Old 03-28-2016, 09:38 AM   #1
1972 Jimmy
1972 Jimmy's Avatar
Wire harness frame clips
Hey guys, does anyone know if any manufactures are reproducing the clips that hold the rear wire harness to the frame. These clips look to have some type of plastic/rubber coating on them. I'm assuming to prevent wearing through the harness. Any help would be appreciated.
1972 Jimmy is offline   Reply With Quote
Old 03-28-2016, 06:55 PM   #2
tjsblazer
tjsblazer's Avatar
Re: Wire harness frame clips
I have never come across them. They are fairly complicated design for what they do. I needed a couple and bought them from someone doing a part out.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 03-28-2016, 09:56 PM   #3
1rippen6
Hey Jeff did they turn out ok for you? Eric I should have some more if you need them.
1rippen6 is offline   Reply With Quote
Old 03-28-2016, 10:20 PM   #4
tjsblazer
tjsblazer's Avatar
Worked great. I cleaned them up with a fine media to get rid of the surface rust and then repainted.
Yes the bottom portion where the wire sits has a rubber coating but I just painted over the whole thing.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 03-29-2016, 07:32 PM   #5
1972 Jimmy
1972 Jimmy's Avatar
Dwayne,
Let me look to see how many I need and I will get back with you!
Eric
Old 04-01-2016, 06:40 AM   #6
GMCPaul
We have them in 10pc sets, although the new versions do not have a rubberized coating on bottom 1/4. You'll find them here
http://www.gmcpauls.com/wire_harness_3.htm
Part # 300032 1967-72 Wire harness clips. Used to attach wires to sheet metal and frame. 10 piece set. Made in the USA $10.00per set
We also carry the wire harness straps on the same page.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
