduction fenders (I had to massage them quite a bit anyway to get them to fit and line up). I used another repo fender that had a lot of shipping damage and got for free, and a couple of patch panels:
Comparison of front and rear wheel openings:
Final welding and hammer/dolly work...first skim coat of filler:
After final body work and primer:
Old 02-12-2016, 09:07 PM   #116
Very nice work!
Old 02-12-2016, 10:13 PM   #117
66-PMD-GMC
66-PMD-GMC's Avatar
That looks good.
Projects..
440CID 2X4 Pontiac
Old 02-12-2016, 10:26 PM   #118
60chevyjim
60chevyjim's Avatar
that's a great , it makes the truck look lower .
and you get to still have hood hinges with springs.
60chevyjim is offline   Reply With Quote
Old 02-12-2016, 11:58 PM   #119
66-PMD-GMC
66-PMD-GMC's Avatar
Ohhhhh...
You dropped the top of the wheel opening down....
Not shortening the wheel openings. .
Right?
Projects..
440CID 2X4 Pontiac
Old 02-13-2016, 12:14 AM   #120
vin63
vin63's Avatar
Yes, I lowered the top of the wheel opening to make it more proportional to the rear wheel opening of the bedside. With the truck lowered, the rear wheel opening covers all of the top portion of the rear tire and part of the wheel. This makes the height of the front fender opening and the space over the front tire even more obvious. Sectioning the front fender helps take up that dead space above the front tire.
Old 02-13-2016, 12:36 AM   #121
66-PMD-GMC
66-PMD-GMC's Avatar
I have 2 R.O.C fenders I didn't know what to do with. ..
Now I'll cut them up and use the asian tin to do the same.
Looks good. . Just took a couple double takes to realize what you did.
GREAT idea... thanks..
Projects..
440CID 2X4 Pontiac
Old 02-16-2016, 11:29 PM   #122
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Nice job! The wheel opening mods look great.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 02-16-2016, 11:40 PM   #123
62stepside longbox
62stepside longbox's Avatar
The front wheel openings look sweet. I've always thought there was a little too much room on the front openings
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-17-2016, 12:58 PM   #124
vin63
vin63's Avatar
Thanks, guys! Here's a shot after paint:
Old 02-17-2016, 01:50 PM   #125
tinydb84
tinydb84's Avatar
I know I have said it before but I love your truck. First time I have seen the sectioned fender on this body style. Might have to try it with my 66. Looks great!
David
Instagram: myfabguy
