01-06-2016, 05:56 PM | #26 | |
Re: Porterbuilt 1" forward control arms sway bar help
01-06-2016, 07:24 PM | #27 | |
67-72 parts collector,…
Thanks.
01-06-2016, 08:32 PM | #28 |
I went with Ride Tech's Musclebar and drill holes in the frame...
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
01-06-2016, 10:43 PM | #29 | |
Given that N2TRUX has already had a Posi-link related failure on his 1/2 ton, I'm on egg shells w/my heavier 1-ton. So I bought a used PB spec'd Addco bar to swap over to. Sux..... For my dually, I had the original HD bar w/upgraded bushings, bought a Bell Tech bar only to find out it wouldn't work w/PB's arms, then got the MuscleBar but have the end link issue, only to get a PB spec Addco bar. That's > $800 invested just trying to get a front sway bar.
01-06-2016, 11:25 PM | #30 | |
01-07-2016, 12:57 AM | #31 |
Wish I was lucky like that. Not so much.....
01-07-2016, 06:36 AM | #32 | |
I have a set of Thorbecke Bros. a-arms on my blazer with a Ridetech MuscleBar. I assumed the Thorbecke a-arms were just copies of the Ridetech a-arms,... which I thought would work with any aftermarket C10 sway bar that utilized end links. I also thought the only "custom" sway bar from Porterbuilt was the Addco bar specifically made for the Dropmember equipped trucks,.... which would be alot narrower.
01-07-2016, 11:09 AM | #33 | |
05-27-2016, 09:05 PM | #34 |
any more info. on this! I was wondering if I could just cut and re-weld the tabs on were they go for the eye links on (the control arms not the bar)? I got the pb control arms but I'm wondering if this would solve any issues
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
11-05-2017, 11:01 AM | #35 |
anyone think I could just cut the tabs off the control arms an move them to work with aftermarket sway bar like the cpp bar or others?? almost a 1-1/2 yrs. an no comments on my other post
11-06-2017, 11:58 AM | #36 |
Yes, moving the mount location on the arms is an option. I'll be doing just that on mine as it already chewed up the bushings currently in use.
11-07-2017, 11:45 AM | #37 |
Have you been in contact with PB and asked what is going on? Did you already pay for it? If you are still waiting from over a year ago then some body dropped the ball. They are slow but not that slow.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
