09-30-2013, 08:21 PM | #51 |
Re: Parts truck
this one has the stock K20 M/C. i want to swap it for the stock matched 1 ton M/C. they still have a firm pedal but a little less travel. i would match it to the axles. especially if you liked how the dodge felt.
09-30-2013, 10:18 PM | #52 |
Re: Parts truck
Thats abt what I fugured . I will swap in a 1 ton master this winter. hows your truck coming along ?
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
10-01-2013, 11:47 PM | #53 |
Re: Parts truck
This truck is doing fine. i have some little stuff left to piddle with. need to lengthen the park brake cable and mount the flex lines appropriately. need to replace a tie rod dust boot. the engine leaks oil, but i knew that. i've been driving it to for the last week and a half with no issues other than it continually marking its territory. the other truck however hasnt had much done to it.
10-09-2013, 11:21 PM | #54 |
6>8 Plugless........
Re: Parts truck
Nice build up of the yeller truck! Have you decided on what color scheme you want to go with? That rainbow deal you told me about sounds way off base.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-10-2013, 08:45 PM | #55 |
Re: Parts truck
Rainbow would be ideal, but so hard to layout. for now im gonna stick with yellow and rust. ill decide more at a later date.
today was our first snow(sheesh) and it is still going. not cold enough during the day to do much but its below freezing now. i decided that today was as good a day as any to install the front driveshaft. i dont care for spicer style front outputs. anyhow, i pilfered through the pile of candidates in the garage, found one of approximate length and adequate condition and installed it. i was planning on ordering a new one, any likely will still do so at some time. the slip in this one is pretty tight, but i dont like thinking about it and i am a hubs locked in kind of fellow. on a bit of an unrelated note, i rather need to reorganize the garage. there are technically two open bays. still had no where good to go. perhaps i will move the green truck over(when its off jackstands-more on that some other time) and get the 350 off the floor on a stand. or move a couple dana 60s and a 70 two sets of doors a tailgate and another wayward 205 from the short bay... jeez not much room here... |
10-10-2013, 08:50 PM | #56 |
Re: Parts truck
also, you can see the warn vr12000 on the floor the woman got me for my annual celebration of surviving one more trip around the sun. it hasnt decided where it will live. i want to put it behind the rear bumper on the green one for loading trailers, but it would look right at home on the front ol' pee bucket. then there is the jeep, which has had a custom built winch ready bumper that has been always empty for the last 4 years...
10-10-2013, 08:56 PM | #57 |
Vintage 4x4s
Re: Parts truck
A guy never has enough room does he?
What are you going to do for a front bumper?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
12-07-2013, 06:33 PM | #58 |
Re: Parts truck
kinda forgot about this thread. so far im doing nothing for a front bumper. i keep thinking ill buy a tubing bender, and with that maybe make a minimalist front bumper to at least keep the ever growing herd of mule deer at bay and give the winch a place to live. i did get the garage cleaned and the yallow truck gets an inside spot now. pretty upscale accommodations for such a low rent turd!
i need to do a front brake job on this thing. the rotors are warped and give that nice shimmy when you step on the brakes. pretty irritating. i also found a really nice truck that would be a perfect body swap for this thing, but i am trying not to deflate the green truck budget anymore... we'll see how that goes. |
12-07-2013, 07:39 PM | #59 |
Carpe manana
Re: Parts truck
A yellow 4wd Suburban would make a really nice match for this!
06-13-2014, 10:02 PM | #60 |
Re: Parts truck
so, i had a little spare time. this thing ended up on the list.
did an inspection and the bearings will be OK, this axle will get a full blown redo when this truck is in the surgery bay. re packed and new rotors pressed on the hubs. the napa biffed it and sent home the wrong seals and brake pads, so its a wait game until tomorrow. i had my sister in law pick it up for me and she didnt know the difference |
06-13-2014, 10:06 PM | #61 |
Carpe manana
Re: Parts truck
I could use that here Ryan...dial it all in and drive it on up
06-14-2014, 08:21 PM | #62 | |
Re: Parts truck
id like to clean up the body and paint eventually too, provided i keep it. to many project i want to do next, so who knows. |
06-14-2014, 08:26 PM | #63 |
Re: Parts truck
i did wrangle the correct seals and pads today. despite hurricane force(mild exaggeration) winds i got this beast back on its feet. i decided to rotate the tires since it has about 10K on it since they were new.
i cant believe i let it go so long. this truck is a much nicer driver, especially in town now that it doesn't shake like a tweaker when you stop. and with properly broken in new pads and rotors it stops so much better than the old glazed BS that was on there |
06-15-2014, 07:34 PM | #64 |
Re: Parts truck
Since the i finished i have put about 25 miles on the truck and it has changed my perspective about this truck. i always figured i would sell it to fund another project after i got done with the green truck and didn't need the extra spare driver.
now i find myself thinking that the jeep deserves some love next and since this one is the little brother of the group, he will get the pretty nice hand me downs. i can really see this being an awesome project in the spare kind of truck. if it was fuel injected with overdrive, AND a big block, its a heck of a spare project/DD/oh-well beater. i also have the beginnings of a gnarly jeep powertrain stashed. so that helps the decision in that direction... now i have my spare time booked up for the next fifteen years. haha |
06-15-2014, 09:54 PM | #65 | |
Re: Parts truck
I like the plan Ryan. A Big Block gas, and a Diesel k20.Cant beat that ! We all need this.Well some of us do.
Tom 71 K2500 71 K5 Jimmy |
12-14-2014, 12:21 PM | #66 |
Re: Parts truck
nice ride...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-05-2015, 02:33 PM | #67 |
Re: Parts truck
Loving the build man. Keepin it an old work truck. And doin it all on your own. Good to see somthing not all chromed out And polished. (Not that there's anything wrong with that.)
01-09-2016, 01:25 PM | #68 |
Re: Parts truck
Thanks Guys!
Update. it has about 30K on the clock since it was forced back into service. to date it has asked for starter, an alternator and a lower radiator hose. the only occurrence that required a little time on the side of the road was the hose. i should have replaced the rubber when i swapped in all the parts, so i take the blame on that one. the alt and starter both aged gracefully and i swapped them both before any inconvenience. it continues to be loud and rattle a lot. its bumpy and ugly as sin. it smells and requires regular but not excessive quarts of oil. it always starts and is more loyal than your dog. here are a few recent road trip pics to prove the awesomeness of junkyard K20s Top of Lizard Head Pass. 10,200' i think. this was Xmas eve. the roads were all a disaster and i was driving from the Durango area to Glenwood Springs Co. this thing is a mountain goat. Oscar the taco bell dog. he digs old chevys. My sister in law rode shotgun. she was impressed by the amount of wind that blows around in the cab. more of the road It even takes I-70 with hubs locked and the go pedal mashed. The View from aspen mouontain! dominating the winter snow! |
01-09-2016, 03:33 PM | #69 |
Vintage 4x4s
Re: Parts truck
Wow, you have been driving the wheels off it, good to get an update. I want your axle ratio Ryan! about zero RPM at 70 MPH! I like saving old K20's too.
01-09-2016, 05:21 PM | #70 |
Re: Parts truck
Awesome! 30k miles! Looking good.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
01-09-2016, 10:15 PM | #71 |
Re: Parts truck
I'm digging this truck! I need one like this. I think takin her down to raw metal and just clear coating the damn thing would be rad. Fix the oil leaks and call it a day.
Another one on the road defying age. Love it. Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
01-10-2016, 11:49 AM | #72 |
Re: Parts truck
Old work trucks rule!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
01-15-2016, 09:04 PM | #73 |
Re: Parts truck
She keeps going and going! I had to laugh at the comment about the amount of wind that goes through the cab. I'm sure she was real impressed. Haha
01-15-2016, 10:50 PM | #74 | |
Re: Parts truck
And redline is 8k! Heck of a motor!
01-16-2016, 12:25 PM | #75 | |||
Re: Parts truck
Thanks! not quite 30, but close. Quote:
heck yes! it was the least leaky of the two i had at the time.. haha. ive been contemplating an upgrade to EFI and OD. that would really make it a rad beater. but its far down the list. |
