Old 02-22-2016, 11:20 PM   #151
AJCK87
Re: 1963 GMC C30 panel truck
Started the blending. Will need to spend some more time on getting it nice and smooth.
AJCK87 is offline   Reply With Quote
Old 02-23-2016, 12:00 AM   #152
62stepside longbox
62stepside longbox's Avatar
Nice, what are you using to take your welds down? I find sandpaper flap disc's such as these work the best.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-23-2016, 11:22 AM   #153
AJCK87
Old 02-23-2016, 11:26 AM   #154
AJCK87
I have used them, they are awesome. I found that I was able to get to aggressive with them and would end up taking to much off. So I have been using a regular grinding disk, a file and in this case was trying out some sand paper. Makes me be a bit more cautious I guess
Old 03-04-2016, 12:20 AM   #155
AJCK87
Down island for the weekend, tackling the bumpers. The front is mounted now. The back is all ready to go, just letting the paint dry. Pictures to come
Old 03-04-2016, 01:46 AM   #156
62stepside longbox
It's lookin good
Old 03-06-2016, 11:16 PM   #157
AJCK87
It's lookin good
Thank you, I like you rocker progress as well!
More on the panel. Rear bumper is all bolted up. Decided to start drilling out all the body mount carriage bolt and well... Ended up drilling out all the bolts for the strapping as well. The strapping was crusty, soo, I got them all fire wheeled and painted with enamel. Will be looking into getting some new plywood to lay down, might be tough to find some in 10 1/2' lengths hahaha
Old 03-10-2016, 11:34 PM   #158
AJCK87
Parts come in!!!!
O yeah, had to put on the lenses and they are looking sharp. Also got , the front windshield seal, cowl to hood seal, front bumper brackets, front floor pan supports, front fender seals and some more barn door hinge seals.
Old 03-11-2016, 03:00 AM   #159
62stepside longbox
Wow those lights look great!
Old 03-20-2016, 01:40 PM   #160
AJCK87
Thanks! Cool work on your fenders!
I had some shop time this weekend and a bit of progress.
First I started putting together my front signal lights. I mounted some amber LED panels in the signal housings. Also got a set of new signal lenses. Nice and crisp!
Also got a few more hours into smoothing and blending the seam from my passengers side front fender. It's coming along but I still want to do a bit more before I fasten in the support. It sure is tricky to get that seam nice on a big piece of sheet like that. Good practice a guess for when I tackle to rear quarter panels
Old 03-20-2016, 01:41 PM   #161
AJCK87
Here's the fender so far
Old 03-20-2016, 09:43 PM   #162
62stepside longbox
Nice work, good to see you making progress
Old 03-25-2016, 11:27 PM   #163
AJCK87
Always hoping to see more though hahaha.
Down island until the 4th. Looking to get some more done on the floor pan, rockers and floor support. Started on the floor here is where I'm at. All the bulbs in the shop were out when I got down, will have to pick up some tubes tomorrow.
Old 03-28-2016, 06:01 AM   #164
notsolo
notsolo's Avatar
Anthony...Great progress on the truck, did you determine if it is a 62, wider frame in the back? I found that a 93 caprice wagon poly fuel tank fits close to the frame rails of my 62, made some new cross braces and hung with 93 OEM straps. May not be what you need for diesel...Ed
notsolo is offline   Reply With Quote
Old 03-30-2016, 12:52 AM   #165
AJCK87
Thanks Ed! It is a 63 with 34" wide frame rails. The rear bumper and sil plate are from a 62, had to make some adjustments to make them fit.... They are on there now hahaha. I am hoping to fit the polymer fuel tank out of the dodge in between the frame rails in front of the rear diff and behind the transfer case. Will have to see how it works out. I will keep the caprice tank idea in reserve, thank you!
Passengers side floor, rocker and floor support are checked off the list
Old 03-30-2016, 12:54 AM   #166
AJCK87
Got the motor pulled last night
Old 03-30-2016, 12:59 AM   #167
AJCK87
Moving on to the drivers side. It is in much better shape, have to repair the hinge adjuster plate and the bracket that holds it in place. Soo many rats nests in the A pillar and rocker!!!
Old 03-30-2016, 01:41 AM   #168
62stepside longbox
It's surprising how much driver and passenger sides can differ, mine was like that as well. The passenger was twice as worse as the drivers. When you are done all the rust repair you'll be glad you got it over with. Keep up the good work
Old 03-31-2016, 01:31 AM   #169
AJCK87
Thanks for the encouragement! To bad about the suburban being scraped, probably would have liked to cut some body parts off for the panel .
More progress on the drivers side rocker. This side had more material to work with and is turning out better then the passengers side.
Old 03-31-2016, 01:34 AM   #170
AJCK87
Got the hunger adjuster plate fabricated as well
Old 03-31-2016, 02:12 AM   #171
62stepside longbox
Nice work on the inner rocker. Well the burb might actually still be alive. He dropped it off at a yard (don't know what yard) and it might not be crushed for a while. I messaged him to ask if it's still around, if it is I'll be sure to let you know.
Old 03-31-2016, 09:54 AM   #172
AJCK87
Thanks that would be awesome! If it's in the Comox Valley I can stop there on my way back to McNeill.
Old 03-31-2016, 10:37 AM   #173
62stepside longbox
Sorry I just heard back from him and it's gone.well the pictures made it look a hundred times better than it was anyways so no big loss.
Old 04-01-2016, 01:01 AM   #174
AJCK87
O well, thanks for trying.
Went hard today and I got the floor in and fabed up the inner portion of the A pillar. More to come
Old 04-01-2016, 10:42 AM   #175
62stepside longbox
Nice job! I don't know where you find the time to do all this in one day
