Old 12-02-2015, 07:22 AM   #826
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Tricked-out Chevy six cylinder engines
Originally Posted by TJ's Chevy View Post
TTT.
What's up guys? lol Been quiet on here. How's all the builds going?
Sorry - nothing tricked out on the latest one. Just got my stocker-type rebuild on my '67 292 back from the engine shop.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 12-02-2015, 11:12 AM   #827
TJ's Chevy
TJ's Chevy's Avatar
Looks good!
Old 12-07-2015, 07:32 PM   #828
T and S
T and S's Avatar
Mine, freshly painted....
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 12-14-2015, 05:28 PM   #829
wolffcub
wolffcub's Avatar
have some older pictures on page 28 of my 235. Thought i would post some more current ones up from this season.
My updated list:
235 over .040
848 head
Water heated dual Edelbrock Intake
Fenton Headers
Dual Weber carbs
HEI Ignition
Custom PCV system
Drilled crank snout for dampener bolt
Custom made Power Steering / Alt bracket system
Mechanical Fuel pump with pressure regulator
Shortened water pump
Flex Fan
Spin on bypass oil filer setup
Delta Cams 251 grind mechanical cam
New push rods and lifters
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline   Reply With Quote
Old 12-14-2015, 05:54 PM   #830
MikeN
MikeN's Avatar
My updated list:
235 over .040
848 head
Fenton Headers
Dual Weber carbs
HEI Ignition
Custom PCV system
Flex Fan
Nice!
MikeN is offline   Reply With Quote
Old 12-14-2015, 07:29 PM   #831
TJ's Chevy
TJ's Chevy's Avatar
Bet that 235 runs good! Looks nice.
Old 12-14-2015, 08:26 PM   #832
62 Barnfind
62 Barnfind's Avatar
Wolffcub, thats a great looking engine!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-15-2015, 12:44 AM   #833
wolffcub
wolffcub's Avatar
Thanks. It running much better than before. That cam was sure a nice upgrade.
Old 12-27-2015, 10:39 PM   #834
T and S
T and S's Avatar
Engine mostly done:
Old 12-27-2015, 11:30 PM   #835
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by T and S View Post
Engine mostly done:
Nice work!
Old 02-11-2016, 10:02 AM   #836
jcramsey
jcramsey's Avatar
Ran across this one the other day. Ad says its a 250 with 6 water injected carbs...never heard of that, but sounds cool!
https://hiltonhead.craigslist.org/cto/5406982345.html
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 02-11-2016, 11:17 AM   #837
TJ's Chevy
TJ's Chevy's Avatar
Man! lol Thanks fer sharing.
Old 04-28-2016, 12:25 AM   #838
TJ's Chevy
TJ's Chevy's Avatar
How's things going fellow Inliner's? Not much going on with mine, gonna order more engine parts next check though, and am in the process of restoring the truck. Really eager to hear this puppy run!
Old 07-10-2016, 10:22 PM   #839
maydaymike
maydaymike's Avatar
I just did a "spray can rebuild" on the 250 in my '66 shortbed. All stock except for the HEI. I do have a Offy/Holley 390 combo on the shelf to go on in the near future.
maydaymike is offline   Reply With Quote
Old 07-10-2016, 11:49 PM   #840
TJ's Chevy
TJ's Chevy's Avatar
Very nice!
Old 07-11-2016, 01:39 AM   #841
'68OrangeSunshine
'68OrangeSunshine's Avatar
Mike, will you be running headers?
Old 07-11-2016, 08:43 AM   #842
maydaymike
maydaymike's Avatar
I was planning on the Langdon headers, or possibly one of the 2.5" outlet 292 manifolds. I'm going to run the offy with the stock exhaust though for a while due to budget constraints. Both the 1bbls I have around are weepy, warped, throttle shaft leaking crap, and I don't want to spend the coin on another.
Old 07-11-2016, 04:14 PM   #843
'68OrangeSunshine
I bought my Clifford Research long tube headers back in '78, when they were under $90 bucks. Can't get 'em for that now. Mine have lasted thru 2 engines, but I've had them re-flanged to 3/8" and -- after #5 tube got bashed in off-roading -- that tube was resectioned. They ran 25 years on a 1977 build and then were hot tanked and bead-blasted for a 2005 rebuild. Don't know what I'd run now, if I had to build up another 292, but Clifford's are not in the budget anymore.
Old 07-11-2016, 04:31 PM   #844
TJ's Chevy
TJ's Chevy's Avatar
Got my Clifford headers for $349 some 4 years ago. lol
Old 08-13-2016, 04:19 PM   #845
66gmcman
Hi i just got my trucks home. I got 2 1966 gmc 1/2tons. Ones a parts truck with a 283 and the other is my good one with a 6 banger. Reading this thread got me thinking maybe keeping the 6 banger and fixing it up like these tricked out ones on this thread. Question i have is what kind of output or horsepower can be had with doing these 6 cylinders right?
66gmcman is offline   Reply With Quote
Old 08-13-2016, 04:33 PM   #846
paintman
Question i have is what kind of output or horsepower can be had with doing these 6 cylinders right?[/QUOTE]
The question we will have is..............How much money do you want to spend.
Unless your towing something, I never understood why people worry about how much power an engine makes. Now having said that, I blew through 7K real fast and got nearly 300HP out of my 292.
paintman is offline   Reply With Quote
Old 08-13-2016, 07:12 PM   #847
TJ's Chevy
TJ's Chevy's Avatar
Depends on which one you have. Your GMC could have a 230,250, or 292.
230: Flat top pistons. 4 inch side covers.
250: Dished pistons. 4 inch side covers.
292: 6 inch side covers and fuel pump in the center.
Old 08-15-2016, 01:06 PM   #848
Sixteen Tons
Sixteen Tons's Avatar
I'd keep the six man. Something different, easiest IMO to work on and you can bolt on some upgrades before you get into the real performance stuff.
Wanda - 1969 C/10 LWB 250 I6 3OTT
LWB>SWB
Sixteen Tons is offline   Reply With Quote
Old 11-03-2016, 04:28 PM   #849
paintman
Ok guys i thought I would post some ear candy over hear for the ones who are not following my 46 build thread. This is the first start up since dyno day of my 292. This motor was built by Larry's Power in Groton Ct., the same shop that did Leo Santucci's spliced head 292. Enjoy!
https://www.youtube.com/watch?v=auaDSwCWdCk
Old 11-03-2016, 09:52 PM   #850
maydaymike
maydaymike's Avatar
So I finally got the Offy/Holley 390 combo up and running a few weeks ago. I used a cable throttle assembly from an '88-up Chevy truck. After some carb repair and tuning, it runs pretty well, and gets around the same mileage that I was getting with the original setup, 14-15 MPG. That's with the stock 3 speed, 3.73 rear, and 28" tall tires. There is a noticeable power increase as well. I'm running it with a stock exhaust manifold for now, but Langdon headers are what I have planned for the future.
