Old 02-11-2016, 07:46 PM   #76
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 1958 GMC Memorial Build
Did you get the headers sorted out yet? Looking forward to seeing your progress!
ChuckDriver is offline   Reply With Quote
Old 02-15-2016, 03:49 PM   #77
58-GMC
58-GMC's Avatar
Hey ChuckDriver - I went with some Patriot Clippster Headers. Haven't tried fitting them yet. Hoping to try them out this week. I will post back with the results.
Build Thread: 1958 GMC Memorial Build
58-GMC is offline   Reply With Quote
Old 02-16-2016, 07:10 PM   #78
dug224
dug224's Avatar
First rate!!! Love the frame and the fact that you painted in mint. Subscribed.
dug224 is offline   Reply With Quote
Old 02-16-2016, 10:16 PM   #79
ChuckDriver
Nice, hopefully you've found a set that fit!
Old 02-17-2016, 12:12 PM   #80
58-GMC
58-GMC's Avatar
Looks like the Patriot Headers will fit! Very slight trimming necessary on driver side near the frame rail. No trimming on the passenger side!
Did run into a fitment problem with the 4l80 transmission though. Have to build a small tunnel in the cab floor. Nothing too major.
Firewall is done and in primer.
Old 02-17-2016, 12:22 PM   #81
58-GMC
58-GMC's Avatar
Here is a full pic. Everything will get a nice layer of black epoxy primer before it rolls out of the shop.
Still have a bit to go.
Old 02-17-2016, 01:04 PM   #82
ptc
ptc's Avatar
Originally Posted by 58-GMC View Post
@ptc - I have heard good things about the Champion Radiators. Glad to hear you think so too!
Seen quite a few at the tracks and in custom cars, so I went to them for just some info. But the folks at Champion totally worked with me for days on end to get the right radiator for my truck that wouldn't be a custom build (to save money). I made measurements and they checked all their stocked sizes to find the right one. They went way above and beyond to help out.
Good luck with the build!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-17-2016, 09:48 PM   #83
ChuckDriver
Would you please post some pic's and part number for the headers!!
Old 02-18-2016, 10:41 AM   #84
58-GMC
58-GMC's Avatar
I will get some pics up once they're installed. Should be fairly soon.
In the meantime...here is the part#: PTE-H8073
Old 02-20-2016, 11:31 AM   #85
greystoke
Did the cab fit down on the frame ok with the transmission cover removed?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 02-20-2016, 10:30 PM   #86
58-GMC
58-GMC's Avatar
Unfortunately no. They have to build a small tunnel in the cab floor. I guess when the transmission was first installed it was at the wrong angle which made it appear that it would fit without floor modification.
I'll get some pictures up this week of the results.
Old 02-25-2016, 12:52 PM   #87
58-GMC
58-GMC's Avatar
Here are some pics of the headers mounted. The driver side header took a couple taps with a hammer to dent one pipe to clear the frame rail. The passenger side had to have the collector moved back 1-2" since it dumped right at the frame rail. All-in-all a really good option for trucks running an LS engine and Porterbuilt suspension.
Old 02-25-2016, 02:23 PM   #88
ptc
ptc's Avatar
Gonna be a 'tight' fit for a steering shaft ..... They didnt have a rear exit type header you could go with to get them out of your way?
Heres a set from BBK - they make some nice stuff for LS engines.
Old 02-25-2016, 02:34 PM   #89
58-GMC
58-GMC's Avatar
Hey ptc - I agree it looks like a tight fit. I dropped off some parts yesterday and discussed the headers and steering. The shop seemed confident it was gonna work - I guess we will see. The BBK headers look good but from the pic I can't tell if they hug the block enough to squeeze between the frame rails.
I looked around and had a hard time finding any info on what worked for headers on these trucks with the LS/Porterbuilt combo. Even PB couldn't give any recommendations. I saw Delmo use a corvette manifold but I wasn't super keen on the way that looked.
Old 02-25-2016, 05:07 PM   #90
wheelbarrow
Thumbs up Re: 1958 GMC Memorial Build
Very Nice!
wheelbarrow is offline   Reply With Quote
Old 02-25-2016, 09:47 PM   #91
ChuckDriver
Thanks for the pic's, hope the steering linkage is not a problem.
Old 02-25-2016, 11:06 PM   #92
Kim57
Kim57's Avatar
Looks like they should work out.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-26-2016, 01:29 PM   #93
ptc
ptc's Avatar
Thats always good news from a shop.... when they find solutions to problems instead of just telling you it wont work!.... hate that.
If PB is gonna stay in this 'build world' I would think that they would either start finding suppliers that fit their systems or start building their own headers and anything else that needs to fit their kits and provide supplemental kits to their product line.... you cant just leave people hanging.... in this "want it now type of world".
Cant wait to see you driving this thing!!!!
Old 02-27-2016, 01:58 AM   #94
Nut Case
Nut Case's Avatar
In my wandering the net I came across information that for the 55-59 TF trucks with BBC's, that a Hooker or Headman Super Comp long tube heads will fit. When I come across any nuggets I take notes. My notes on headers don't list where or who furnished the info, only the suggestion. I bought Mark VI 454 block that I was assuranced that it ran. Not with 5 of the jugs full of water and bore to +.40, now I have a mock up block. Purely by luck the 454 seller threw in a set of long tubes. No ID anywhere on the headers. With the guts out of the block, and the heads and headers on I did a test fit, and it did with about 3/4 clearance on both sides. So I going to order the Hooker Super Comps when the time comes and cross my fingers. Gook Luck Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 02-27-2016, 02:14 AM   #95
Nut Case
Nut Case's Avatar
Look for the Headers that fit a 70 Chevelle, sorry left the important information out.
It's late I should turn out the lights and go to sleep. Maybe I'm in a dream and sleep typing.
Nut Case
Old 02-27-2016, 02:15 AM   #96
Nut Case
Nut Case's Avatar
Big Block 70 Chevelle. Doe
it only took 3 posts.
I'm outa here Nut Case
Old 02-27-2016, 11:51 AM   #97
greystoke
Because the PB front clip is narrowed a bit it does lack header space...I'm looking forward to pictures of how the steering linkage ( firewall to unisteer ) is installed. Love this build and the truck..oh yeah, Shanes a nice guy too
Old 02-27-2016, 03:13 PM   #98
ChuckDriver
Nate has developed a newer version for the TF truck that has more room for headers.
Old 02-28-2016, 10:23 PM   #99
58-GMC
58-GMC's Avatar
I will try to get some pics once the steering linkage is all installed.
@ptc - I will definitely get some pics up of it driving!
@greystoke - thanks buddy, appreciate the kind words!
@ChuckDriver - of course they come out with something new before I even get mine on the road, haha. That's good though that he modified the front drop member to make more room for the headers.
Old 03-04-2016, 04:00 PM   #100
58-GMC
58-GMC's Avatar
The shop hasn't done the final steering shaft assembly but they assured me again it would work out slick. Fingers crossed.
Wiring is in full swing. Here are a couple pics.
They also sprayed the front clip and bed with black epoxy.
