Old 09-16-2015, 09:53 AM   #1
gkhashem
Fiber optic cable
I have been searching in the forum but cannot find this. Where is it routed in the column to the pointer? Is it in the column? If so how do you replace it?
Do I take screw off pointer remove it and then can I see cable?
gkhashem is offline   Reply With Quote
Old 09-16-2015, 10:42 AM   #2
leftybass209
leftybass209's Avatar
Re: Fiber optic cable
It routes through similar to your turn signal harness, then connects to the back of the dash panel. Once you get it out you will see how easily it comes apart.
leftybass209 is offline   Reply With Quote
Old 09-16-2015, 10:43 AM   #3
Sklptrljay
Sklptrljay's Avatar
If you look under the column you'll see the little cover that goes over the wires to the blinker/horn assembly. It goes along with those wires and then up to the pointer. If you unscrew the pointer it should kind of twist out and you hopefully will see the end of the cable. You might have to fish around for it though if it popped back in.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 09-16-2015, 11:12 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here is a picture of what the cable looks like and where it connects on the back of the cluster.... (bottom picture borrowed from member TBONE1964... Thanks Tom)
Leon
