Old 02-02-2016, 07:04 PM   #251
Layedoutsonoma91
Layedoutsonoma91's Avatar
Re: You guessed it, 1950 s10 swap.
Originally Posted by Advanced Design View Post
Under hood looks awesome! Apologies if mentioned before, what is it sprayed with?
Thanks guys, it is sprayed with stuff called raptor liner. Very nice stuff. I sprayed the underside of the cab and firewall with it too.
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 02-03-2016, 01:04 AM   #252
Layedoutsonoma91
Got the wheels back from coating today, and the tires on. The rear rims are a little too wide. Gonna have to swap my rear end with a 2wd to get the back wheels on. But got a pic of the fronts on!
6.0 ls swap/4l80e
Past build thread
Old 02-03-2016, 06:40 AM   #253
HULK64
Looks sooooo good!
Some questions, since I might be getting the same sizes:
Did you have spacers on the rear? Or just a 4x4 rear end?
What BS did you end up going with? If you had known they would end up too wide, would you have gone with a different BS? Or would you have gone with a 10" for the rear? Did you have the room in the rear fender to use the 11"?
I am planning on running aftermarket inner fenders- I'm wondering if I will run into issues at full drop- how close are yours to the inner fender?
I am anxious to hear how it rides on the 20s with those thin tires. Do you have concerns about bending the wheels since they are all steel?
HULK64 is offline   Reply With Quote
Old 02-03-2016, 09:57 AM   #254
Layedoutsonoma91
The rear end is a 4x4 with no spacers. Gotta swap a 2wd rear end in to make them fit. The rear rims are 20x11 with 4.5 back space. They should fit perfect with a 2wd rear. The front is 20x9 with 4.5 backspace. They fit perfect. I had to get a small tire to lay out with 20s. I have been using tires this small for a long time. Never bent a rim yet! Maybe ive been lucky.
6.0 ls swap/4l80e
Past build thread
Old 02-03-2016, 10:14 AM   #255
HULK64
That's cool- I may go with a slightly larger tire if I have the room since I dont want to lay on the ground- just above it(In case I blow an airline)
Old 02-03-2016, 05:36 PM   #256
lower50's
lower50's's Avatar
That looks so good with the rims.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-03-2016, 07:14 PM   #257
*Kenny
Looks so awesome! This truck keeps getting better and better. How long did it take to get them? Thinking about pulling the trigger and doing 20x9 on all fours. Do you think the 20x9 with the 4.5 backspace will work on the rear with no tubs? I have an explorer rear end.
*Kenny is offline   Reply With Quote
Old 02-03-2016, 07:16 PM   #258
Layedoutsonoma91
Thanks guys! 20x9 with 4.5 would worl on mine with the 4x4 rear. I dont know the specs of a 8.8 rear tho. They took about 2 weeks to get after ordering. But that was raw metal wheels
6.0 ls swap/4l80e
Past build thread
Old 02-03-2016, 07:29 PM   #259
*Kenny
Perfect, thanks for the info! Cant wait to see it with all of them on
Old 02-03-2016, 07:30 PM   #260
Layedoutsonoma91
Me either, hope to have that happen this weekend.
6.0 ls swap/4l80e
Past build thread
Old 02-03-2016, 09:04 PM   #261
FarmerSid
FarmerSid's Avatar
Rims are awesome! Like to have that style on my build. Like a little more side wall though
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-03-2016, 11:18 PM   #262
84blaze
Looking forward to seeing all 4 on the truck
84blaze is offline   Reply With Quote
Old 02-03-2016, 11:24 PM   #263
joedoh
joedoh's Avatar
those look crazy on there!
Old 02-07-2016, 12:02 PM   #264
Layedoutsonoma91
Got the 2wd rear end in. Fit perfect!
6.0 ls swap/4l80e
Past build thread
Old 02-07-2016, 02:51 PM   #265
youngrodder
youngrodder's Avatar
Looks great. You don't mess around.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-08-2016, 09:50 AM   #266
lower50's
lower50's's Avatar
I like a lot. Is that a picture of license plates or real license plates?
1951 MG TD
Old 02-08-2016, 09:57 AM   #267
Layedoutsonoma91
Thanks guys, and those are all real plates.
6.0 ls swap/4l80e
Past build thread
Old 02-08-2016, 11:20 AM   #268
Cuttin up
Cuttin up's Avatar
Man that thing looks great!
my 54 s10 build
Cuttin up is offline   Reply With Quote
Old 02-09-2016, 07:26 PM   #269
NickL
What tire size? Looks soooo good.
NickL is offline   Reply With Quote
Old 02-10-2016, 01:25 AM   #270
Layedoutsonoma91
Tire size up front 20x9 245 35 20. Out back 20x11 285 30 20
I wanna ask you guys for an opinion on my truck real quick. This truck had aftermatket fog lights installed when I got it. I took them off and havent put them back on, but ilI am considering puttig them back on. Whatbyall think?
6.0 ls swap/4l80e
Past build thread
Old 02-10-2016, 01:28 AM   #271
Layedoutsonoma91
Before photo
6.0 ls swap/4l80e
Past build thread
Old 02-10-2016, 08:03 AM   #272
lower50's
lower50's's Avatar
I kinda like the fog lights.
1951 MG TD
Old 02-10-2016, 10:35 AM   #273
reaper71
reaper71's Avatar
Never seen them mounted on the fender before..
Have always seen them mounted on the bumper valance,but I happen to LOVE the look with the fog lamps!
I have a pair myself but have went a different direction with the front bumper so I don't know if I will use them.
Mark..
reaper71 is offline   Reply With Quote
Old 02-10-2016, 12:17 PM   #274
84blaze
I like them.
Old 02-10-2016, 09:09 PM   #275
NickL
Personally like it more without them. Thanks for the tire sizes. Going to do 20x9 square here soon.
